  3. Step-by-step procedure to connect the NRF24L01+ to the GPIO pins and use the Raspberry as a Serial Gateway (MySensors 1.x)
nrf24raspberry piraspberryraspberry nrf24l01 gpiogateway
168 Posts 47 Posters 212.9k Views 36 Watching
  • mfalkviddM
    Yes it is. See the section under
    COMPILING THE GATEWAY
    also, you ran sudo ./PiGatewaySerial instead of sudo /usr/local/sbin/PiGatewaySerial described in the instructions.
    • mfalkviddM
      I have added a
      TROUBLESHOOTING
      section in the original post to cover for this error. Hopefully it can help if someone else makes the same mistake.
      • micahM
        micahM
        micah
        Any thoughts on making a version for the 2.0 dev branch?
        I recently switched my in-progress builds to 2.0 and am in the process of "trying" to get my Raspberry Pi2 setup with OpenHab and Mosquito. And the idea of not having to have an ethernet gateway arduino in the mix is appealing to me.
        I would do it myself but I probably only have 3.275% of the required knowledge at this point
        • mfalkviddM
          I'm unfortunately at about the same level as you. I can compile stuff and do basic troubleshooting, but merging the dev branch with the gateway code is way out of my league.
          micahM 1 Reply Last reply
            micahM
            micahM
            micah
            There is no way you are at 3.275% knowledge like me... I've seen many of your posts on here and you are at least a 4.532%... lol.... no honestly I've liked your posts and you seem very knowledgeable. You've got to be at least a 84.5% ;)
            • Sander StolkS
              Sander StolkS
              Sander Stolk
              Can somebody tell me how to change the channel after compiling and using the Gateway for a couple of days?
              Changing the channel in MyConfig.h in the dir Raspberry doesnt bother even after a reboot.
              Still 0x4c channel / 76 when I run the PiSerialGateway program.
              alexsh1A 1 Reply Last reply
              • Sander StolkS Sander Stolk
                alexsh1A
                alexsh1A
                alexsh1
                Did you recompile the code after changing the channel?
                Sander StolkS 1 Reply Last reply
                • alexsh1A alexsh1
                  Sander StolkS
                  Sander StolkS
                  Sander Stolk
                  wrote on last edited by Sander Stolk
                  #92
                  @alexsh1 I did this after changeing the channel in MyConfig.h: make all && sudo make install
                  Rebooted after that but no luck
                  • mfalkviddM
                    That should be sufficient but you could see if running make clean before make all helps.
                      Sander StolkS
                      Sander StolkS
                      Sander Stolk
                      #94
                      @mfalkvidd I did the make clean and the make install and rebooted.
                      Still 0x4c eq. 76
                      Using username "pi".
                      Server refused our key
                      pi@192.168.1.14's password:
                      ______                      _   _
                      |  _  \                    | | (_)
                      | | | |___  _ __ ___   ___ | |_ _  ___ ____
                      | | | / _ \| '_ ` _ \ / _ \| __| |/ __|_  /
                      | |/ / (_) | | | | | | (_) | |_| | (__ / /
                      |___/ \___/|_| |_| |_|\___/ \__|_|\___/___|
                      Last login: Sat Apr  9 18:41:17 2016 from 192.168.1.34
                      Monday, 11 April 2016, 12:10:24 pm CEST
                      Linux 4.1.18-v7+ armv7l GNU/Linux
                      Uptime.............: 1 days, 17h29m13s
                      Memory.............: 520336kB (Free) / 948056kB (Total)
                      Load Averages......: 0.00, 0.01, 0.05 (1, 5, 15 min)
                      Running Processes..: 97
                      IP Addresses.......: 192.168.1.14
                      pi@Domoticz3:~$ cd Raspberry/
                      pi@Domoticz3:~/Raspberry$ cat MyConfig.h
                       The MySensors library adds a new layer on top of the RF24 library.
                       It handles radio network routing, relaying and ids.
                       Created by Henrik Ekblad <henrik.ekblad@gmail.com>
                       12/10/14 - Ported to Raspberry Pi by OUJABER Mohamed <m.oujaber@gmail.com>
                      #ifndef MyConfig_h
                      #define MyConfig_h
                       * Configure Sensor Network
                      #define RF24_CHANNEL       111             //RF channel for the sensor net, 0-127
                      #define RF24_DATARATE      RF24_250KBPS   //RF24_250KBPS for 250kbs, RF24_1MBPS for 1Mbps, or RF24_2MBPS for 2Mbps
                      #define RF24_PA_LEVEL      RF24_PA_MAX    //Sensor PA Level == RF24_PA_MIN=-18dBm, RF24_PA_LOW=-12dBm, RF24_PA_HIGH=-6dBM, and RF24_PA_MAX=0dBm
                      #define RF24_PA_LEVEL_GW   RF24_PA_MAX  //Gateway PA Level, defaults to Sensor net PA Level.  Tune here if using an amplified nRF2401+ in your gateway.
                      #define BASE_RADIO_ID      ((uint64_t)0xA8A8E1FC00LL) // This is also act as base value for sensor nodeId addresses. Change this (or channel) if you have more than one sensor network.
                      // MySensors online examples defaults
                      #define DEFAULT_CE_PIN 9
                      #define DEFAULT_CS_PIN 10
                       * Enable/Disable debug logging
                      #define DEBUG
                      #ifdef __Raspberry_Pi
                              #define vsnprintf_P vsnprintf
                              #define snprintf_P snprintf
                              #define PSTR(x) (x)
                              #define printf_P printf
                              #define strlen_P strlen
                      pi@Domoticz3:~/Raspberry$ make clean
                      rm -rf MyGateway MySensor MyMessage PiEEPROM PiGateway PiGatewaySerial MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGateway.o PiGatewaySerial.o
                      pi@Domoticz3:~/Raspberry$ make all
                      g++ -c -o MyGateway.o MyGateway.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                      g++ -c -o MySensor.o MySensor.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                      g++ -c -o MyMessage.o MyMessage.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                      g++ -c -o PiEEPROM.o PiEEPROM.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                      g++ -c -o PiGateway.o PiGateway.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                      g++ -o PiGateway MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGateway.o -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24 -lrf24-bcm
                      g++ -c -o PiGatewaySerial.o PiGatewaySerial.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                      g++ -o PiGatewaySerial MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGatewaySerial.o -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24 -lrf24-bcm -lutil
                      pi@Domoticz3:~/Raspberry$ sudo reboot
                      Broadcast message from pi@Domoticz3 on pts/1 (Mon 2016-04-11 12:12:17 CEST):
                      The system is going down for reboot NOW!
                      ______                      _   _
                      |  _  \                    | | (_)
                      Last login: Mon Apr 11 12:10:24 2016 from 192.168.1.34
                      Monday, 11 April 2016, 12:12:45 pm CEST
                      Uptime.............: 0 days, 00h00m25s
                      Memory.............: 770952kB (Free) / 948056kB (Total)
                      Load Averages......: 0.59, 0.16, 0.05 (1, 5, 15 min)
                      Running Processes..: 100
                      pi@Domoticz3:~$ ls
                      bash_scripts  domoticz  Dropbox-Uploader  Raspberry  RF24
                      pi@Domoticz3:~$ sudo /etc/init.d/PiGatewaySerial start
                      [ ok ] Starting PiGatewaySerial (via systemctl): PiGatewaySerial.service.
                      pi@Domoticz3:~$ sudo ln -s /dev/ttyMySensorsGateway /dev/ttyUSB20
                      ln: failed to create symbolic link ‘/dev/ttyUSB20’: File exists
                      pi@Domoticz3:~$ sudo /usr/local/sbin/PiGatewaySerial
                      Starting PiGatewaySerial...
                      Protocol version - 1.4
                      Created PTY '/dev/pts/2'
                      Gateway tty: /dev/ttyMySensorsGateway
                      ================ SPI Configuration ================
                      CSN Pin          = CE0 (PI Hardware Driven)
                      CE Pin           = Custom GPIO25
                      Clock Speed      = 8 Mhz
                      ================ NRF Configuration ================
                      STATUS           = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
                      RX_ADDR_P0-1     = 0xa8a8e
                      RX_ADDR_P2-5     = 0xff 0xc4
                      TX_ADDR          = 0xa8a8e1fc07
                      RX_PW_P0-6       = 0x20 0x20 0x20 0x00 0x00 0x00
                      EN_AA            = 0x3b
                      EN_RXADDR        = 0x06
                      RF_CH            = 0x4c
                      RF_SETUP         = 0x23
                      CONFIG           = 0x0e
                      DYNPD/FEATURE    = 0x3f 0x06
                      Data Rate        = 250KBPS
                      Model            = nRF24L01+
                      CRC Length       = 16 bits
                      PA Power         = PA_LOW
                      read: 5-5-5 s=5,c=5,t=5,pt=0,l=0:
                      version mismatch
                      ^CReceived SIGINT
                      Exiting...
                      pi@Domoticz3:~$
                      mfalkviddM J 2 Replies Last reply
                        Still 0x4c eq. 76
                        ______                      _   _
                        |  _  \                    | | (_)
                        #ifndef MyConfig_h
                        #define MyConfig_h
                        #define DEBUG
                                #define PSTR(x) (x)
                        ______                      _   _
                        |  _  \                    | | (_)
                        pi@Domoticz3:~$ ls
                        Clock Speed      = 8 Mhz
                        EN_AA            = 0x3b
                        EN_RXADDR        = 0x06
                        RF_CH            = 0x4c
                        RF_SETUP         = 0x23
                        CONFIG           = 0x0e
                        Data Rate        = 250KBPS
                        Model            = nRF24L01+
                        PA Power         = PA_LOW
                        version mismatch
                        ^CReceived SIGINT
                        Exiting...
                        pi@Domoticz3:~$
                        @Sander-Stolk I don't see a new make install in your output. Did you miss that or is the output just not included?
                        make all compiles the code. The result is a binary file in the Raspberry folder
                        make install copies the binary (and some scripts I think) from the Raspberry folder to the system folders.
                        • Sander StolkS
                          Sander StolkS
                          Sander Stolk
                          Ok here's the deal to change the channel or other settings:
                          cd Raspberry
                          make clean
                          make all
                          sudo make install
                          Done!
                          • Tore André RosanderT
                            Tore André Rosander
                            wrote on last edited by Tore André Rosander
                            #97
                            Does anyone know what this error is about?
                            RPi2, NRF24l01, OSMC (Debian jessie), Domoticz v3.5051.
                            osmc@osmc:~/Raspberry$ sudo make install
                            Installing PiGatewaySerial to /usr/local/sbin
                            Installing PiGateway to /usr/local/sbin
                            Installing initscripts to /etc/init.d
                            Installing syslog config to /etc/rsyslog.d
                            Failed to restart rsyslog.service: Unit rsyslog.service failed to load: No such file or directory.
                            Makefile:79: recipe for target 'install-initscripts' failed
                            make: *** [install-initscripts] Error 6
                            I can run the gateway even with the error, i can also add it to Domoticz and send/receive data.
                            But after a few minutes i get a massive error in domoticz saying "(24) Too many files open" on every logentry and my domoticz loose connection to the Logitech mediaserver, remote Kodi hardware, mqtt server etc.
                            osmc@osmc:~/Raspberry$ sudo ./PiGatewaySerial
                            Clock Speed      = 8 Mhz
                            RX_ADDR_P0-1     = 0xa8a8e1fc00 0xa8a8e1fc00
                            RX_ADDR_P2-5     = 0xff 0xc4 0xc5 0xc6
                            TX_ADDR          = 0xa8a8e1fc02
                            EN_AA            = 0x3b
                            EN_RXADDR        = 0x06
                            RF_CH            = 0x4c
                            RF_SETUP         = 0x23
                            CONFIG           = 0x0e
                            Data Rate        = 250KBPS
                            Model            = nRF24L01+
                            PA Power         = PA_LOW
                            • C
                              C
                              cingolanifede
                              Hi, is signing supported using this library? thanks.
                              • C cingolanifede
                                @cingolanifede the Raspberry Pi gateway does not support signing.
                                • B
                                  B
                                  BikeDan
                                  I'm looking for some help in getting "PiGatewaySerial" running properly. I am having no issue running "PiGateway" and receiving all data from a counter node I'm using for testing. When I try to run "PiGatewaySerial", only intermittent data appears. For this example, I have my counter sending increasing integers at 1 second intervals, and receives fewer than 1 in 25 through the "PiGatewaySerial" script. I previously had this working reliably on a RPi2, reading in the tty output and logging it to a file. Now, I cannot repeat that on either that device, nor the current RPi B+ I'm working with. I'm sure there's some basic setting that I'm missing, but I can't seem to figure it out. Thanks!
                                  An example of "PiGateway" correctly receiving all messages:
                                  pi@raspberrypi:/dev/pts $ sudo /usr/local/sbin/PiGateway
                                  Starting Gateway...
                                  Clock Speed	 = 8 Mhz
                                  TX_ADDR		 = 0xe7e7e7e7e7
                                  EN_AA		 = 0x3b
                                  EN_RXADDR	 = 0x06
                                  RF_CH		 = 0x4c
                                  RF_SETUP	 = 0x23
                                  CONFIG		 = 0x0e
                                  Data Rate	 = 250KBPS
                                  Model		 = nRF24L01+
                                  PA Power	 = PA_LOW
                                  [CALLBACK]0;0;3;0;14;Gateway startup complete.
                                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:906
                                  [CALLBACK]0;33;1;0;38;906
                                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:907
                                  [CALLBACK]0;33;1;0;38;907
                                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:908
                                  [CALLBACK]0;33;1;0;38;908
                                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:909
                                  [CALLBACK]0;33;1;0;38;909
                                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:910
                                  [CALLBACK]0;33;1;0;38;910
                                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:911
                                  [CALLBACK]0;33;1;0;38;911
                                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:912
                                  [CALLBACK]0;33;1;0;38;912
                                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:913
                                  [CALLBACK]0;33;1;0;38;913
                                  an example of "PiGatewaySerial" missing most messages:
                                  pi@raspberrypi:/dev/pts $ sudo /usr/local/sbin/PiGatewaySerial
                                  Created PTY '/dev/pts/1'
                                  Clock Speed	 = 8 Mhz
                                  EN_AA		 = 0x3b
                                  EN_RXADDR	 = 0x06
                                  RF_CH		 = 0x4c
                                  RF_SETUP	 = 0x23
                                  CONFIG		 = 0x0e
                                  Data Rate	 = 250KBPS
                                  Model		 = nRF24L01+
                                  PA Power	 = PA_LOW
                                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:301
                                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:302
                                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:303
                                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:328
                                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:353
                                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:378
                                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:403
                                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:428
                                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:454
                                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:479
                                  read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:504
                                  I'm running a RPi B+, NRF24l01+, on a clean install of Jessie, and using only a few percent of the CPU power.
                                  • rmtuckerR
                                    rmtuckerR
                                    rmtucker
                                    I have been thinking about giving this a try But:-
                                    The Raspberry port is using protocol version 1.4.
                                    Do the sensors also have to use version 1.4?
                                    • rmtuckerR rmtucker
                                      GertSandersG
                                      GertSandersG
                                      GertSanders
                                      @rmtucker
                                      No, the sensors can be running 1.5 or 2.0-beta, the PI will run a 1.4 version.
                                      The only thing not supported by the PiGateway is message signing.
                                      But I have a mix of sensors in 1.5, 1.6-beta and 2.0-beta in my home network, so it certainly works.
                                      rmtuckerR 1 Reply Last reply
                                      • GertSandersG GertSanders
                                        @rmtucker
                                        rmtuckerR
                                        rmtuckerR
                                        rmtucker
                                        @GertSanders
                                        Is it best to start with a blank jessie image and manually install/compile domoticz or just use the domoticz sd image?
                                        The latter would be the easiest for me because i am useless with the CLI but if the first method is best??
                                        • AnticimexA
                                          AnticimexA
                                          Anticimex
                                          Adding support for signing on a pi gw should just be a matter of implementing random number generation and use software signing. With slight modification in the software signing backend as it assumes Arduino api:s for obtaining a seed for the rng.
