  3. MySensors on ATTINY85
attiny
24 Posts 12 Posters 21.7k Views 4 Watching
    mrendu43
    hello
    I dont understand why didnt you use reset, and delcare it as input pin?
    as i know it can be declared as io
    • SweebeeS
      SweebeeS
      Sweebee
      wrote on last edited by Sweebee
      Oitzu and I (testing :P) are currently working on the Attiny support. To test you can download this library (the same as the original one except that it includes the attiny).
      Its working so far.
      Bugs:
      Your node id is the same as child id (if you set a different child id, somehow the attiny ignores it and makes it the same as your node id).
      Sleep is working with interrupt but it does the setup again after wake.
      Sleep / timer is not yet working.
      library: https://github.com/Oitzu/Arduino/tree/master/libraries/MySensors (You can replace it with your existing mysensors library)
      example sketch thats working: http://pastebin.com/xRu2JNQ9
      wiring:
                       1|o   |8  VCC/CE  RED/ORANGE
       YELLOW  CSN     2|    |7  SCK     GREEN
       -       SENSOR  3|    |6  MOSI    BLUE
      BLACK    GND     4|    |5  MISO    VIOLET
      • A
        Andy
        Awsome work Oitzu and Sweebee!
        Just tried it out and it works perfect :)
        Have you succeeded with getting the sleep/timer working? I've tried but discovered that my skills aren't good enough.
        mntlvrM 1 Reply Last reply
        • SweebeeS
          SweebeeS
          Sweebee
          Not yet. Maybe next week. To much work at school right now ^^. But when it works i'll post it here.
          A 1 Reply Last reply
          • SweebeeS Sweebee
            Andy
            @Sweebee Got it working last night (I hope!), I haven't measured the power consumption yet.
            It doesn't have the resolution of ms. To save battery the attiny85 will sleep for 8 seconds, then wake up and go to sleep again. So if you call gw.deep_sleep(7), it will sleep fox 7x8=56 seconds. It is possible to get a more precise timer by calculating the best combination of sleep timers. For example if you want to sleep a minute, sleep 7x8s=56s and then an additional 1x4s=4, total 60s.
            It needs some cleaning up and correct naming/commenting/testing e.t.c.
            void MySensor::deep_sleep(int time) {
            	// Sleep alternatives:
            	// 0=16ms, 1=32ms,2=64ms,3=128ms,4=250ms,5=500ms, 6=1 sec,7=2 sec, 8=4 sec, 9= 8sec
            	int ii = 9;	// sleep 8 seconds at a time.
            	byte bb;
            	int ww;
            	if (ii > 9 ) ii=9;
            	bb=ii & 7;
            	if (ii > 7) bb|= (1<<5);
            	bb|= (1<<WDCE);
            	ww=bb;
            	MCUSR &= ~(1<<WDRF);
            	// start timed sequence
            	WDTCR |= (1<<WDCE) | (1<<WDE);
            	// set new watchdog timeout value
            	WDTCR = bb;
            	WDTCR |= _BV(WDIE);
            	// Count some sheeps.
            	for(int i=0;i<time;i++) {
            		RF24::powerDown();
            		cbi(ADCSRA,ADEN);                    // switch Analog to Digitalconverter OFF
            		set_sleep_mode(SLEEP_MODE_PWR_DOWN); // sleep mode is set here
            		sleep_enable();
            		sleep_mode();                        // System actually sleeps here
            		sleep_disable();                     // System continues execution here when watchdog timed out
            		sbi(ADCSRA,ADEN);                    // switch Analog to Digitalconverter ON
            • n3roN
              n3roN
              n3ro
              has someone tested digispark? That would be to test a lot easier.
              http://digistump.com/products/1
              pimatic + MySensors + Homeduino + z-way
              https://github.com/n3roGit/MySensors_n3ro
              • A Andy
                mntlvrM
                mntlvrM
                mntlvr
                Hi Fella,
                I just came across this post several weeks ago , I was looking for a smaller cheaper way of making a binary switch to use with my Veras. After reading the "Great debates" whether an ATTiny 85 could be used for such a purpose, I decide to try what was here and by the individuals who said they had made them work. I built one and powered it with a Li-Ion 3.7 v 4000 Mah battery. I have had it in use now for about a week and so far it works great. I have not been able to make the WDT work but from my test so far , running the ATTiny and nRF24l01+ from a Li-ION 4000 Mah battery , it should last for months. Now the the entire circuit is drawing 6.0 ma and when tripped the unit drew 7.5 ma. Now I am sure the current was higher than 7.5 ma when in transmit but it would be for just a very small amount of time. Thanks for the leg work you guys did to make this project for me happen.
                • SweebeeS Sweebee
                  Its working so far.
                  Bugs:
                  wiring:
                  ted
                  @Sweebee
                  Do you mind sharing your library again? The link is no longer working.
                  • OitzuO
                    OitzuO
                    Oitzu
                    @ted you are probably searching for this: https://github.com/Oitzu/mysensors-Arduino-attiny/tree/master/libraries/MySensors
                    But i need to seriously warn you, it is horribly outdated. The repository do not got the love it needed. ^^
                    • OitzuO Oitzu
                      ted
                      @Oitzu
                      Thanks!!
