  3. Pimatic doesnt receive any signal
3 Posts 3 Posters 1.2k Views 1 Watching
  • fahrettineF
    fahrettineF
    fahrettine
    1-I installed Pimatic.
    2-I installed Serial Gateway on the Arduino Nano.
    3-I installed the Light sketch from MySensors on the Nano.
    Pimatic logs look like below. It seems it doesnt receive any signal.
    I think there is someting wrong with the USB port...
    Are my USB port settings correct?
    "plugin": "mysensors",
    "driver": "serialport",
    "protocols": "1.5.1",
    "startingNodeId": 1,
    "driverOptions": {
    "//": "'/dev/ttyACM1' if using serial Gateway",
    "serialDevice": "/dev/ttyMySensorsGateway",
    "baudrate": 115200
    PIMATIC LOG
    2016-04-05 19:23:46info [pimatic]: Listening for HTTP-request on port 80...
    19:23:46info [pimatic-mobile-frontend]: rendering html finished
    19:23:20info [pimatic-mobile-frontend]: rendering html
    19:23:20info [pimatic-mobile-frontend]: packing static assets finished
    19:23:18info [pimatic-mobile-frontend]: packing static assets
    19:23:18info [pimatic]: New device "Light"...
    19:23:08info [pimatic-cron]: the time is: Tue Apr 05 2016 14:23:08 GMT-0200 (GMT+2)
    19:23:08info [pimatic]: Loading plugin: "pimatic-mysensors" (0.8.25)
    19:23:02info [pimatic]: Loading plugin: "pimatic-mobile-frontend" (0.8.82)
    19:22:59
    • SweebeeS
      SweebeeS
      Sweebee
      First check where your usb device is.
      Open the terminal and type:
      ls -l /dev/ttyU*
      You should see something like:
      crw-rw---- 1 root dialout 188, 0 Apr  6 18:36 /dev/ttyUSB0
      crw-rw---- 1 root dialout 188, 1 Apr  6 07:00 /dev/ttyUSB1
      In my case it is /dev/ttyUSB1 (other one is my homeduino).
      add this to the plugins:
            "driverOptions": {
              "serialDevice": "/dev/ttyUSB1",
              "baudrate": 115200
      Then start pimatic and see if you can find the connected message:
      Connected to MySensors Gateway
      • OitzuO
        OitzuO
        Oitzu
        This can probably marked as solved in http://forum.mysensors.org/topic/797/pimatic-mysensors-controller-plugin/85 ?
