  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 467.3k Views 30 Watching
  • mfalkviddM
    The easiest way to find out is to look at the output in Arduino IDE when you click "Verify".
    There are some factors that affect size:
    • Size of bootloader
    • MySensors version (different versions of the library have different size requirements)
    • MySensors features used (software signing, encryption, debug on or off, etc)
    • Size of other libraries you use in your sketch
    • Size of your sketch
    • mfalkviddM
      ouch, @Anticimex was a bit faster :)
      oh, and the problem in the thread you quoted @Soloam is encryption. At least at that time, encryption used too much space so there wasn't space to include either hardware or software signing.
      • SoloamS
        SoloamS
        Soloam
        Yes, encryption and signing! I'll try to order this and test it out! http://www.ebay.com/itm/5PCS-ATSHA204A-STUCZ-T-IC-CRYPTO-4-5KB-SWI-204A-SHA204A-/191782104901?hash=item2ca71aaf45:g:zEQAAOSwwE5WZk9O
        • AnticimexA
          AnticimexA
          Anticimex
          And on development branch, @tekka has an open PR where he has cut down significantly on the size of the NRF24 driver as well.
          • AnticimexA
            AnticimexA
            Anticimex
            And you might also have read mine and @mfalkvidd's stand on encryption, so don't be discouraged if you find that you can't fit both. Just skip the encryption in that case. It adds far less in security than signing does.
            • SoloamS
              SoloamS
              Soloam
              Yes, if I have to discard one it would be encryption! Thank you for the help @Anticimex and @mfalkvidd
              • carlierdC
                carlierdC
                carlierd
                I currently testing various bootloader to measure impact on CPU speed on the power consumption.
                I got a lot of nonce error when using 1 MHz configuration.
                Is signing feature possible at 1 MHz ?
                David.
                AnticimexA 1 Reply Last reply
                • carlierdC carlierd
                  David.
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @carlierd could you specify a bit clearer what you mean by "nonce error"? Signing should work, but the atsha driver is not tested @ 1MHz and might get bad timing. Also, for soft (and hard) signing, if 1MHz is used, performance could degrade to the point that the nonce timeout needs to be increased.
                  carlierdC 1 Reply Last reply
                  • AnticimexA Anticimex
                    carlierdC
                    carlierdC
                    carlierd
                    @Anticimex
                    Hello.
                    I am using soft signing.
                    find parent
                    send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
                    read: 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                    sensor started, id=255, parent=255, distance=255
                    find parent
                    read: 0-0-255 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                    parent=0, d=1
                    req id
                    read: 0-0-255 s=255,c=3,t=4,pt=0,l=1,sg=0:9
                    send: 9-9-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=fail:1
                    read and drop: 9-9-0 s=255,c=3,t=15,pt=2,l=2,sg=0:1
                    read: 0-0-9 s=255,c=3,t=15,pt=2,l=2,sg=0:1
                    send: 9-9-0-0 s=255,c=3,t=16,pt=0,l=0,sg=0,st=fail:
                    nonce tr err
                    nonce tr err
                    read and drop: 9-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                    read: 0-0-9 s=255,c=3,t=17,pt=6,l=25,sg=0:0129D04B64916F5E805EFDF704C34F56B47E547FDDE93805BE
                    id=9
                    send: 9-9-0-0 s=0,c=0,t=0,pt=0,l=0,sg=0,st=ok:
                    send: 9-9-0-0 s=1,c=0,t=30,pt=0,l=0,sg=0,st=fail:
                    [Setup duration: 9928 ms]
                    send: 9-9-0-0 s=0,c=3,t=16,pt=0,l=0,sg=0,st=fail:
                    nonce tr err
                    send: 9-9-0-0 s=1,c=3,t=16,pt=0,l=0,sg=0,st=fail:
                    nonce tr err
                    nonce tr err
                    Value is 1   Cycle is 1   3.39 v   [753 ms]
                    David.
                      @Anticimex
                      Hello.
                      find parent
                      find parent
                      parent=0, d=1
                      req id
                      nonce tr err
                      nonce tr err
                      id=9
                      nonce tr err
                      nonce tr err
                      nonce tr err
                      David.
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @carlierd you have a lot of st=fail, so your problem is radio related, not signing related. I also see non nonce related messages fail so you need to stabilize your rf connection before signing can work. And since signing uses the maximum payload size, it has the least probability to succeed to be sent, so you could find that unsigned messages work while nonces and signed messages fail, but this is normal of the rf link is not fully working. If you get st=fail, it is a radio problem. See this discussion for details: http://forum.mysensors.org/topic/3386/mqttclientgateway-broken-after-upgrade-signature-failure
                        carlierdC
                        carlierdC
                        carlierd
                        @Anticimex Hello. Everything is working at 16 or 8MHz so I am pretty sure it's not an issue with the material.
                        I will burn the bootloader again and create a new post if it's still not correct. I will also disable signing feature to be sure there is no impact.
                        David.
                          David.
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @carlierd well, st=fail indicate transmission failure so it is pretty clear that you have a issue with rf, at least on that frequency. st=fail is not signing related. But, like previously discussed, enabling signing can trigger more st=fail because the payload gets bigger and is more sensitive to noise.
                          • T
                            tomkxy
                            @calierd You can have a look here at the discussion I had with a similar problem which I was able to resolve finally. See the last reply in the aforementioned thread where I summarized how I resolved it, eventually.
                              carlierdC
                              carlierdC
                              carlierd
                              @Anticimex @tomkxy
                              Perhaps the arduino and RFM69 can't run at 1MHz. I have capacitors and I tried with two different power sources. Without signing it's better but still a lot of st=fail. No matter, it was just for testing purpose :)
                              • T
                                tomkxy
                                @calierd I cannot comment on RFM69 since I have non in operation. Sorry, try to place the nodes further apart and look whether it changes.
                                • duovisD
                                  duovisD
                                  duovis
                                  @Anticimex Thank you for the effort you have put into signing, this is great!
                                  Would it make sense to explore the I2C version of ATSHA204A ? The reason I'm asking is speed.
                                  • AnticimexA
                                    AnticimexA
                                    Anticimex
                                    Thanks @duovis,
                                    Yes, I welcome anyone who has the HW to provide a IO routine for I2C-variants of ATSHA204A. I don't have the hw myself though.
                                    duovisD 1 Reply Last reply
                                      Thanks @duovis,
                                      duovisD
                                      duovisD
                                      duovis
                                      @Anticimex Ok, I'll try to play with it and see if I can come up with something that works on I2C.
                                      • duovisD duovis
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @duovis Great. I'll happily review any code. You should only need to worry about the low level stuff.
                                        • SoloamS
                                          SoloamS
                                          Soloam
                                          Hello all!
                                          Two fast question! Can I have nodes working with ATSHA204A chip and others with software?
                                          And, can I have nodes with signing on and others off? Or if I add signing to my network, all nodes must have it?
                                          Thank you all!
