  3. Arduino UNO + serial gateway
12 Posts 3 Posters 6.3k Views 4 Watching
  • E
    E
    erangel
    I don't have radio. Because this, I just want to use serial usb.
      Then you must use the development branch.
      • E
        E
        erangel
        Thanks for information. I downloaded the development branch, but the SerialGateway is "empty". Is it correct ? The version 1.5 is compatible ?
        • G
          G
          georgep56
          If you mean that there is no code in setup{} or loop{} then yes, that is correct.
          The new development branch code works differently.
          • E
            E
            erangel
            How can I take some sample to create a relay actuator using the development version ? Do you have some documentation of this version ?
              All the examples has been converted. Among them is the RelayActuator. But instead of defining MY_RADIO_NRF24 you must enable the serial gateway by defining MY_GATEWAY_SERIAL
              So basically only one little change.
              • E
                E
                erangel
                Tks Hek!
                I changed the source, but now I do not compile the code.
                Do you know what is that ?
                MyGatewayTransport.cpp:In function 'void gatewayTransportProcess()
                MyGatewayTransport.cpp:54:16: error: cannot resolve overloaded function 'receive' based on conversion to type 'bool
                :if (receive) {
                Error compiling project sources
                I am using RelayActuator.
                  Just tried it here and I'm not getting any errors here when compiling.. You must be doing something wrong.
                  • E
                    E
                    erangel
                    @hek said:
                    MY_GATEWAY_SERIAL
                    Hi @hek!
                    Do you know if the feature - MY_GATEWAY_SERIAL - it is in 1.5 version ? Or jut in development ?
                      It is a development branch define.
