  3. ๐Ÿ’ฌ AC-DC double solid state relay module
hlk-pm01solid state relaylight switchlightacdc
226 Posts 67 Posters 170.5k Views 65 Watching
  • sundberg84S
    sundberg84S
    @Samuel235 Check http://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers/295 - below post #295 is a great discussion about slow/fast blow.
    S 1 Reply Last reply
    • m26872M
      m26872M
      m26872
      I also wrote some here about fuse selection: http://forum.mysensors.org/topic/3428/my-look-at-a-cheap-12v-power-supply
        shabba
        wrote on last edited by shabba
        Does anyone know how to convert diptrace to kicad format? I want to try and edit to make a RFM69 version.
        An on that note - would swapping a 3.3v arduino in and connecting the HLK to raw and supply rest of circuit from the VCC pin work? That way I do not need to level shift for the RFM69 and I don't need the voltage converter either.
        • sundberg84S sundberg84
          Samuel235
          @sundberg84, @m26872 - Thanks for pointing me over there. I had read through those before but didn't take it all in back then as i wasn't doing my module back then. Thank you for reminding me!
          MySensors 2.1.1
          • SoloamS
            SoloamS
            Soloam
            wrote on last edited by Soloam
            Hello @aproxx I was developing something similar but using a ATMEGA328 chip, that way I would make it smaller! Can I ask you way do you use 2 100nf Capacitors after the HLK? And what is the width of the copper lines in the 220v and signal?
            Thank you
            And great work
            • SoloamS Soloam
              Thank you
              And great work
              Samuel235
              @Soloam, the capacitors after the HLK are to filter out any noise from the HLK and the AC Input side of the circuitry. I personally shoot for a 100uF cap if its below 5A and anything over 5A i'de drop a 440uF in, along with a 0.1uF next to it. This isn't saying Aproxx is wrong or incorrect in any way, that is just my personal preference.
              As for the trace width, i can't help you on that one as i can't open any of his board files to get a reading on them. I'm sure he will provide some more detailed information for you.
              MySensors 2.1.1
                I let approx answer for his width trace :)
                You can find online tools to calc this, plus there are different strategy like using a pcb with thicker copper (2oz but more expensive than of 1oz common). Like no soldermask so you add some solder or/and piece of copper wire to improve thickness etc..The thicker copper, the smaller the trace.
                For the capacitor, it's for filtering output ripple, not input! there is no 5A on output.
                Only 2cap can't filter everything.. but that will improve and work better than nothing ;) And increasing a lot the 100uf like 400uf won't change things, it could be less efficient. I won't do a lesson (I'm not expert too) but sometimes its preferable to use multiple different value capacitor depending on what you want to filter. And here again there are other filtering techniques which can be used. but that's if you have problem with those ripples on your circuit and it's easier to have a scope to check how this improve.
                • scalzS scalz
                  Samuel235
                  And there is the more advanced version of my reply, thanks to @scalz.
                  MySensors 2.1.1
                  • A
                    aproxx
                    wrote on last edited by aproxx
                    @Soloam I'm actually not using 2 100nF capacitors, but 1 100nF and 100 uF capacitor. Exactly for the reason that scalz mentioned. :) I'm not saying these are the perfect values to use, but I came across similar values some time ago, and these give me a decent and stable voltage.
                    The width of my copper traces is 2mm for the entire high voltage circuit. I have used a trade width/thickness calculator, and it should be more than sufficient to power the HLK-PM01.
                    However, it is not sufficient for the traces between the relays and the connectors because it should be able to handle up to 2A (limiting factor of the solid state relays). That's why I have designed this board with open air traces between the relays and the connectors. That way it's possible to reinforce the traces with solder, after which it should be able to withstand 2 Amps.
                    And good luck with designing your version of the board! If there is a way to decrease the board size even further that would be great!
                    • SoloamS
                      SoloamS
                      Soloam
                      Hello all, I finished my version of this idea! Thank you to @aproxx for the help! I used a ATMEGA328, this wil make it a bit cheaper. https://www.openhardware.io/view/83
                      I need some help validating the layout, most important the 220v traces and the capacitors used in the layout!
                      Thank you all
                      dpressleD 1 Reply Last reply
                      • okosO
                        okosO
                        okos
                        My question is whether the code includes support DS18B20?
                          Samuel235
                          @aproxx, Could i ask what trace width and what clearance you used for the AC portion of this device? Also, what current did you base these settings on, what current do you expect to be flowing through the AC traces?
                          MySensors 2.1.1
                            shabba
                            Just a thought : Why not use RAW instead of VCC so a 3.3V mini can be used as thus no logic conversion needed for RFM69? The SSR works find below 3v as it happens. Also means no need for the voltage changer. Could also look at getting the 3.3V HLMs also I guess.
                            • okosO
                              okosO
                              okos
                              How many pieces got ordering paying $ 14 http://dirtypcbs.com/index.php ?
                              mr_constM 1 Reply Last reply
                              • mr_constM
                                mr_constM
                                mr_const
                                Hi @approx, there is 4k7 resistor placeholder under arduino, near 100nf capacitor, but you didn't mention it in a project description - is this resistor optional?
                                • mr_constM mr_const
                                  Samuel235
                                  @Konstantin-Kolesnichenko, I would highly recommend the pullup resistor.
                                  Please see https://wp.josh.com/2014/06/23/no-external-pull-up-needed-for-ds18b20-temp-sensor/ for more information regarding this resistor.
                                  MySensors 2.1.1
                                  • okosO okos
                                    mr_constM
                                    mr_constM
                                    mr_const
                                    @okos I got 11 pieces for one order.
                                    @Samuel235 thank you, soldered one :)
                                    • the cosmic gateT
                                      the cosmic gateT
                                      the cosmic gate
                                      anybody who's got a complete kit for sale ? Want to test build one (single relay is enough)
                                      (or maybe nicer: a 3in1 solution : Motion detection , relais , DHT of other temp sensor)
                                      There's more than meets the eye
                                      • mr_constM
                                        mr_constM
                                        mr_const
                                        Is somewhere there present source for this module with temperature module support?
                                        • badmannenB
                                          badmannenB
                                          badmannen
                                          this looks like a great project. Have anyone made a complete shopping / whish-list on Alibaba for all the components needed? ( Iยดm lookin for safest version possible =)
                                          Many thanks,
                                          Henrik
                                          rPi 3 - UNO R3 - Mini - Nano - custom
                                          Nca78N 2 Replies Last reply
                                          With your input, this post could be even better ๐Ÿ’—
