  3. Help troubleshooting code
13 Posts 3 Posters 3.3k Views 3 Watching
  • Cliff KarlssonC Offline
    Cliff Karlsson
    I want to use a PIR to enable two ultrasonic sensors for 30 seconds like this:
    1 PIR detects movement
    2 PIR is disabled for 30 seconds
    3 Both ultrasonic sensors is enbabled for 30 seconds
    4 Ultrasonic sensors OFF PIR ON
    5 --> Step one
    But I cant get my code to complie.
    // Enable debug prints
    #define MY_BAUD_RATE 115200
    #include <NewPing.h>
    #define SONAR_A_CHILD_ID 1
    #define SONAR_B_CHILD_ID 2
    #define MOTION_A_CHILD_ID 3
    #define SONAR_A_TRIGGER_PIN  6  // Arduino pin tied to trigger pin on the ultrasonic sensor.
    #define SONAR_A_ECHO_PIN     5  // Arduino pin tied to echo pin on the ultrasonic sensor.
    #define MOTION_A_TRIGGER_PIN  2
    #define SONAR_B_TRIGGER_PIN  8  // Arduino pin tied to trigger pin on the ultrasonic sensor.
    #define SONAR_B_ECHO_PIN     7  // Arduino pin tied to echo pin on the ultrasonic sensor.
    #define MAX_DISTANCE 300 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
    unsigned long SLEEP_TIME = 200; // Sleep time between reads (in milliseconds)
    unsigned long MOTION_SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
    NewPing sonar_A(SONAR_A_TRIGGER_PIN, SONAR_A_ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
    NewPing sonar_B(SONAR_B_TRIGGER_PIN, SONAR_B_ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
    MyMessage SONAR_A_msg(SONAR_A_CHILD_ID, V_DISTANCE);
    int SONAR_A_lastDist;
    MyMessage SONAR_B_msg(SONAR_B_CHILD_ID, V_DISTANCE);
    int SONAR_B_lastDist;
    MyMessage MOTION_A_msg(MOTION_A_CHILD_ID, V_TRIPPED);
    boolean metric = true;
      pinMode(MOTION_A_TRIGGER_PIN, INPUT);      // sets the motion sensor digital pin as input
      sendSketchInfo("Distance+Motion Sensor", "1.0");
      present(SONAR_A_CHILD_ID, S_DISTANCE);
      present(SONAR_B_CHILD_ID, S_DISTANCE);
      present(MOTION_A_TRIGGER_PIN, S_MOTION);
      boolean tripped = digitalRead(MOTION_A_TRIGGER_PIN) == HIGH;
      Serial.println(tripped);
      send(MOTION_A_msg.set(tripped?"1":"0"));  // Send tripped value to gw
     if(tripped)  {
      int SONAR_A_dist = metric?sonar_A.ping_cm():sonar_A.ping_in();
      Serial.print("Ping Sonar A: ");
      Serial.print(SONAR_A_dist); // Convert ping time to distance in cm and print result (0 = outside set distance range)
      Serial.println(metric?" cm":" in");
      if (SONAR_A_dist != SONAR_A_lastDist) {
          send(SONAR_A_msg.set(SONAR_A_dist));
          SONAR_A_lastDist = SONAR_A_dist;
      wait(1000);
      int SONAR_B_dist = metric?sonar_B.ping_cm():sonar_B.ping_in();
      Serial.print("Ping Sonar B: ");
      Serial.print(SONAR_B_dist); // Convert ping time to distance in cm and print result (0 = outside set distance range)
      if (SONAR_B_dist != SONAR_B_lastDist) {
          send(SONAR_B_msg.set(SONAR_B_dist));
          SONAR_B_lastDist = SONAR_B_dist;
      sleep(SLEEP_TIME);
    //else{
      sleep(INTERRUPT,CHANGE, MOTION_SLEEP_TIME);
    reply
    • barduinoB Offline
      barduinoB Offline
      barduino
      Hi @Cliff-Karlsson
      In this line
      DIGITAL_INPUT_SENSOR does not exist, Im assuming its the pin from the PIR so replace it with
      #define INTERRUPT MOTION_A_CHILD_ID-2
      Also you have an extra } in your code
        sleep(SLEEP_TIME);
      //else{
      Replace with
          sleep(SLEEP_TIME);
        //else{
        sleep(INTERRUPT, CHANGE, MOTION_SLEEP_TIME);
      • barduinoB barduino
        Hi @Cliff-Karlsson
        In this line
          sleep(SLEEP_TIME);
        //else{
        Replace with
            sleep(SLEEP_TIME);
          //else{
        martinhjelmareM Offline
        martinhjelmare
        @barduino
        Don't confuse MOTION_A_TRIGGER_PIN with MOTION_A_CHILD_ID.
        barduinoB 1 Reply Last reply
          @barduino
          barduinoB Offline
          barduinoB Offline
          barduino
          @martinhjelmare
          You're right it should be MOTION_A_TRIGGER_PIN. And it should be -1 not -2 confirm?
            @martinhjelmare
            martinhjelmare
            @barduino
            The interrupt number is usually pin - 2 on our boards. But I would rather use the function provided by arduino to get the correct interrupt number for a pin, digitalPinToInterrupt.
              Cliff Karlsson
              Thanks for the help, the sketch complies and runs now. But where and how do I specify the timing in the sketch. This is what I want.
              5 --> Step one
                Cliff Karlsson
                I don't really understand how the sketch that I posted works. After motionsensor detects movement the loop under
                if (tripped)
                runs, but for how long are the ultrasonic sensors active? And how do I make it so that they are active for 30 sec before they are disabled and the PIR starts again.
                  if (tripped)
                  martinhjelmare
                  @Cliff-Karlsson
                  Should the node sleep in between pinging during the 30 secs that the sonars should be active?
                    Cliff Karlsson
                    No I only want the sensor to sleep until it gets interrupted from the PIR. Then I want the ultrasonic sensors to ping continuously during the 30 secs.
                    • martinhjelmareM Offline
                      martinhjelmare
                      Right now there's a call to wait method in between A and B pings, waiting 1 second. Is that intended? For 30 secs, ping A and B alternatively every 1 second?
                      Cliff KarlssonC 1 Reply Last reply
                        Cliff Karlsson
                        @martinhjelmare
                        Well I thing the sketch was created mostly using copy/paste so that bit is not exactly what I wanted.
                        For 30secs, ping A and B alternatively every 100ms would probably be better.
                          Cliff Karlsson
                          I don't understand where and how I should specify that the ultrasonic part should run for 30 sec.
                           if(tripped)  {
                            wait(1000);
                            sleep(SLEEP_TIME);
                          //else{
                            sleep(INTERRUPT,CHANGE, MOTION_SLEEP_TIME);```
                            martinhjelmare
                            You have to add a timer, and an if statement. Start the timer after motion is tripped. If time is less than 30 s, ping. Else reset timer and sleep with motion interrupt.
                            I can post some example code later perhaps.
