  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 460.5k Views 30 Watching
  • carlierdC
    carlierdC
    carlierd
    I currently testing various bootloader to measure impact on CPU speed on the power consumption.
    I got a lot of nonce error when using 1 MHz configuration.
    Is signing feature possible at 1 MHz ?
    David.
    AnticimexA 1 Reply Last reply
    • carlierdC carlierd
      David.
      AnticimexA
      AnticimexA
      Anticimex
      @carlierd could you specify a bit clearer what you mean by "nonce error"? Signing should work, but the atsha driver is not tested @ 1MHz and might get bad timing. Also, for soft (and hard) signing, if 1MHz is used, performance could degrade to the point that the nonce timeout needs to be increased.
      carlierdC 1 Reply Last reply
      • AnticimexA Anticimex
        carlierdC
        carlierdC
        carlierd
        @Anticimex
        Hello.
        I am using soft signing.
        find parent
        send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
        read: 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
        sensor started, id=255, parent=255, distance=255
        find parent
        read: 0-0-255 s=255,c=3,t=8,pt=1,l=1,sg=0:0
        parent=0, d=1
        req id
        read: 0-0-255 s=255,c=3,t=4,pt=0,l=1,sg=0:9
        send: 9-9-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=fail:1
        read and drop: 9-9-0 s=255,c=3,t=15,pt=2,l=2,sg=0:1
        read: 0-0-9 s=255,c=3,t=15,pt=2,l=2,sg=0:1
        send: 9-9-0-0 s=255,c=3,t=16,pt=0,l=0,sg=0,st=fail:
        nonce tr err
        nonce tr err
        read and drop: 9-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
        read: 0-0-9 s=255,c=3,t=17,pt=6,l=25,sg=0:0129D04B64916F5E805EFDF704C34F56B47E547FDDE93805BE
        id=9
        send: 9-9-0-0 s=0,c=0,t=0,pt=0,l=0,sg=0,st=ok:
        send: 9-9-0-0 s=1,c=0,t=30,pt=0,l=0,sg=0,st=fail:
        [Setup duration: 9928 ms]
        send: 9-9-0-0 s=0,c=3,t=16,pt=0,l=0,sg=0,st=fail:
        nonce tr err
        send: 9-9-0-0 s=1,c=3,t=16,pt=0,l=0,sg=0,st=fail:
        nonce tr err
        nonce tr err
        Value is 1   Cycle is 1   3.39 v   [753 ms]
        David.
          @Anticimex
          Hello.
          find parent
          find parent
          parent=0, d=1
          req id
          nonce tr err
          nonce tr err
          id=9
          nonce tr err
          nonce tr err
          nonce tr err
          David.
          AnticimexA
          AnticimexA
          Anticimex
          @carlierd you have a lot of st=fail, so your problem is radio related, not signing related. I also see non nonce related messages fail so you need to stabilize your rf connection before signing can work. And since signing uses the maximum payload size, it has the least probability to succeed to be sent, so you could find that unsigned messages work while nonces and signed messages fail, but this is normal of the rf link is not fully working. If you get st=fail, it is a radio problem. See this discussion for details: http://forum.mysensors.org/topic/3386/mqttclientgateway-broken-after-upgrade-signature-failure
            carlierdC
            carlierdC
            carlierd
            @Anticimex Hello. Everything is working at 16 or 8MHz so I am pretty sure it's not an issue with the material.
            I will burn the bootloader again and create a new post if it's still not correct. I will also disable signing feature to be sure there is no impact.
            David.
              David.
              AnticimexA
              AnticimexA
              Anticimex
              @carlierd well, st=fail indicate transmission failure so it is pretty clear that you have a issue with rf, at least on that frequency. st=fail is not signing related. But, like previously discussed, enabling signing can trigger more st=fail because the payload gets bigger and is more sensitive to noise.
              • T
                tomkxy
                @calierd You can have a look here at the discussion I had with a similar problem which I was able to resolve finally. See the last reply in the aforementioned thread where I summarized how I resolved it, eventually.
                  carlierdC
                  carlierdC
                  carlierd
                  @Anticimex @tomkxy
                  Perhaps the arduino and RFM69 can't run at 1MHz. I have capacitors and I tried with two different power sources. Without signing it's better but still a lot of st=fail. No matter, it was just for testing purpose :)
                  • T
                    tomkxy
                    @calierd I cannot comment on RFM69 since I have non in operation. Sorry, try to place the nodes further apart and look whether it changes.
                    • duovisD
                      duovisD
                      duovis
                      @Anticimex Thank you for the effort you have put into signing, this is great!
                      Would it make sense to explore the I2C version of ATSHA204A ? The reason I'm asking is speed.
                      • AnticimexA
                        AnticimexA
                        Anticimex
                        Thanks @duovis,
                        Yes, I welcome anyone who has the HW to provide a IO routine for I2C-variants of ATSHA204A. I don't have the hw myself though.
                        duovisD 1 Reply Last reply
                          Thanks @duovis,
                          duovisD
                          duovisD
                          duovis
                          @Anticimex Ok, I'll try to play with it and see if I can come up with something that works on I2C.
                          • duovisD duovis
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @duovis Great. I'll happily review any code. You should only need to worry about the low level stuff.
                            • SoloamS
                              SoloamS
                              Soloam
                              Hello all!
                              Two fast question! Can I have nodes working with ATSHA204A chip and others with software?
                              And, can I have nodes with signing on and others off? Or if I add signing to my network, all nodes must have it?
                              Thank you all!
                              • SoloamS Soloam
                                Hello all!
                                Thank you all!
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @Soloam
                                You can mix nodes with soft signing and ATSHA signing as you like.
                                You can mix nodes with signing on and off as well. The GW will only sign messages to nodes that require it, and it will also only check signatures from nodes that require signatures. So you can have one node which support/require signing and another which don't. The GW will be able to exchange messages with both nodes.
                                • SoloamS
                                  SoloamS
                                  Soloam
                                  Great work indeed!
                                  Thank you @Anticimex
                                  • SoloamS Soloam
                                    Great work indeed!
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @Soloam thanks :)
                                    • alexsh1A
                                      alexsh1A
                                      alexsh1
                                      Slightly silly question, but did anyone manage to get signing working (MySigningAtsha204Soft signer;) on Arduino Uno on MS 1.5.4 on the Ethernet gateway please? I am going out of memory and really hate to upgrade it to Mega
                                      • alexsh1A alexsh1
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @alexsh1 if you feel adventurous try 2.0.0-beta2, or if you are patient, go to 2.0.0 in a few months and redesigns will have made space available for you.
                                        alexsh1A 1 Reply Last reply
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          #251
                                          @Anticimex Thanks - I am currently trying an Ethernet GW and a node (Sensebender Micro) with dev branch. I am stuck at personalisation. I cannot lock data. Any idea what I am doing wrong?
                                          This is Sensebender (with ATSHA204):
                                          Device revision: 00020009
                                          Device serial:   {0x01,0x23,0x53,0x3F,0x52,0x6A,0x1A,0x06,0xEE}
                                          0123533F526A1A06EE
                                          Skipping configuration write and lock (configuration already locked).
                                          Chip configuration:
                                          EEPROM DATA:
                                          ATSHA204A DATA:
                                                     SN[0:1]           |         SN[2:3]           | 01   23 | 53   3F
        Revnum                         | 00   09   04   00
        SN[4:7]                        | 52   6A   1A   06
                                              SN[8]    |  Reserved13   | I2CEnable | Reserved15    | EE | 13 | 00 | 00
                                            I2CAddress |  TempOffset   |  OTPmode  | SelectorMode  | C8 | 00 | 55 | 00
                                                   SlotConfig00        |       SlotConfig01        | 8F   80 | 80   A1
                                                   SlotConfig02        |       SlotConfig03        | 82   E0 | A3   60
                                                   SlotConfig04        |       SlotConfig05        | 94   40 | A0   85
                                                   SlotConfig06        |       SlotConfig07        | 86   40 | 87   07
                                                   SlotConfig08        |       SlotConfig09        | 0F   00 | 89   F2
                                                   SlotConfig0A        |       SlotConfig0B        | 8A   7A | 0B   8B
                                                   SlotConfig0C        |       SlotConfig0D        | 0C   4C | DD   4D
                                                   SlotConfig0E        |       SlotConfig0F        | C2   42 | AF   8F
                                            UseFlag00  | UpdateCount00 | UseFlag01 | UpdateCount01 | FF | 00 | FF | 00
                                            UseFlag02  | UpdateCount02 | UseFlag03 | UpdateCount03 | FF | 00 | FF | 00
                                            UseFlag04  | UpdateCount04 | UseFlag05 | UpdateCount05 | FF | 00 | FF | 00
                                            UseFlag06  | UpdateCount06 | UseFlag07 | UpdateCount07 | FF | 00 | FF | 00
        LastKeyUse[0:3]                    | FF   FF   FF   FF
        LastKeyUse[4:7]                    | FF   FF   FF   FF
        LastKeyUse[8:B]                    | FF   FF   FF   FF
        LastKeyUse[C:F]                    | FF   FF   FF   FF
                                            UserExtra  |    Selector   | LockValue |  LockConfig   | 00 | 00 | 55 | 00
                                          Take note of this key, it will never be the shown again:
                                          #define MY_HMAC_KEY [deleted]
                                          Writing key to slot 0...
                                          Send SPACE character to lock data...
                                          Data lock failed. Response: D3
                                          Halting!
