  3. Vera
  4. one question ! about interference wave !
12 Posts 7 Posters 4.4k Views 4 Watching
  • L LastSamurai
    I am not sure if I really get your question, but sure mysensors (or specificly the NRF24L01+) interferes with anyone else using the same frequency (like all senders do). But I haven't had any problems with any other devices (not even WLAN) and you can always switch the used channel to something else.
    Other devices also interfere with the nodes. I have read in this forum that some users had problem receiving when the microwave was running ;)
    So short answer: yes, but normally it shouldn't really matter.
    R
    R
    Reza
    so if there was same problem can i use change the frequency band ? how do it?
    • mfalkviddM
      If you have a problem it is much more likely that it is related to power and shielding. If you describe the problem we might be able to help you.
      The channel is set in MyConfig.h
      https://github.com/mysensors/Arduino/blob/d7459ae0503feac0b38d3c923b8b16f4faa8e777/libraries/MySensors/MyConfig.h#L116
      R 1 Reply Last reply
        R
        R
        Reza
        thank you <3
        • TRS-80T
          TRS-80T
          TRS-80
          Somewhat related, is anyone aware of a tool that would allow you to visualize (or otherwise look at in any fashion) RF spectrum, without spending an arm and a leg?
          I know I have an app on my Android called Wi-Fi Analyzer, it's very helpful some times in diagnosing overlapping Wi-Fi channels in a crowded apartment building for example.
          I suppose I was just wondering if there was something more generalized to RF and not Wi-Fi channels specifically?
          • OitzuO
            OitzuO
            Oitzu
            @TRS-80 you may want to look at RTL-SDR http://www.rtl-sdr.com/about-rtl-sdr/
            If you just want to scan on the nrf24l01+ channel range, this is maybe enough for you: https://maniacbug.github.io/RF24/scanner_8pde-example.html
            • siklosiS
              siklosiS
              siklosi
              I modified poor man's scanner script so that you can see all 127 channels..
              http://forum.mysensors.org/topic/2454/node-cant-see-gateway-less-than-10m-away/11
              • mfalkviddM
                Yveaux' sniffer might be useful as well
                • TRS-80T
                  TRS-80T
                  TRS-80
                  Thanks for replies guys. Any of these may prove useful in the event of troubleshooting.
                  That RTL-SDR thing looks really cool though! So many different applications! I'm sure I will be picking one up sooner or later, just to play around with...
                  • TRS-80T TRS-80
                    Just a note: The most common RT-SDRs can not receive 2.4GHz (limit is 1.5-2.2GHz depending on chipset) so you can't use that for nrf24l01 signals unfortunately.
                    • D
                      DavidZH
                      A step up in price from the RTL-SDR you'd find the RF-explorer; price from $270.
                      • Hardware with display.
                      • Free (and also payed) software to get a better picture of the situation.
                      • sub-1GHz and 2.4 GHz in the same device.
                      Not affiliated with the company, but I have used one and was pleasantly surprised
