  3. Step-by-step procedure to connect the NRF24L01+ to the GPIO pins and use the Raspberry as a Serial Gateway (MySensors 1.x)
nrf24raspberry piraspberryraspberry nrf24l01 gpiogateway
168 Posts 47 Posters 214.4k Views 36 Watching
    shabba
    Thanks @mfalkvidd - will check it out.
      shabba
      Ps. I followed https://github.com/abouillot/HomeAutomation/tree/master/piGateway and now have a MQTT service running. But I do not know how to connect this to domoticz or even debug that it can actually see my test sensor etc.
      • haydukeH hayduke
        @mfalkvidd said:
        @Justinian looks like you forgot to run "sudo make install" after "make all"
        I took a little break from this project, but I worked on it again this weekend. I decided to start from scratch and rebuild the gateway completely. I put a fresh Domoticz image onto the SD card, updated and upgraded, cloned, compiled, and installed the RF24 and Raspberry code.
        Now I have the exact same symptom as Justinian :(
        Since this used to work for me at some point, next I will try using an older Dmoticz image. I read somewhere that people had better success by NOT using apt-get update. Perhaps it's a problem with Jessie vs Wheezy? Domoticz switched kernels during on of the version upgrades.
        Winter is over, so I can live without getting my furnace controls working right now. I know relays have an issue, but now I'm just needing to monitor the temperature in an egg incubator.
        I'm surprised that using a rpi with this radio module directly attached is not a more popular platform. Is it just not a reliable platform? With the rpi3 out now, there shouldn't be a CPU load issue trying to act as an HA controller even with a large installation. I've got lots of ideas I want to implement if I can ever get a stable backend.
        strangerS
        strangerS
        stranger
        This thread has been great - thanks @mfalkvidd!
        @hayduke I had a similar problem earlier. I haven't fixed it yet, but here's where I'm at:
        Clean install (Jessie, RF24, Raspberry) March 25th 2016 has the problem where it works for a few minutes, then stops (/dev/pts/0 dissapears, which breaks the symbolic links - ttyMySensorsGateway and ttyUSB20). This is at home where I have a bunch of nodes around and a Vera with serial gateway, so there are lots of different signals coming in.
        But when I move to another location with just one node (that just sends a light status update regularly), it works fine - at least, I've been sitting here with it running for 30 minutes so far.
        I know this might not help much, I'm new to all this and still getting my head around everything. I would probably agree with what you suggested earlier: something in one of the messages that causes a problem with the gateway (possibly to do with already having another serial gateway nearby).
        I'll try to do some more testing by changing this gateway to a different channel to my other one, and gradually bringing nodes across to see when it breaks.
        • alexsh1A
          alexsh1A
          alexsh1
          @stranger just to make sure - you said you have two gateways at home. Did you change the channel so that they do not interfere with each other?
          strangerS 1 Reply Last reply
          • Tore André RosanderT
            Tore André Rosander
            Hello, im just starting to set up some mysensors nodes and have already set up a gateway with nodemcu (esp).
            But to eliminate the number of devices i am thinking about moving the gateway directly to the Raspberry pi as mentioned in this thread. Is there any downsides (or upsides) by connecting the nrf24 chip directly to the RPI?
            And btw:
            "The radio module NRF24L01+ is cheap and power efficient, but it is unable to communicate with regular wifi."
            That is not entirely correct, the nrf24 can connecct to wifi and send TCP/IP packets with an arduino.
            • alexsh1A alexsh1
              strangerS
              strangerS
              stranger
              @alexsh1 No actually. I didn't want to go around and reprogram all my nodes, and I forgot to turn off my other gateway. That is what I was going to do next, but I've just been running it for a few hours with no problems (with a heap of nodes and another gateway a few metres away, all on the same channel).
              I then Home Assistant and tested out a few nodes, and now it sometimes breaks, but mostly works fine.
              All that being said, I've realised I need signing (I have a few electronic locks), so I'm going back to a hardware serial gateway. If anyone has got signing working I'd love to hear how - I had a look but couldn't figure it out and don't have much time to spare on it.
              • Sander StolkS
                Sander StolkS
                Sander Stolk
                wrote on last edited by Sander Stolk
                #82
                pi@Domoticz3:~/Raspberry$ sudo ./PiGatewaySerial
                Starting PiGatewaySerial...
                Protocol version - 1.4
                Created PTY '/dev/pts/1'
                Gateway tty: /dev/ttyMySensorsGateway
                ================ SPI Configuration ================
                CSN Pin          = CE0 (PI Hardware Driven)
                CE Pin           = Custom GPIO25
                Clock Speed      = 8 Mhz
                ================ NRF Configuration ================
                STATUS           = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
                RX_ADDR_P0-1     = 0xa8--------------------------------
                RX_ADDR_P2-5     = 0xff 0xc-----------------
                TX_ADDR          = 0xe7e7e7e7e7
                RX_PW_P0-6       = 0x20 0x20 0x20 0x00 0x00 0x00
                EN_AA            = 0x3b
                EN_RXADDR        = 0x06
                RF_CH            = 0x4c
                RF_SETUP         = 0x23
                CONFIG           = 0x0e
                DYNPD/FEATURE    = 0x3f 0x06
                Data Rate        = 250KBPS
                Model            = nRF24L01+
                CRC Length       = 16 bits
                PA Power         = PA_LOW
                ^[read: 1-1-0 s=0,c=1,t=0,pt=7,l=5:16.1
                read: 1-1-0 s=0,c=1,t=23,pt=2,l=2:1022
                read: 1-1-0 s=1,c=1,t=23,pt=2,l=2:1023
                read: 1-1-0 s=2,c=1,t=23,pt=2,l=2:1021
                Received SIGINT^C
                Exiting...
                pi@Domoticz3:~/Raspberry$ sudo cat /dev/ttyMySensorsGateway
                cat: /dev/ttyMySensorsGateway: No such file or directory
                pi@Domoticz3:~/Raspberry$ sudo /etc/init.d/PiGatewaySerial start
                [....] Starting PiGatewaySerial (via systemctl): PiGatewaySerial.serviceFailed to start PiGatewaySerial.service: Unit PiGatewaySerial.service failed to load: No such file or directory.
                 failed!
                Playing with a RPI 3 B and a NRF24+ radio I got this error message above.
                Running Jessie but with no luck...
                Anybody else got this problem?
                • Sander StolkS Sander Stolk
                  Clock Speed      = 8 Mhz
                  EN_AA            = 0x3b
                  EN_RXADDR        = 0x06
                  RF_CH            = 0x4c
                  RF_SETUP         = 0x23
                  CONFIG           = 0x0e
                  Data Rate        = 250KBPS
                  Model            = nRF24L01+
                  PA Power         = PA_LOW
                  Received SIGINT^C
                  Exiting...
                   failed!
                  @Sander-Stolk did you run
                  sudo make install
                  What happens if you run
                  sudo /usr/local/sbin/PiGatewaySerial
                  Sander StolkS 1 Reply Last reply
                    sudo make install
                    Sander StolkS
                    Sander StolkS
                    Sander Stolk
                    @mfalkvidd
                    Tnx that worked but this is not in the tutorial I'm I right?
                    If this happens, double-check your wiring and correct any problems. Press Ctrl+Z and type
                    sudo killall PiGatewaySerial
                    to get rid of the non-functioning Gateway. Then run sudo /usr/local/sbin/PiGatewaySerial again
                    If all is well, exit PiGatewaySerial by pressing Ctrl+C. Then run
                    to start the gateway as a background process. Verify that it started correctly by running```
                    • mfalkviddM
                      Yes it is. See the section under
                      COMPILING THE GATEWAY
                      also, you ran sudo ./PiGatewaySerial instead of sudo /usr/local/sbin/PiGatewaySerial described in the instructions.
                      • mfalkviddM
                        I have added a
                        TROUBLESHOOTING
                        section in the original post to cover for this error. Hopefully it can help if someone else makes the same mistake.
                        • micahM
                          micahM
                          micah
                          Any thoughts on making a version for the 2.0 dev branch?
                          I recently switched my in-progress builds to 2.0 and am in the process of "trying" to get my Raspberry Pi2 setup with OpenHab and Mosquito. And the idea of not having to have an ethernet gateway arduino in the mix is appealing to me.
                          I would do it myself but I probably only have 3.275% of the required knowledge at this point
                          • mfalkviddM
                            I'm unfortunately at about the same level as you. I can compile stuff and do basic troubleshooting, but merging the dev branch with the gateway code is way out of my league.
                            micahM 1 Reply Last reply
                              micahM
                              micahM
                              micah
                              There is no way you are at 3.275% knowledge like me... I've seen many of your posts on here and you are at least a 4.532%... lol.... no honestly I've liked your posts and you seem very knowledgeable. You've got to be at least a 84.5% ;)
                              • Sander StolkS
                                Sander StolkS
                                Sander Stolk
                                Can somebody tell me how to change the channel after compiling and using the Gateway for a couple of days?
                                Changing the channel in MyConfig.h in the dir Raspberry doesnt bother even after a reboot.
                                Still 0x4c channel / 76 when I run the PiSerialGateway program.
                                alexsh1A 1 Reply Last reply
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  Did you recompile the code after changing the channel?
                                  • alexsh1A alexsh1
                                    Sander StolkS
                                    Sander StolkS
                                    Sander Stolk
                                    #92
                                    @alexsh1 I did this after changeing the channel in MyConfig.h: make all && sudo make install
                                    Rebooted after that but no luck
                                    • mfalkviddM
                                      That should be sufficient but you could see if running make clean before make all helps.
                                        Sander StolkS
                                        Sander StolkS
                                        Sander Stolk
                                        #94
                                        @mfalkvidd I did the make clean and the make install and rebooted.
                                        Still 0x4c eq. 76
                                        Using username "pi".
                                        Server refused our key
                                        pi@192.168.1.14's password:
                                        ______                      _   _
                                        |  _  \                    | | (_)
                                        | | | |___  _ __ ___   ___ | |_ _  ___ ____
                                        | | | / _ \| '_ ` _ \ / _ \| __| |/ __|_  /
                                        | |/ / (_) | | | | | | (_) | |_| | (__ / /
                                        |___/ \___/|_| |_| |_|\___/ \__|_|\___/___|
                                        Last login: Sat Apr  9 18:41:17 2016 from 192.168.1.34
                                        Monday, 11 April 2016, 12:10:24 pm CEST
                                        Linux 4.1.18-v7+ armv7l GNU/Linux
                                        Uptime.............: 1 days, 17h29m13s
                                        Memory.............: 520336kB (Free) / 948056kB (Total)
                                        Load Averages......: 0.00, 0.01, 0.05 (1, 5, 15 min)
                                        Running Processes..: 97
                                        IP Addresses.......: 192.168.1.14
                                        pi@Domoticz3:~$ cd Raspberry/
                                        pi@Domoticz3:~/Raspberry$ cat MyConfig.h
                                         The MySensors library adds a new layer on top of the RF24 library.
                                         It handles radio network routing, relaying and ids.
                                         Created by Henrik Ekblad <henrik.ekblad@gmail.com>
                                         12/10/14 - Ported to Raspberry Pi by OUJABER Mohamed <m.oujaber@gmail.com>
                                        #ifndef MyConfig_h
                                        #define MyConfig_h
                                         * Configure Sensor Network
                                        #define RF24_CHANNEL       111             //RF channel for the sensor net, 0-127
                                        #define RF24_DATARATE      RF24_250KBPS   //RF24_250KBPS for 250kbs, RF24_1MBPS for 1Mbps, or RF24_2MBPS for 2Mbps
                                        #define RF24_PA_LEVEL      RF24_PA_MAX    //Sensor PA Level == RF24_PA_MIN=-18dBm, RF24_PA_LOW=-12dBm, RF24_PA_HIGH=-6dBM, and RF24_PA_MAX=0dBm
                                        #define RF24_PA_LEVEL_GW   RF24_PA_MAX  //Gateway PA Level, defaults to Sensor net PA Level.  Tune here if using an amplified nRF2401+ in your gateway.
                                        #define BASE_RADIO_ID      ((uint64_t)0xA8A8E1FC00LL) // This is also act as base value for sensor nodeId addresses. Change this (or channel) if you have more than one sensor network.
                                        // MySensors online examples defaults
                                        #define DEFAULT_CE_PIN 9
                                        #define DEFAULT_CS_PIN 10
                                         * Enable/Disable debug logging
                                        #define DEBUG
                                        #ifdef __Raspberry_Pi
                                                #define vsnprintf_P vsnprintf
                                                #define snprintf_P snprintf
                                                #define PSTR(x) (x)
                                                #define printf_P printf
                                                #define strlen_P strlen
                                        pi@Domoticz3:~/Raspberry$ make clean
                                        rm -rf MyGateway MySensor MyMessage PiEEPROM PiGateway PiGatewaySerial MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGateway.o PiGatewaySerial.o
                                        pi@Domoticz3:~/Raspberry$ make all
                                        g++ -c -o MyGateway.o MyGateway.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                                        g++ -c -o MySensor.o MySensor.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                                        g++ -c -o MyMessage.o MyMessage.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                                        g++ -c -o PiEEPROM.o PiEEPROM.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                                        g++ -c -o PiGateway.o PiGateway.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                                        g++ -o PiGateway MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGateway.o -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24 -lrf24-bcm
                                        g++ -c -o PiGatewaySerial.o PiGatewaySerial.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                                        g++ -o PiGatewaySerial MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGatewaySerial.o -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24 -lrf24-bcm -lutil
                                        pi@Domoticz3:~/Raspberry$ sudo reboot
                                        Broadcast message from pi@Domoticz3 on pts/1 (Mon 2016-04-11 12:12:17 CEST):
                                        The system is going down for reboot NOW!
                                        ______                      _   _
                                        |  _  \                    | | (_)
                                        Last login: Mon Apr 11 12:10:24 2016 from 192.168.1.34
                                        Monday, 11 April 2016, 12:12:45 pm CEST
                                        Uptime.............: 0 days, 00h00m25s
                                        Memory.............: 770952kB (Free) / 948056kB (Total)
                                        Load Averages......: 0.59, 0.16, 0.05 (1, 5, 15 min)
                                        Running Processes..: 100
                                        pi@Domoticz3:~$ ls
                                        bash_scripts  domoticz  Dropbox-Uploader  Raspberry  RF24
                                        pi@Domoticz3:~$ sudo /etc/init.d/PiGatewaySerial start
                                        [ ok ] Starting PiGatewaySerial (via systemctl): PiGatewaySerial.service.
                                        pi@Domoticz3:~$ sudo ln -s /dev/ttyMySensorsGateway /dev/ttyUSB20
                                        ln: failed to create symbolic link ‘/dev/ttyUSB20’: File exists
                                        pi@Domoticz3:~$ sudo /usr/local/sbin/PiGatewaySerial
                                        Created PTY '/dev/pts/2'
                                        Clock Speed      = 8 Mhz
                                        RX_ADDR_P0-1     = 0xa8a8e
                                        RX_ADDR_P2-5     = 0xff 0xc4
                                        TX_ADDR          = 0xa8a8e1fc07
                                        EN_AA            = 0x3b
                                        EN_RXADDR        = 0x06
                                        RF_CH            = 0x4c
                                        RF_SETUP         = 0x23
                                        CONFIG           = 0x0e
                                        Data Rate        = 250KBPS
                                        Model            = nRF24L01+
                                        PA Power         = PA_LOW
                                        read: 5-5-5 s=5,c=5,t=5,pt=0,l=0:
                                        version mismatch
                                        ^CReceived SIGINT
                                        Exiting...
                                        pi@Domoticz3:~$
                                        mfalkviddM J 2 Replies Last reply
                                          Still 0x4c eq. 76
                                          ______                      _   _
                                          |  _  \                    | | (_)
                                          #ifndef MyConfig_h
                                          #define MyConfig_h
                                          #define DEBUG
                                                  #define PSTR(x) (x)
                                          ______                      _   _
                                          |  _  \                    | | (_)
                                          pi@Domoticz3:~$ ls
                                          Clock Speed      = 8 Mhz
                                          EN_AA            = 0x3b
                                          EN_RXADDR        = 0x06
                                          RF_CH            = 0x4c
                                          RF_SETUP         = 0x23
                                          CONFIG           = 0x0e
                                          Data Rate        = 250KBPS
                                          Model            = nRF24L01+
                                          PA Power         = PA_LOW
                                          version mismatch
                                          ^CReceived SIGINT
                                          Exiting...
                                          pi@Domoticz3:~$
                                          @Sander-Stolk I don't see a new make install in your output. Did you miss that or is the output just not included?
                                          make all compiles the code. The result is a binary file in the Raspberry folder
                                          make install copies the binary (and some scripts I think) from the Raspberry folder to the system folders.
                                          12.5k
