  3. [ProMini] Blue LED on Pin 13 wont turn off
13 Posts 4 Posters 3.7k Views 3 Watching
  • R Offline
    R Offline
    rollercontainer
    I try to get a 2 AA node to work. I desoldered the voltage regulator and the power led from my 3,3V 8Mhz Pro Mini. Then I tried 1 MHz bootloaders and fuses. But the Pin13 LED keeps on burning. I tried to set it to low and high (for maybe chinese reverse logic) but it wont turn off. Strange is: I can blink it on purpose. Then I thought: maybe its an bootloader issue. But same thing wirth original bootloader and on another Pro Mini guess what? Right, the same thing.
    Is there something in the beta lib lighting up my led?
    I am using this 2.0.0-beta sketch with SI7021:
    // Relais Node for MySensors 2.0.0-beta
    // I am using the filename and compile date for sktech announcements:
    #include <string.h>
    // Strip the path info from __FILE__
    // For Windows use '\\' instead of '/'.
    #define __FILENAME__ (strrchr(__FILE__, '\\') ? strrchr(__FILE__, '\\') + 1 : __FILE__)
    #define SKETCH_NAME __FILENAME__
    #define SKETCH_DATE __DATE__
    #define MY_NODE_ID 70
    #define MY_PARENT_NODE_ID 0
    #define MY_REPEATER_FEATURE false
    #include <SI7021.h>
    #include <RunningAverage.h>
    #include <avr/power.h>
    //#define BATT_SENSOR    199
    #define AVERAGES 2
    #define CHILD_ID_TEMP  0
    #define CHILD_ID_HUM   1
    #define FORCE_TRANSMIT_INTERVAL 30
    #define LED 13
    #define SI7021_POWER 2
    SI7021 humiditySensor;
    #ifdef BATT_SENSOR
    MyMessage msgBatt(BATT_SENSOR, V_VOLTAGE);
    // Global settings
    int measureCount = 0;
    int sendBattery = 0;
    boolean isMetric = true;
    boolean highfreq = true;
    boolean transmission_occured = false;
    float lastTemperature = -100;
    int lastHumidity = -100;
    long lastBattery = -100;
       Setup code
      pinMode(SI7021_POWER, OUTPUT);
      //pinMode(LED, OUTPUT);
      digitalWrite(SI7021_POWER, HIGH);
      //digitalWrite(LED, HIGH);
      delay (100);
      Serial.begin(9600);
      raHum.clear();
      sendTempHumidityMeasurements(false);
      sendBattLevel(false);
      humiditySensor.begin();
      digitalWrite(SI7021_POWER, LOW);
      //flashLED(5);
    void presentation()  {
      sendSketchInfo(SKETCH_NAME, SKETCH_DATE);
      present(CHILD_ID_HUM, S_HUM, "Humidity");
      present(CHILD_ID_TEMP, S_TEMP, "Temperature");
    #ifdef BATT_SENSOR
      present(BATT_SENSOR, S_POWER);
        Main loop function
      //digitalWrite(LED, LOW);
      delay (100);
      measureCount ++;
      sendBattery ++;
      bool forceTransmit = false;
      if (measureCount > FORCE_TRANSMIT_INTERVAL) { // force a transmission
        forceTransmit = true;
        measureCount = 0;
      sleep(MEASURE_INTERVAL);
       Sends temperature and humidity from Si7021 sensor
       Parameters
       - force : Forces transmission of a value (even if it's the same as previous measurement)
    void sendTempHumidityMeasurements(bool force)
      bool tx = force;
      raHum.addValue(data.humidityPercent);
      Serial.print(F("TempDiff :")); Serial.println(diffTemp);
      Serial.print(F("HumDiff  :")); Serial.println(diffHum);
      if (isnan(diffHum)) tx = true;
      if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
      if (diffHum > HUMI_TRANSMIT_THRESHOLD) tx = true;
      if (tx) {
        measureCount = 0;
        float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
        float humidity = data.humidityPercent;
        Serial.print("T: "); Serial.println(temperature);
        Serial.print("H: "); Serial.println(humidity);
        lastHumidity = humidity;
        transmission_occured = true;
        if (sendBattery > 60) {
          sendBattLevel(true); // Not needed to send battery info that often
          sendBattery = 0;
        //flashLED(1);
       Sends battery information (battery percentage)
       Parameters
      if (force) lastBattery = -1;
      long vcc = readVcc();
      if (vcc != lastBattery) {
        lastBattery = vcc;
    #ifdef BATT_SENSOR
        send(msgBatt.set(vcc));
        // Calculate percentage
        long percent = vcc / 14.0;
        sendBatteryLevel(percent);
       Internal battery ADC measuring
    long readVcc() {
    void flashLED(int count) {
      int i;
      for (i = 0 ; i < count ; i++) {
        delay(10);
        delay(200);
    • S Offline
      @rollercontainer - could be, some bootloaders use this led to indicare its ready.
      Arduino Pro Mini bootloader for example blinks if its loaded and waiting for a sketch to be uploaded. Depends on which bootloader you use and how that is coded.
      But once you upload a sketch on the original bootloader it does not blink (unless there is radio traffic - ie signals going to and from the nrf24l01+ on pin 13.
      R 1 Reply Last reply
      • R Offline
        R Offline
        rollercontainer
        You are right, I missed that one. 13 is a radio pin AND the led output. So I have to move the radio pin or desolder the led, right?
        • mfalkviddM Offline
          I keep the led13 on my battery-powered units. It is useful for basic troubleshooting and the power used is small enough to be ignored.
          • S sundberg84
            R Offline
            R Offline
            rollercontainer
            @sundberg84 Thanks a lot for opening my eyes!
            I moved the radio to soft spi and now it works like intended.
            // RobotDyn Pro Mini 3,3V 8Mhz has blue LED on Pin13 which is used by radio and will be lit all the time.
            // Therfore, I moved the radio as it is done for the ethernet gateway.
            #define MY_SOFTSPI
            #define MY_SOFT_SPI_SCK_PIN 14  // Analog 0
            #define MY_SOFT_SPI_MOSI_PIN 15 // Analog 1
            #define MY_SOFT_SPI_MISO_PIN 16 // Analog 2
            #define MY_RF24_CE_PIN 5
            #define MY_RF24_CS_PIN 6
            • B Offline
              B Offline
              boozz
              @rollercontainer
              And you opened my eyes with the soft-spi remark. I just realized this could be an option to connect a LCD to a pro-mini as some kind of temperature indicator for multiple sensors. This is still on my wish-list.
              • outside temperature (low, high, current).
              • multiple room temperatures
              • etc..
              BR,
              Boozz
              • R Offline
                R Offline
                rollercontainer
                How about an I2C Display? Two wires on A4 &A5...
                • S Offline
                  Going OT now - but @boozz here is an example of my i2c lcd (A4 + A5).
                  https://www.openhardware.io/view/23/In-wall-LCD-SwitchScene-controller-for-MySensors
                  B 1 Reply Last reply
                  • S sundberg84
                    B Offline
                    B Offline
                    boozz
                    @sundberg84
                    Thanks for the example, I'll have a look at it and yes we're going OT now. :grin:
                    BR,
                    Boozz
                    • R Offline
                      R Offline
                      rollercontainer
                      no problem, my fault was solved. Feel free to capture the thread ^^
                        Another thing that's slightly OT... How much more power does soft spi use compared to hardware spi? Is it more or less than the led?
                        • R Offline
                          R Offline
                          rollercontainer
                          Excellent question. I dont know.
                          • R Offline
                            R Offline
                            rollercontainer
                            Here are some scientific messurements: http://cc.oulu.fi/~kmikhayl/site-assets/pdfs/2012_NTMS.pdf
                            Table on last page says: SoftSPI consumes about double the electricity of a Hardware SPI on a PIC system. So, desoldering the LED is the thing to do.
                            Thx for the hint.
                            12.1k
