  3. Door Sensor / Mini Pro Clone Interrupt
4 Posts 3 Posters 1.4k Views 3 Watching
  • TakeroT
    TakeroT
    Takero
    i have some Trouble with my Door Sensor.
    The Sensor works fine, but if i use the gw.sleep function they don't wake up. I try D2 and D3. Nothing happens. . . .
    Herre is my Sketch:
    #define CHILD_ID 1
    #define CHILD_ID_BATT 3
    #define SENSOR_ID 30
    #define BUTTON_PIN 3
    #define INTERRUPT 1
    #define SLEEP_TIME 600000
    Bounce debouncer = Bounce();
    int oldValue=-1;
    int batterie_check = 0;
    float normaldeltabatt = 0.400;
    float batteriezwischen = 0;
    int interrupt = 1;
    MyMessage msgVolt(CHILD_ID_BATT, V_VOLTAGE);
      analogReference(INTERNAL);
      gw.begin(NULL, SENSOR_ID);
      pinMode(BUTTON_PIN,INPUT);
      gw.sendSketchInfo("WoZi_Window", "1.0");
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      gw.present(CHILD_ID, S_DOOR);
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         oldValue = value;
    //  if (batterie_check >= 30 || batterie_check < 1) {
    //    // get the battery Voltage
    //    int sensorValue = analogRead(BATTERY_SENSE_PIN);
    //    float batteryValue = sensorValue * 0.0033140756302521;
    //    //int batteryPcnt = sensorValue / 10;
    //    batteriezwischen = batteryValue - 2;
    //    //Serial.println(batteriezwischen);
    //    float batteryPcnt = (batteriezwischen/normaldeltabatt) * 100;
    //    Serial.print("Batt: ");
    //    Serial.print(batteryValue);
    //    Serial.println(" V");
    //    gw.send(msgVolt.set(batteryValue, 1));
    //    Serial.print("Battery Prozent: ");
    //    Serial.print(batteryPcnt);
    //    Serial.println(" %");
    //    gw.sendBatteryLevel(batteryPcnt);
    //    batterie_check = 1;
    //  } else {
    //    batterie_check++;
    gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME);
    • TheoLT
      TheoLT
      TheoL
      could you post a schematic you use for the provided sketch? It's a bit hard to tell what's wrong, just by looking at your sketch.
      • mfalkviddM
        This will not affect the functionality of your sketch, but I suggest you change
        to
        gw.sleep(digitalPinToInterrupt(BUTTON_PIN) , CHANGE, SLEEP_TIME);
        and remove
        #define INTERRUPT 1
        to avoid mistakes if you change BUTTON_PIN but forget to change INTERRUPT.
        • TakeroT
          TakeroT
          Takero
          Thanks for help. . . i dont now why but it works now.
          I Think i had an Hardware issues :(
