  3. RFID Garage door opener
47 Posts 23 Posters 42.7k Views 26 Watching
  • Lawrence HelmL Lawrence Helm
    very cool, might have a go at some stage to try and use the nfc variant... So that you can open it with your phone http://www.aliexpress.com/item/Free-shipping-PN532-NFC-RFID-module-User-Kits-for-Arduino-compatible/2009097698.html?spm=2114.01020208.3.1.piLmyG&ws_ab_test=searchweb201556_9_79_78_77_80,searchweb201644_5,searchweb201560_6
    E
    E
    ericvdb
    Well, I have that NFC reader, and I also have 2 Huawei G8 phones that have NFC build in. They both have the same NFC UID (1234), so distinguishing who opened the door is a problem. Even worse, a google search revealed that most phones have the same 1234 UID configured, which means that anyone with a NFC enabled phone can open your door!!!
    I still have to find a way to change that UID on the phone, or add extra NFC tags into the phone.
    • C
      C
      cyberfilou
      wrote on last edited by cyberfilou
      Hello.
      I have a problemm.
      The rfid don't store the card.
      If power off, all delete.
      What is the problem.
      Thx
      • DannyMD
        DannyMD
        DannyM
        Hi @BartE,
        Works great, but I want to let the masterkey trigger a second alarm, what way should I think; I have tried to let the mastercard open a second relay, but it didn't work. Maybe I should use a second programmed key lets say personkey and trigger on that? Can you give me some directions?
        Thanks Danny
        BartEB 1 Reply Last reply
        • DannyMD DannyM
          Hi @BartE,
          Thanks Danny
          BartEB
          BartEB
          BartE
          @DannyM With this sketch a second relay (on pin 3) is controlled by the master-key
          The sketch should work but i did not test it.
           * This is a MFRC522 library example; see https://github.com/miguelbalboa/rfid
           * for further details and other examples.
           * NOTE: The library file MFRC522.h has a lot of useful info. Please read it.
           * Released into the public domain.
           * Example sketch/program showing how to read data from a PICC (that is: a RFID
           * Tag or Card) using a MFRC522 based RFID Reader on the Arduino SPI interface.
           * When the Arduino and the MFRC522 module are connected (see the pin layout
           * below), load this sketch into Arduino IDE then verify/compile and upload it.
           * To see the output: use Tools, Serial Monitor of the IDE (hit Ctrl+Shft+M).
           * When you present a PICC (that is: a RFID Tag or Card) at reading distance
           * of the MFRC522 Reader/PCD, the serial output will show the ID/UID, type and
           * any data blocks it can read. Note: you may see "Timeout in communication"
           * messages when removing the PICC from reading distance too early.
           * If your reader supports it, this sketch/program will read all the PICCs
           * presented (that is: multiple tag reading). So if you stack two or more
           * PICCs on top of each other and present them to the reader, it will first
           * output all details of the first and then the next PICC. Note that this
           * may take some time as all data blocks are dumped, so keep the PICCs at
           * reading distance until complete.
           * Typical pin layout used:
           *             MFRC522      Arduino       Arduino   Arduino    Arduino          Arduino
           *             Reader/PCD   Uno           Mega      Nano v3    Leonardo/Micro   Pro Micro
           * Signal      Pin          Pin           Pin       Pin        Pin              Pin
           * RST/Reset   RST          9             5         D9         RESET/ICSP-5     RST
           * SPI SS      SDA(SS)      10            53        D10        10               10
           * SPI MOSI    MOSI         11 / ICSP-4   51        D11        ICSP-4           16
           * SPI MISO    MISO         12 / ICSP-1   50        D12        ICSP-1           14
           * SPI SCK     SCK          13 / ICSP-3   52        D13        ICSP-3           15
           RFID Garagedoor opener by Bart Eversdijk
           This sketch is to open a Garage door with an mifare RIFD-tag
            For an Arduino Nano v3
            Connection wiring :
              - nrf24l01+ as descibed on the MySensors website
              - MFRC522 reader/writer as described above EXCEPT for pin D9 and D10:  connect RST i.s.o. pin D9 to pin D7 and connect SDA(SS) i.s.o. pin D10 to pin D8
              - LED with 470ohm resistor between GMD and pin A3
              - push button between GND and pin D5
              - 5v relays coil between GND and  pin D4 -> switch pins of the relays should be connected in parallel with your garage door push button.
            Features:
            This project can record up to 18 RFID-"tags"
            These card IDs are stored in to EEPROM by keeping them next to the RFID reader when the system in program mode. (Slow blinking LED) When a card is accepted as new card the LED will blink fast for a short time.
            To keep the master-tags (choose your own) next to the RFID reader when pressing the push button. To clear all cards (except the master card) press the push button in program mode for 6 seconds. The LED will now fast blink for a couple of seconds.
            Your garage your can be opened by keep a registered RFID tag next to the reader or by clicking the open icon on lock node presented by this plugin.
            By by-passing the alarm node presented by this plug in the RFID will be temporarily disabled.
            When an incorrect (not registered) RFID tag is scanned the alarm is triggered to detect illegal scan attempts
          #include <MFRC522.h>
          #define RF_INIT_DELAY   125
          #define ONE_SEC         1000
          #define MAX_CARDS       18
          #define PROG_WAIT       10
          #define HEARTBEAT       10
          #define BAUD            115200
          /*Pin definitions*/
          #define LED_PIN         A3
          #define SECONDRELAY     3
          #define GARAGEPIN       4
          #define SWITCH_PIN      5
          #define RST_PIN         7       //  MFRC
          #define SS_PIN          8       //  MFRC
          MFRC522      mfrc522(SS_PIN, RST_PIN);  // Create MFRC522 instance
          MFRC522::Uid olduid;
          MFRC522::Uid masterkey = { 10, {0,0,0,0, 0,0,0,0, 0,0 },  0 };
          byte       countValidCards  = 0;
          MFRC522::Uid validCards[MAX_CARDS];
          void       ShowCardData(MFRC522::Uid* uid);
          bool       sameUid(MFRC522::Uid* old, MFRC522::Uid* check);
          void       copyUid(MFRC522::Uid* src, MFRC522::Uid* dest);
          bool       isValidCard(MFRC522::Uid* uid);
          int        releasecnt = 0;
          #define    CHILD_ID_ALARM    1
          #define    CHILD_ID_LOCK     2
          #define    CHILD_ID_LOCK2    3
          MySensor   gw;
          Bounce     debouncer = Bounce();
          int        oldSwitchValue=-1;
          int        switchValue = 0;
          long       timer = -1;
          bool       programmode = false;
          bool       ledon;
          int        programTimer = 0;
          bool       armed = true;
          unsigned long lastTime = 0;
          MyMessage  lockMsg(CHILD_ID_LOCK,          V_LOCK_STATUS);
          MyMessage  lock2Msg(CHILD_ID_LOCK2,          V_LOCK_STATUS);
          MyMessage  lockArmMsg(CHILD_ID_ALARM,      V_ARMED);
          MyMessage  wrongMsg(CHILD_ID_ALARM,        V_TRIPPED);
                  Serial.begin(BAUD);     // Initialize serial communications with the PC
                  pinMode(GARAGEPIN, OUTPUT);     // Initialise in/output ports
                  pinMode(SECONDRELAY, OUTPUT);     // Initialise in/output ports
                  // Make sure MFRC will be disabled on the SPI bus
                  pinMode(RST_PIN, OUTPUT);
                  digitalWrite(RST_PIN, LOW);
                  pinMode(SS_PIN, OUTPUT);
                  digitalWrite(SS_PIN, LOW);
                  pinMode(LED_PIN, OUTPUT);
                  digitalWrite(LED_PIN, LOW);
                  // Setup the button
                  pinMode(SWITCH_PIN, INPUT_PULLUP);
                  debouncer.attach(SWITCH_PIN);
                  debouncer.interval(5);
                  // Init mysensors library
                  gw.begin(incomingMessage, 5);
                  gw.sendSketchInfo("RFID Garage", "1.2"); delay(RF_INIT_DELAY);
                  gw.present(CHILD_ID_LOCK, S_LOCK);      delay(RF_INIT_DELAY);
                  gw.present(CHILD_ID_LOCK2, S_LOCK);      delay(RF_INIT_DELAY);
                  gw.present(CHILD_ID_ALARM, S_MOTION);   delay(RF_INIT_DELAY);
                  recallEeprom();
                  // Init MFRC RFID sensor
                  SPI.begin();            // Init SPI bus
                  mfrc522.PCD_Init();     // Init MFRC522
                  ShowReaderDetails();            // Show details of PCD - MFRC522 Card Reader details
                  gw.send(lockArmMsg.set(armed));
                  Serial.println(F("Init done..."));
                  timer++;
                  delay(HEARTBEAT);
                  debouncer.update();
                  // Get the update value
                  int switchValue = debouncer.read();
                  if (switchValue != oldSwitchValue) {
                    // Send in the new value
                    Serial.print (F("Switch "));
                    Serial.println (switchValue);
                    if (switchValue && programmode) {
                         lastTime     = millis() / 1000;
                    if (!switchValue && programmode && lastTime > 0) {
                         if ( (millis() / 1000) - lastTime > 3) {
                              Serial.println(F("Reset all cards"));
                              blinkFast(50);
                            Serial.println(F("Program off"));
                            storeEeprom();
                    if (!switchValue)   {
                        programTimer = 0;
                    oldSwitchValue = switchValue;
                  if (programmode && ((timer % (ONE_SEC / HEARTBEAT)) == 0 ))  {
                      ledon = !ledon;
                      digitalWrite(LED_PIN, ledon);
                      programTimer++;
                      // Stop program mode after 20 sec inactivity
                      if (programTimer > PROG_WAIT)  {
                         digitalWrite(LED_PIN, false);
                         Serial.println(F("Program expired"));
                  if ((timer % (200 / HEARTBEAT)) == 0 )   {
                       // Look for new cards
                       if ( ! mfrc522.PICC_IsNewCardPresent()) {
                            if (releasecnt > 0)   {
                                releasecnt--;
                                if (!releasecnt)  {
                                    olduid.size = 0;
                                    Serial.println(F("release"));
                      return;
                      releasecnt = 5;
                     // Select one of the cards
                     if ( ! mfrc522.PICC_ReadCardSerial()) {
                        return;
                     // Dump debug info about the card; PICC_HaltA() is automatically called
                     //mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
                     if (!olduid.size || !sameUid(&(mfrc522.uid), &olduid))  {
                          ShowCardData(&(mfrc522.uid));
                          copyUid(&(mfrc522.uid), &olduid);
                          if ( isValidCard(&olduid) )   {
                               OpenDoor(programmode);
                          } else  {
                             if (sameUid(&(mfrc522.uid), &masterkey)) {
                                 // Only switch in program mode when mastercard is found AND the program button is pressed
                                 if (switchValue)  {
                                   Serial.println(F("Program mode"));
                                   programmode = true;
                                   programTimer = 0;
                                   lastTime     = 0;
                                   OpenDoor2(programmode);
                                 if (programmode) {
                                   Serial.println(F("new card"));
                                   programTimer = 0;
                                   if (countValidCards < MAX_CARDS)
                                      // Add card to list...
                                      copyUid(&(mfrc522.uid), &validCards[countValidCards]);
                                      countValidCards++;
                                      blinkFast(15);
                                   Serial.println(F("Invalid card"));
                                   if (armed) {
                                      gw.send(wrongMsg.set(1));
                                      delay(2000);
                                      gw.send(wrongMsg.set(0));
              Serial.print(F("Card UID:"));
              for (byte i = 0; i < uid->size; i++) {
                  if(uid->uidByte[i] < 0x10) {
                      Serial.print(F(" 0"));
                      Serial.print(F(" "));
                  Serial.print(uid->uidByte[i], HEX);
              Serial.println();
              dest->size = src->size;
              dest->sak  = src->sak;
              for (byte i = 0; i < src->size; i++) {
              dest->uidByte[i] = src->uidByte[i];
              if (old->size != check->size) {
                 return false;
              for (byte i = 0; i < old->size; i++) {
                  if (old->uidByte[i] != check->uidByte[i]) {
                      return false;
              return true;
                for (byte i = 0; i < countValidCards; i++)  {
                    if (validCards[i].size != uid->size)  {
                    for (int j = 0; j < uid->size; j++) {
                        if (validCards[i].uidByte[j] != uid->uidByte[j])  {
                        if (j == (uid->size - 1)) {
                            return true;
                return false;
          void storeEeprom()
              byte address = 0;
              gw.saveState(address++, countValidCards);
                 gw.saveState(address++, validCards[i].size);
                 for (byte j = 0; j < 10; j++) {
                    gw.saveState(address++, validCards[i].uidByte[j]);
          void recallEeprom()
              byte address = 0;
              countValidCards = gw.loadState(address++);
              if (countValidCards > MAX_CARDS) {
                 Serial.println(F("Not a valid EEPROM reading set to default"));
                 storeEeprom();
                 return;
                 validCards[i].size = gw.loadState(address++);
                    validCards[i].uidByte[j] = gw.loadState(address++);
          void blinkFast(int times)
              for (int i = 0; i < times; i++) {
                 ledon = !ledon;
                 delay(100);
          void OpenDoor(bool fakeOpen)
              Serial.println(F("Open door!"));
              gw.send(lockMsg.set(false));
              if (!fakeOpen) {
                digitalWrite(LED_PIN, HIGH);
                digitalWrite(GARAGEPIN, HIGH);
              delay(1000);
              if (!fakeOpen) {
                digitalWrite(GARAGEPIN, LOW);
              gw.send(lockMsg.set(true));
          void OpenDoor2(bool fakeOpen)
              Serial.println(F("Open door 2!"));
              gw.send(lock2Msg.set(false));
              if (!fakeOpen) {
                digitalWrite(SECONDRELAY, HIGH);
              delay(1000);
              if (!fakeOpen) {
                digitalWrite(SECONDRELAY, LOW);
              gw.send(lock2Msg.set(true));
          void ShowReaderDetails() {
              // Get the MFRC522 software version
              byte v = mfrc522.PCD_ReadRegister(mfrc522.VersionReg);
              Serial.print(F("MFRC522 Software Version: 0x"));
              Serial.print(v, HEX);
              if (v == 0x91) {
                  Serial.print(F(" = v1.0"));
                  } else if (v == 0x92) {
                  Serial.print(F(" = v2.0"));
                  Serial.print(F(" (unknown)"));
              Serial.println("");
                  // When 0x00 or 0xFF is returned, communication probably failed
              if ((v == 0x00) || (v == 0xFF)) {
                  Serial.println(F("WARNING: Communication failure, is the MFRC522 properly connected?"));
          void incomingMessage(const MyMessage &message)
             if (message.type == V_LOCK_STATUS) {
               // Change relay state
               if (!message.getBool())  {
                  switch (message.sensor)
                     case CHILD_ID_LOCK:
                        OpenDoor(false);
                     case CHILD_ID_LOCK2:
                        OpenDoor2(false);
               Serial.print(F("Lock:  "));
               Serial.print(F(" status: "));
               if (message.type == V_ARMED)  {
                 armed = message.getBool();
                 Serial.print(F("Arm status: "));
                 Serial.print(F("Incoming msg type: "));
                 Serial.print(message.type);
                 Serial.print(F(" id: "));
                 Serial.print(F(" content: "));
            SVLoneStar
            Hello BartE,
            I have the same issue as cyberfilou...
            Sketch works beautifully...but if I power off the Arduino (Pro Mini in my case) and power it on again, all stored cards are gone. Any ideas what could cause this, and how to prevent it?
            Thx a lot, Stefan
            • S SVLoneStar
              Hello BartE,
              Thx a lot, Stefan
              BartEB
              BartEB
              BartE
              @SVLoneStar That is weird.
              Do you get this message each time you boot the Arduino? "Not a valid EEPROM reading set to default"
              What is the UID size (how many bytes) of the recorded cards?
                SVLoneStar
                Hi BartE - thanks for your reply!
                I do not receive any error regarding invalid EEPROM - not while writing, not at boot time.
                My cards are shown in this format: D4 04 E2 E9
                I register a Master Card like this (and it works until reboot):
                MFRC522::Uid masterkey = { 4, {0xD4,0x04,0xE2,0xE9}, 0 };
                • AnticimexA
                  AnticimexA
                  Anticimex
                  Cool stuff! You probably what some signing in there as well :) would be a shame if someone snooped the open command from your controller and decided to pay a visit.
                  • S SVLoneStar
                    BartEB
                    BartEB
                    BartE
                    @SVLoneStar That should work, did you try the sketch shown in the topic?
                    The function recallEeprom(); reads the EEPROM content and after closing the program mode this function storeEeprom();
                    writes the EEPROM. Please add some debug info (Serial.print) and validate that these functions actually are called on
                    • recallEeprom(); --> on start up
                    • storeEeprom(); --> ending program mode.
                    ChakkieC 2 Replies Last reply
                    • AnticimexA Anticimex
                      BartEB
                      BartEB
                      BartE
                      @Anticimex yes your right but when i wrote this sketch signing was not in the released branch.
                      • Rod MacPhersonR
                        Rod MacPhersonR
                        Rod MacPherson
                        Nice work. I have yet to pick up an RFID reader to give that part of it a try, but I've modified it a little to have reed sensors for the 2 doors so that I can easily see if the door is open on my phone, and get notifications when the door opens at an unexpected time, like when the controller is set to vacation mode, or at times of night when we would not normally be coming and going.
                        I'll be watching for someone to post up a signing version.
                        Here's my 2 relay, 2 door sensor version.
                         Modified to add door sensors by Rod MacPherson
                          Connection wiring :
                            - MFRC522 reader/writer MOSI, MISO, SCK, 3.3V and GND as they are on the nrf24101+, but connect RST to pin D7 and connect SDA(SS) to pin D8
                            - LED with 470ohm resistor between GND and pin A3
                            - second relay for second door on pin D3
                          Features:
                        #define BAUD            115200
                        /*Pin definitions*/
                        #define LED_PIN         A3
                        #define GARAGEPIN       4
                        #define DOOR_PIN_L  A0  // Arduino Digital I/O pin for button/reed switch
                        #define DOOR_PIN_R  A1  // Arduino Digital I/O pin for button/reed switch
                        int        releasecnt = 0;
                        #define    CHILD_ID_DOOR_L    4
                        #define    CHILD_ID_DOOR_R    5
                        MySensor   gw;
                        Bounce     debouncerDoorR = Bounce();
                        Bounce     debouncerDoorL = Bounce();
                        int oldValueR=-1;
                        int oldValueL=-1;
                        long       timer = -1;
                        bool       ledon;
                        bool       armed = true;
                        MyMessage  doorRmsg(CHILD_ID_DOOR_R, V_TRIPPED);
                        MyMessage  doorLmsg(CHILD_ID_DOOR_L, V_TRIPPED);
                                // Setup the button
                                // Setup the right door sensor
                                pinMode(DOOR_PIN_R,INPUT);
                                // Activate internal pull-up
                                digitalWrite(DOOR_PIN_R,HIGH);
                                debouncerDoorR.attach(DOOR_PIN_R);
                                debouncerDoorR.interval(5);
                                // Setup the left door sensor
                                pinMode(DOOR_PIN_L,INPUT);
                                digitalWrite(DOOR_PIN_L,HIGH);
                                debouncerDoorL.attach(DOOR_PIN_L);
                                debouncerDoorL.interval(5);
                                gw.present(CHILD_ID_DOOR_R, S_DOOR);
                                gw.present(CHILD_ID_DOOR_L, S_DOOR);
                                recallEeprom();
                                timer++;
                                delay(HEARTBEAT);
                                debouncer.update();
                                debouncerDoorL.update();
                                // Get the update value for Left
                                int valueL = debouncerDoorL.read();
                                if (valueL != oldValueL) {
                                   // Send in the new value for Left
                                   gw.send(doorLmsg.set(valueL==HIGH ? 1 : 0));
                                   oldValueL = valueL;
                                debouncerDoorR.update();
                                // Get the update value for Right
                                int valueR = debouncerDoorR.read();
                                if (valueR != oldValueR) {
                                   // Send in the new value for Right
                                   gw.send(doorRmsg.set(valueR==HIGH ? 1 : 0));
                                   oldValueR = valueR;
                                            blinkFast(50);
                                          storeEeprom();
                                  if (!switchValue)   {
                                      programTimer = 0;
                                    ledon = !ledon;
                                    programTimer++;
                                              releasecnt--;
                                              if (!releasecnt)  {
                                                  olduid.size = 0;
                                    return;
                                    releasecnt = 5;
                                      return;
                                        } else  {
                                               if (switchValue)  {
                                                 programmode = true;
                                                 programTimer = 0;
                                                 lastTime     = 0;
                                               if (programmode) {
                                                 programTimer = 0;
                                                    countValidCards++;
                                                    blinkFast(15);
                                                 if (armed) {
                                                    delay(2000);
                            Serial.println();
                               return false;
                                    return false;
                            return true;
                                          return true;
                              return false;
                        void storeEeprom()
                            byte address = 0;
                        void recallEeprom()
                            byte address = 0;
                               storeEeprom();
                               return;
                               ledon = !ledon;
                               delay(100);
                            if (!fakeOpen) {
                            delay(1000);
                            if (!fakeOpen) {
                            if (!fakeOpen) {
                            delay(1000);
                            if (!fakeOpen) {
                            if (v == 0x91) {
                            Serial.println("");
                                   case CHILD_ID_LOCK:
                                      OpenDoor(false);
                                      OpenDoor2(false);
                        • codergirl56C
                          codergirl56C
                          codergirl56
                          Hi @BartE - thanks for putting this together! It has been very helpful.
                          I am working on a project with two wireless MFRC522 modules and RFID Reader. I want to be able to read PICC cards with the RFID reader and send it the UID between the modules. So essentially a more bare version of the code you have written with the garage door opening code. I was wondering if you could help me out in simplifying the code to just reading the UID off the PICC cards and outputting that date between the RCF522 modules.
                          Thanks in advance.
                          • codergirl56C codergirl56
                            Thanks in advance.
                            BartEB
                            BartEB
                            BartE
                            @codergirl56 there are a number of examples in the MFRC522 library which might help you.
                            You can find them here: https://github.com/miguelbalboa/rfid
                            Please feel free to ask questions if the examples does not help you further
                            codergirl56C 1 Reply Last reply
                            • BartEB BartE
                              codergirl56C
                              codergirl56C
                              codergirl56
                              @BartE thanks for getting back to me. I've looked through the examples on the MFRC522 library. I think the main thing I'm struggling with is setting up and initializing the N24L01 module and the RFID on the same arduino uno. My plan is to have one N24L01 and RFID on one arduino module, and a second N24L01 on a second arduino. I want the RFID to read the UID off of PICC cards and be able to wirelessly transmit the UID between the N24L01 modules. I think it's simpler than the code you have written here, but I'm struggling to simplify the code you have to only what I need. Could you possibly walk through what each function in your program is used for? Thanks in advance.
                                BartEB
                                BartEB
                                BartE
                                @codergirl56 Oke i will give it a try:
                                Basic IO pin set up
                                This part initializes the SPI I/O pins used by the RFID reader so it release the SPI bus for thr NFR radio
                                Init LED and button I/O-pin
                                        // Setup the button
                                Init radion module
                                Read eeprom settings
                                        recallEeprom();
                                nit SPI bus for MFRC RFID sensor
                                        timer++;
                                        delay(HEARTBEAT);
                                        debouncer.update();
                                                    blinkFast(50);
                                                  storeEeprom();
                                          if (!switchValue)   {
                                              programTimer = 0;
                                            ledon = !ledon;
                                            programTimer++;
                                                      releasecnt--;
                                                      if (!releasecnt)  {
                                                          olduid.size = 0;
                                            return;
                                            releasecnt = 5;
                                Check if a RFID card is held at the RFID reader if not: skip the rest and start over with loop()
                                              return;
                                Check if this card is the same as the previous loop if not enter the IF loop
                                                } else  {
                                Check if the master card was presented and the button was pressed enter program mode
                                                       if (switchValue)  {
                                                         programmode = true;
                                                         programTimer = 0;
                                                         lastTime     = 0;
                                If not the master card and this card in not known and we're in program mode add this as a new card
                                                       if (programmode) {
                                                         programTimer = 0;
                                                            countValidCards++;
                                                            blinkFast(15);
                                                         if (armed) {
                                                            delay(2000);
                                These are support functions
                                    Serial.println();
                                       return false;
                                            return false;
                                    return true;
                                                  return true;
                                      return false;
                                void storeEeprom()
                                    byte address = 0;
                                void recallEeprom()
                                    byte address = 0;
                                       storeEeprom();
                                       return;
                                       ledon = !ledon;
                                       delay(100);
                                    if (!fakeOpen) {
                                    delay(1000);
                                    if (!fakeOpen) {
                                    if (!fakeOpen) {
                                    delay(1000);
                                    if (!fakeOpen) {
                                    if (v == 0x91) {
                                    Serial.println("");
                                           case CHILD_ID_LOCK:
                                              OpenDoor(false);
                                              OpenDoor2(false);
                                • BartEB BartE
                                  ChakkieC
                                  ChakkieC
                                  Chakkie
                                  @BartE
                                  Hi BartE, I have the same issue regarding tags lost after power off. I run the debug instruction using Serial print as you mentioned. I found out that the storeEeprom line did not run after closing the program mode. I think this is why the tags are lost after power cycle.
                                  send: 210-210-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
                                  send: 210-210-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.4
                                  send: 210-210-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                                  read: 0-0-210 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                  sensor started, id=210, parent=0, distance=1
                                  send: 210-210-0-0 s=255,c=3,t=11,pt=0,l=9,sg=0,st=ok:RFID Lock
                                  send: 210-210-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
                                  send: 210-210-0-0 s=2,c=0,t=19,pt=0,l=0,sg=0,st=ok:
                                  send: 210-210-0-0 s=1,c=0,t=1,pt=0,l=0,sg=0,st=ok:
                                  RecallEeprom
                                  MFRC522 Software Version: 0x92 = v2.0
                                  send: 210-210-0-0 s=1,c=1,t=15,pt=2,l=2,sg=0,st=ok:1
                                  Init done...
                                  Switch 1
                                  Card UID: 26 13 80 41
                                  Invalid card
                                  send: 210-210-0-0 s=1,c=1,t=16,pt=2,l=2,sg=0,st=ok:1
                                  send: 210-210-0-0 s=1,c=1,t=16,pt=2,l=2,sg=0,st=ok:0
                                  release
                                  Card UID: xx xx xx xx
                                  Program mode
                                  release
                                  new card
                                  release
                                  Program expired
                                  Raspberry Pi 2
                                  Domoticz
                                  RFXCOM
                                  ZWAVE Aeon stick
                                  Coming soon Arduino mysensors GW
                                  • BartEB BartE
                                    ChakkieC
                                    ChakkieC
                                    Chakkie
                                    @BartE
                                    I've just solved the issue regarding tags lost after power off.
                                    Simply add the line "StoreEeprom();" after the program mode function
                                                ledon = !ledon;
                                                programTimer++;
                                                   storeEeprom();
                                                   Serial.println(F("Store Card to EEPROM"));  ```
                                    Raspberry Pi 2
                                    Domoticz
                                    RFXCOM
                                    ZWAVE Aeon stick
                                    • ChakkieC Chakkie
                                      @BartE
                                                  ledon = !ledon;
                                                  programTimer++;
                                                     storeEeprom();
                                      BartEB
                                      BartEB
                                      BartE
                                      @Chakkie sorry for the slow response (i was on a pre summer holiday)
                                      Thx for analyzing this report. The fix you did made is not what i meant with program expired.
                                      The idea is that you start program mode by pressing the program button and holding the master card.
                                      And now one can add one or more new RFID cards and when your oke press the program button for a short period to END the program mode and store the new cards.
                                      If you wait too long the program mode will expire and the new cards are NOT stored. Off course you can change this behavior by adding this line as you suggested.
                                      • Michel - ItM
                                        Michel - ItM
                                        Michel - It
                                        wrote on last edited by Michel - It
                                        #25
                                        hello to all guys, I noticed some problems, if the power goes away there is a flaw in the system. I modified the source as needed to me, now you turn the sensor on domoticz when you turn on and off when you turn off. I modified the project to create an alarm homemade I configured via lua script the motion sensors. I mounted on the bell so as to turn on and off when I go out or within the home. thank you all
                                        0_1464953572731_rfidCompreto.jpg 0_1464953579700_rfidmoduloporta-180x180.jpg 0_1464953586849_rfidcentralina-180x180.jpg
                                        • electromakerE
                                          electromakerE
                                          electromaker
                                          Hi Everyone,
                                          I have tested this code http://etabetastudio.blogspot.it/2016/07/tutorial-lettore-rfid-rc522-arduino-idea.html to test RFID RC-522 with Arduino 2009 and all is ok, also to registred RFID card on EEPROM...
                                          I hope to help uo...bye
