  3. MySensors on ATTINY85
attiny
24 Posts 12 Posters 21.7k Views 4 Watching
  • J
    J
    Joseph Macaulay
    Hi, can you share any of the source code you got running on the ATTiny85? I've got 5 ATTiny85s & 5 ATTiny84s. I've been running the TMRH20 RF24, Network, and Mesh on them, but I wanted to see if I can use the MySensor stuff. Thanks!
    axillentA V 2 Replies Last reply
    • J Joseph Macaulay
      axillentA
      axillentA
      axillent
      @Joseph-Macaulay the version of RF24 is comming with latest MySensor contains a software SPI driver able to work on tiny MCU
      sense and drive
      • J Joseph Macaulay
        V
        V
        vtento
        wrote on last edited by vtento
        • @Joseph-Macaulay Hi, this is the sketch that I use for Themp sensor
        MySensors85.ino
          mrendu43
          hello
          I dont understand why didnt you use reset, and delcare it as input pin?
          as i know it can be declared as io
          • SweebeeS
            SweebeeS
            Sweebee
            wrote on last edited by Sweebee
            Oitzu and I (testing :P) are currently working on the Attiny support. To test you can download this library (the same as the original one except that it includes the attiny).
            Its working so far.
            Bugs:
            Your node id is the same as child id (if you set a different child id, somehow the attiny ignores it and makes it the same as your node id).
            Sleep is working with interrupt but it does the setup again after wake.
            Sleep / timer is not yet working.
            library: https://github.com/Oitzu/Arduino/tree/master/libraries/MySensors (You can replace it with your existing mysensors library)
            example sketch thats working: http://pastebin.com/xRu2JNQ9
            wiring:
                             1|o   |8  VCC/CE  RED/ORANGE
             YELLOW  CSN     2|    |7  SCK     GREEN
             -       SENSOR  3|    |6  MOSI    BLUE
            BLACK    GND     4|    |5  MISO    VIOLET
            • A
              Andy
              Awsome work Oitzu and Sweebee!
              Just tried it out and it works perfect :)
              Have you succeeded with getting the sleep/timer working? I've tried but discovered that my skills aren't good enough.
              mntlvrM 1 Reply Last reply
              • SweebeeS
                SweebeeS
                Sweebee
                Not yet. Maybe next week. To much work at school right now ^^. But when it works i'll post it here.
                A 1 Reply Last reply
                • SweebeeS Sweebee
                  Andy
                  @Sweebee Got it working last night (I hope!), I haven't measured the power consumption yet.
                  It doesn't have the resolution of ms. To save battery the attiny85 will sleep for 8 seconds, then wake up and go to sleep again. So if you call gw.deep_sleep(7), it will sleep fox 7x8=56 seconds. It is possible to get a more precise timer by calculating the best combination of sleep timers. For example if you want to sleep a minute, sleep 7x8s=56s and then an additional 1x4s=4, total 60s.
                  It needs some cleaning up and correct naming/commenting/testing e.t.c.
                  void MySensor::deep_sleep(int time) {
                  	// Sleep alternatives:
                  	// 0=16ms, 1=32ms,2=64ms,3=128ms,4=250ms,5=500ms, 6=1 sec,7=2 sec, 8=4 sec, 9= 8sec
                  	int ii = 9;	// sleep 8 seconds at a time.
                  	byte bb;
                  	int ww;
                  	if (ii > 9 ) ii=9;
                  	bb=ii & 7;
                  	if (ii > 7) bb|= (1<<5);
                  	bb|= (1<<WDCE);
                  	ww=bb;
                  	MCUSR &= ~(1<<WDRF);
                  	// start timed sequence
                  	WDTCR |= (1<<WDCE) | (1<<WDE);
                  	// set new watchdog timeout value
                  	WDTCR = bb;
                  	WDTCR |= _BV(WDIE);
                  	// Count some sheeps.
                  	for(int i=0;i<time;i++) {
                  		RF24::powerDown();
                  		cbi(ADCSRA,ADEN);                    // switch Analog to Digitalconverter OFF
                  		set_sleep_mode(SLEEP_MODE_PWR_DOWN); // sleep mode is set here
                  		sleep_enable();
                  		sleep_mode();                        // System actually sleeps here
                  		sleep_disable();                     // System continues execution here when watchdog timed out
                  		sbi(ADCSRA,ADEN);                    // switch Analog to Digitalconverter ON
                  • n3roN
                    n3roN
                    n3ro
                    has someone tested digispark? That would be to test a lot easier.
                    http://digistump.com/products/1
                    pimatic + MySensors + Homeduino + z-way
                    https://github.com/n3roGit/MySensors_n3ro
                    • A Andy
                      mntlvrM
                      mntlvrM
                      mntlvr
                      Hi Fella,
                      I just came across this post several weeks ago , I was looking for a smaller cheaper way of making a binary switch to use with my Veras. After reading the "Great debates" whether an ATTiny 85 could be used for such a purpose, I decide to try what was here and by the individuals who said they had made them work. I built one and powered it with a Li-Ion 3.7 v 4000 Mah battery. I have had it in use now for about a week and so far it works great. I have not been able to make the WDT work but from my test so far , running the ATTiny and nRF24l01+ from a Li-ION 4000 Mah battery , it should last for months. Now the the entire circuit is drawing 6.0 ma and when tripped the unit drew 7.5 ma. Now I am sure the current was higher than 7.5 ma when in transmit but it would be for just a very small amount of time. Thanks for the leg work you guys did to make this project for me happen.
                      • SweebeeS Sweebee
                        Its working so far.
                        Bugs:
                        wiring:
                        ted
                        @Sweebee
                        Do you mind sharing your library again? The link is no longer working.
                        • OitzuO
                          OitzuO
                          Oitzu
                          @ted you are probably searching for this: https://github.com/Oitzu/mysensors-Arduino-attiny/tree/master/libraries/MySensors
                          But i need to seriously warn you, it is horribly outdated. The repository do not got the love it needed. ^^
                          • OitzuO Oitzu
                            ted
                            @Oitzu
                            Thanks!!
