  3. Doubt of components to my project
6 Posts 3 Posters 1.6k Views 3 Watching
  • E
    E
    erangel
    wrote on last edited by erangel
    Hi guys!
    Today I have 1 arduino Uno connected to my RaspberryPi 2 by serial cable. This arduino controls 2 relays for on and off lights of my house. I am using Pidome to manage the system's house.
    Now I want to buy another arduino, to put outside a make some new controls:
    • Turn on/off lights in garden - 1 relay;
    • Turn on/off light in garage - 1 relay;
    • Turn on/off light in wall - 1 relay;
    • Open/Close garage gate - 1 relay;
    • 1 temperature sensor;
    • 1 sensor for measuring power consumption;
    I think about 1 arduino nano to control this things.
    Now my doubt: I think the best option to connect both arduinos X Raspberry is a radio control. I beleive can put a serial gateway with radio in my Uno, connect via USB in my Raspberry, and I put another radio nano - sensor. I believe that the nano and uno can comunicate. Am I correct ? Is it the best choice ? Anybody have another idea ?
    I wait few comments.
    Thank you
    Eduardo
    TheoLT 1 Reply Last reply
    • E erangel
      Hi guys!
      Thank you
      Eduardo
      TheoLT
      TheoLT
      TheoL
      @erangel I think the thing you want to achieve is exactly what MySensors does for you. Also have a look at Domoticz or any of the other Home Automation software that's on this forum. Home Automation is a necessity when you want to control light or other devices.
      Concerning the hardware it depends on personal choices. I'd prefer the ProMini's above a Nano. Much cheaper than a Nano.
      • E
        E
        erangel
        Hi Theol
        , I am testing Domoticz... My problem now it is the status of lamp, it is inverse - when the lamp is on, in Domoticz show off, and vise-versa.
        This week, I will buy the components of arduino, and I will check about the ProMini. I understand my thought now it is correct. ok ?
        Regards,
        Eduardo
        • E erangel
          Hi Theol
          Regards,
          Eduardo
          @erangel are you using the standard relay sketch?
          If so, switch
          #define RELAY_ON 1
          #define RELAY_OFF 0
          to
          #define RELAY_ON 0
          #define RELAY_OFF 1
          • E
            E
            erangel
            Thnak you @mfalkvidd !
            It works!
            • mfalkviddM
              Great! Thanks for reporting back.
