  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 659.9k Views 35 Watching
  • AnticimexA
    AnticimexA
    Anticimex
    You will still be notified without verbose logging. And if you have enabled and require signing, you won't get any data if something fails (assuming signing is properly activated).
    ximinezX 1 Reply Last reply
    • user2334U user2334
      I just received two Sensebenders, but have problems getting the device to consume little power. I get totally different values as displayed above.
      #include <LowPower.h>
      #include "RF24.h"
      RF24 radio(9, 10);
          delay(8000);
      user2334U
      user2334U
      user2334
      #include "RF24.h"
      RF24 radio(9, 10);
          delay(8000);
      As a follow-up to my previous posting, I can confirm, that using original nRF24-modules (best source seems to be https://www.itead.cc/nrf24l01-module.html), I get 0,023mA (=23µA) with nrf24 attached during sleep mode (no difference between the libraries JeeLib->Sleepy::loseSomeTime or LowPower->LowPower.powerDown).
      It is quite interesting, that so many nRF24 Modules (bought from eBay, from Amazon UK) are clones with higher power consumption. Some of them use 3mA, some have electrical short, ...
      • AnticimexA Anticimex
        ximinezX
        ximinezX
        ximinez
        @Anticimex I've set MY_SIGNING_SOFT, MY_SIGNING_REQUEST_SIGNATURES and MY_SIGNING_NODE_WHITELIST on the GW, and reenabled (normal) debug but not signing debug since that is too big.
        With those enabled, if the sending node does not sign, I should not get this?
        0;255;3;0;9;read: 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:6.3
        0;255;3;0;9;read: 2-2-0 s=2,c=1,t=1,pt=2,l=2,sg=0:59
        AnticimexA 1 Reply Last reply
        • ximinezX ximinez
          AnticimexA
          AnticimexA
          Anticimex
          @ximinez The GW will only require signatures from a node that in turn require signatures.
          It is the sg-flag that indicate if a message is signed, in your case, both messages are unsigned.
          If you only have node->gw communication, both gw and node has to require signatures for you to see signed messages.
          If you have gw->node communication, it is enough that the node require signatures, the gw will then sign them, no matter if the gw require signatures or not.
          • ximinezX
            ximinezX
            ximinez
            0;255;3;0;9;read: 3-3-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
            0;255;3;0;9;read: 3-3-0 s=2,c=3,t=16,pt=0,l=0,sg=0:
            0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:57ACB4BD46843BFCC7ABA693CC5AA527F7724531F525338E8A
            0;255;3;0;9;read: 3-3-0 s=2,c=0,t=7,pt=0,l=0,sg=0:
            I feel more secure now :-P
            • ximinezX ximinez
              AnticimexA
              AnticimexA
              Anticimex
              @ximinez Hm, good, but I still see no signed message. But at least a nonce was sent
                ximinezX
                ximinezX
                ximinez
                @Anticimex Sensor values are getting through though. And signing is requested on both ends (for one sensor so far). I can't see any other #defines that should be set to enable signing. I get the same result on both the zombie sensor and the unmodded one.
                I get three "sign fail" (showing up as verify fail on gw) before the sketch reaches setup(), where the ATSHA gets powered up. I will need to power the ATSHA somewhere in the mysensors library. However, once setup() is reached, the ATSHA seems to handle powering down and up just fine.
                I can however say that it the Si7021 doesn't like being powered off and back on again after sleep. That causes the MCU to reset.
                • ximinezX ximinez
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @ximinez Ah, yes, on development branch the signing backend clear the sign flag when it verifies the message. so it will always show as 0 without verbose signing debug enabled.
                  I know there have been discussions about a "pre setup" to be used for early sketch init. You probably want to power the atsha for early handshaking as well to get the sketch name and such to propagate properly. @hek perhaps has the latest on such features.
                    ximinezX
                    ximinezX
                    ximinez
                    wrote on last edited by ximinez
                    #439
                    I've built a nicer-looking serial gateway instead of the rather large ethernet gateway. I thought that would basically be a "slot-in" as long as I personalize the GW it with the same SOFT_HMAC_KEY, SOFT_SERIAL and AES_KEY as the original GW. Are there more steps that need to be taken to get the sensors to connect?
                    Serial Gateway
                    • ximinezX
                      ximinezX
                      ximinez
                      No matter what I do now, this is what I get:
                      send: 2-2-0-0 s=1,c=3,t=16,pt=0,l=0,sg=0,st=fail:
                      sign fail
                      send: 2-2-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=fail:26.0
                      send: 2-2-0-0 s=2,c=3,t=16,pt=0,l=0,sg=0,st=fail:
                      sign fail
                      send: 2-2-0-0 s=2,c=1,t=1,pt=2,l=2,sg=0,st=fail:34
                      send: 2-2-0-0 s=255,c=3,t=16,pt=0,l=0,sg=0,st=fail:
                      sign fail
                      • AnticimexA
                        AnticimexA
                        Anticimex
                        You must not use the same serial across nodes. Serial have to be unique. HMAC have to be identical.
                        • ximinezX
                          ximinezX
                          ximinez
                          Yes, I know serial must be unique. Serials go in the whitelist for the corresponding node ID. It turned out to be the NRF24L01+-modules with antennas. Replaced it with a regular module and it worked fine.
                          (Which is strange, because one of those modules worked fine on the ethernet gw. It doesn't eat that much power does it?)
                          • ximinezX ximinez
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @ximinez The signing failing is due to messages not arriving (st=fail). So it is not signing that is your problem here.
                            However, with signing, messages are now "full size" which strains the RF link so if it is "weak" fewer messages get through if they are "longer". I suspect that is the problem here. Basically the usual stuff; adding caps, using a dedicated regulator and so on...
                            • ximinezX
                              ximinezX
                              ximinez
                              Looks like it works now, but what's the deal with the initial failed signs? Look at http://pastebin.ca/3585005 (GW side) and http://pastebin.ca/3585014 (Sensor side. Not the same powerup). It starts by failing a lot, then after a while everything looks OK.
                              AnticimexA alexsh1A 2 Replies Last reply
                              • ximinezX ximinez
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @ximinez difficult to say. Maybe a long stabilization period for the regulator. You could try to add a delay in early init in the library to see if it makes a difference.
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @Anticimex and again, it is not failed signature errors per se. It is st=fail (transmission errors) that cause the signing backend to timeout. So it is not the performance of the atsha (or sw) that cause the issue here, it is the radio.
                                  • tbowmoT tbowmo
                                    @ximinez
                                    For my battery reporting, I have set 1.9V as 0%, 3.3V is 100%..
                                    While you're at it, also power down the external flash, as it might also contribute a bit..
                                    ximinezX
                                    ximinezX
                                    ximinez
                                    @tbowmo said:
                                    @ximinez
                                    I forgot about the flash. That would require bootloader support though? Or is the OTA done by jumping to the bootloader while running, keeping pin states?
                                    I'm waiting for some SOIC breakouts in the mail. When I get them, I'll scavenge the ATSHA and flash module from my zombie sensor and build my own sensebender with blackjack and hookers.
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @ximinez
                                      Yes.. bootloader should probably by modified, if you decide to switch off the flash as well..
                                      • G
                                        G
                                        gloob
                                        wrote on last edited by gloob
                                        #449
                                        I did update the Arduino IDE and now I don't see the Sensebender Micro in the device list.
                                        I'm using 1.6.5 and did copy the content to the boards.txt.
                                        Is there something else I have to do?
                                        # See: http://code.google.com/p/arduino/wiki/Platforms
                                        menu.cpu=Processor
                                        yun.name=Arduino Yún
                                        yun.upload.via_ssh=true
                                        yun.vid.0=0x2341
                                        yun.pid.0=0x0041
                                        yun.vid.1=0x2341
                                        yun.pid.1=0x8041
                                        yun.vid.2=0x2A03
                                        yun.pid.2=0x0041
                                        yun.vid.3=0x2A03
                                        yun.pid.3=0x8041
                                        yun.upload.tool=avrdude
                                        yun.upload.protocol=avr109
                                        yun.upload.maximum_size=28672
                                        yun.upload.maximum_data_size=2560
                                        yun.upload.speed=57600
                                        yun.upload.disable_flushing=true
                                        yun.upload.use_1200bps_touch=true
                                        yun.upload.wait_for_upload_port=true
                                        yun.bootloader.tool=avrdude
                                        yun.bootloader.low_fuses=0xff
                                        yun.bootloader.high_fuses=0xd8
                                        yun.bootloader.extended_fuses=0xfb
                                        yun.bootloader.file=caterina/Caterina-Yun.hex
                                        yun.bootloader.unlock_bits=0x3F
                                        yun.bootloader.lock_bits=0x2F
                                        yun.build.mcu=atmega32u4
                                        yun.build.f_cpu=16000000L
                                        yun.build.vid=0x2341
                                        yun.build.pid=0x8041
                                        yun.build.usb_product="Arduino Yun"
                                        yun.build.board=AVR_YUN
                                        yun.build.core=arduino
                                        yun.build.variant=yun
                                        yun.build.extra_flags={build.usb_flags}
                                        uno.name=Arduino/Genuino Uno
                                        uno.vid.0=0x2341
                                        uno.pid.0=0x0043
                                        uno.vid.1=0x2341
                                        uno.pid.1=0x0001
                                        uno.vid.2=0x2A03
                                        uno.pid.2=0x0043
                                        uno.vid.3=0x2341
                                        uno.pid.3=0x0243
                                        uno.upload.tool=avrdude
                                        uno.upload.protocol=arduino
                                        uno.upload.maximum_size=32256
                                        uno.upload.maximum_data_size=2048
                                        uno.upload.speed=115200
                                        uno.bootloader.tool=avrdude
                                        uno.bootloader.low_fuses=0xFF
                                        uno.bootloader.high_fuses=0xDE
                                        uno.bootloader.extended_fuses=0x05
                                        uno.bootloader.unlock_bits=0x3F
                                        uno.bootloader.lock_bits=0x0F
                                        uno.bootloader.file=optiboot/optiboot_atmega328.hex
                                        uno.build.mcu=atmega328p
                                        uno.build.f_cpu=16000000L
                                        uno.build.board=AVR_UNO
                                        uno.build.core=arduino
                                        uno.build.variant=standard
                                        diecimila.name=Arduino Duemilanove or Diecimila
                                        diecimila.upload.tool=avrdude
                                        diecimila.upload.protocol=arduino
                                        diecimila.bootloader.tool=avrdude
                                        diecimila.bootloader.low_fuses=0xFF
                                        diecimila.bootloader.unlock_bits=0x3F
                                        diecimila.bootloader.lock_bits=0x0F
                                        diecimila.build.f_cpu=16000000L
                                        diecimila.build.board=AVR_DUEMILANOVE
                                        diecimila.build.core=arduino
                                        diecimila.build.variant=standard
                                        ## Arduino Duemilanove or Diecimila w/ ATmega328
                                        diecimila.menu.cpu.atmega328=ATmega328
                                        diecimila.menu.cpu.atmega328.upload.maximum_size=30720
                                        diecimila.menu.cpu.atmega328.upload.maximum_data_size=2048
                                        diecimila.menu.cpu.atmega328.upload.speed=57600
                                        diecimila.menu.cpu.atmega328.bootloader.high_fuses=0xDA
                                        diecimila.menu.cpu.atmega328.bootloader.extended_fuses=0x05
                                        diecimila.menu.cpu.atmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328.hex
                                        diecimila.menu.cpu.atmega328.build.mcu=atmega328p
                                        ## Arduino Duemilanove or Diecimila w/ ATmega168
                                        diecimila.menu.cpu.atmega168=ATmega168
                                        diecimila.menu.cpu.atmega168.upload.maximum_size=14336
                                        diecimila.menu.cpu.atmega168.upload.maximum_data_size=1024
                                        diecimila.menu.cpu.atmega168.upload.speed=19200
                                        diecimila.menu.cpu.atmega168.bootloader.high_fuses=0xdd
                                        diecimila.menu.cpu.atmega168.bootloader.extended_fuses=0x00
                                        diecimila.menu.cpu.atmega168.bootloader.file=atmega/ATmegaBOOT_168_diecimila.hex
                                        diecimila.menu.cpu.atmega168.build.mcu=atmega168
                                        nano.name=Arduino Nano
                                        nano.upload.tool=avrdude
                                        nano.upload.protocol=arduino
                                        nano.bootloader.tool=avrdude
                                        nano.build.f_cpu=16000000L
                                        nano.build.board=AVR_NANO
                                        nano.build.core=arduino
                                        ## Arduino Nano w/ ATmega328
                                        nano.menu.cpu.atmega328=ATmega328
                                        nano.menu.cpu.atmega328.upload.maximum_size=30720
                                        nano.menu.cpu.atmega328.upload.maximum_data_size=2048
                                        nano.menu.cpu.atmega328.upload.speed=57600
                                        nano.menu.cpu.atmega328.bootloader.high_fuses=0xDA
                                        nano.menu.cpu.atmega328.bootloader.extended_fuses=0x05
                                        nano.menu.cpu.atmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328.hex
                                        nano.menu.cpu.atmega328.build.mcu=atmega328p
                                        ## Arduino Nano w/ ATmega168
                                        nano.menu.cpu.atmega168=ATmega168
                                        nano.menu.cpu.atmega168.upload.maximum_size=14336
                                        nano.menu.cpu.atmega168.upload.maximum_data_size=1024
                                        nano.menu.cpu.atmega168.upload.speed=19200
                                        nano.menu.cpu.atmega168.bootloader.low_fuses=0xff
                                        nano.menu.cpu.atmega168.bootloader.high_fuses=0xdd
                                        nano.menu.cpu.atmega168.bootloader.extended_fuses=0x00
                                        nano.menu.cpu.atmega168.bootloader.file=atmega/ATmegaBOOT_168_diecimila.hex
                                        nano.menu.cpu.atmega168.build.mcu=atmega168
                                        mega.name=Arduino/Genuino Mega or Mega 2560
                                        mega.vid.0=0x2341
                                        mega.pid.0=0x0010
                                        mega.vid.1=0x2341
                                        mega.pid.1=0x0042
                                        mega.vid.2=0x2A03
                                        mega.pid.2=0x0010
                                        mega.vid.3=0x2A03
                                        mega.pid.3=0x0042
                                        mega.vid.4=0x2341
                                        mega.pid.4=0x0210
                                        mega.vid.5=0x2341
                                        mega.pid.5=0x0242
                                        mega.upload.tool=avrdude
                                        mega.upload.maximum_data_size=8192
                                        mega.bootloader.tool=avrdude
                                        mega.bootloader.low_fuses=0xFF
                                        mega.bootloader.unlock_bits=0x3F
                                        mega.bootloader.lock_bits=0x0F
                                        mega.build.f_cpu=16000000L
                                        mega.build.core=arduino
                                        mega.build.variant=mega
                                        # default board may be overridden by the cpu menu
                                        mega.build.board=AVR_MEGA2560
                                        ## Arduino/Genuino Mega w/ ATmega2560
                                        mega.menu.cpu.atmega2560=ATmega2560 (Mega 2560)
                                        mega.menu.cpu.atmega2560.upload.protocol=wiring
                                        mega.menu.cpu.atmega2560.upload.maximum_size=253952
                                        mega.menu.cpu.atmega2560.upload.speed=115200
                                        mega.menu.cpu.atmega2560.bootloader.high_fuses=0xD8
                                        mega.menu.cpu.atmega2560.bootloader.extended_fuses=0xFD
                                        mega.menu.cpu.atmega2560.bootloader.file=stk500v2/stk500boot_v2_mega2560.hex
                                        mega.menu.cpu.atmega2560.build.mcu=atmega2560
                                        mega.menu.cpu.atmega2560.build.board=AVR_MEGA2560
                                        ## Arduino Mega w/ ATmega1280
                                        mega.menu.cpu.atmega1280=ATmega1280
                                        mega.menu.cpu.atmega1280.upload.protocol=arduino
                                        mega.menu.cpu.atmega1280.upload.maximum_size=126976
                                        mega.menu.cpu.atmega1280.upload.speed=57600
                                        mega.menu.cpu.atmega1280.bootloader.high_fuses=0xDA
                                        mega.menu.cpu.atmega1280.bootloader.extended_fuses=0xF5
                                        mega.menu.cpu.atmega1280.bootloader.file=atmega/ATmegaBOOT_168_atmega1280.hex
                                        mega.menu.cpu.atmega1280.build.mcu=atmega1280
                                        mega.menu.cpu.atmega1280.build.board=AVR_MEGA
                                        megaADK.name=Arduino Mega ADK
                                        megaADK.vid.0=0x2341
                                        megaADK.pid.0=0x003f
                                        megaADK.vid.1=0x2341
                                        megaADK.pid.1=0x0044
                                        megaADK.vid.2=0x2A03
                                        megaADK.pid.2=0x003f
                                        megaADK.vid.3=0x2A03
                                        megaADK.pid.3=0x0044
                                        megaADK.upload.tool=avrdude
                                        megaADK.upload.protocol=wiring
                                        megaADK.upload.maximum_size=253952
                                        megaADK.upload.maximum_data_size=8192
                                        megaADK.upload.speed=115200
                                        megaADK.bootloader.tool=avrdude
                                        megaADK.bootloader.low_fuses=0xFF
                                        megaADK.bootloader.high_fuses=0xD8
                                        megaADK.bootloader.extended_fuses=0xFD
                                        megaADK.bootloader.file=stk500v2/stk500boot_v2_mega2560.hex
                                        megaADK.bootloader.unlock_bits=0x3F
                                        megaADK.bootloader.lock_bits=0x0F
                                        megaADK.build.mcu=atmega2560
                                        megaADK.build.f_cpu=16000000L
                                        megaADK.build.board=AVR_ADK
                                        megaADK.build.core=arduino
                                        megaADK.build.variant=mega
                                        leonardo.name=Arduino Leonardo
                                        leonardo.vid.0=0x2341
                                        leonardo.pid.0=0x0036
                                        leonardo.vid.1=0x2341
                                        leonardo.pid.1=0x8036
                                        leonardo.vid.2=0x2A03
                                        leonardo.pid.2=0x0036
                                        leonardo.vid.3=0x2A03
                                        leonardo.pid.3=0x8036
                                        leonardo.upload.tool=avrdude
                                        leonardo.upload.protocol=avr109
                                        leonardo.upload.maximum_size=28672
                                        leonardo.upload.maximum_data_size=2560
                                        leonardo.upload.speed=57600
                                        leonardo.upload.disable_flushing=true
                                        leonardo.upload.use_1200bps_touch=true
                                        leonardo.upload.wait_for_upload_port=true
                                        leonardo.bootloader.tool=avrdude
                                        leonardo.bootloader.low_fuses=0xff
                                        leonardo.bootloader.high_fuses=0xd8
                                        leonardo.bootloader.extended_fuses=0xcb
                                        leonardo.bootloader.file=caterina/Caterina-Leonardo.hex
                                        leonardo.bootloader.unlock_bits=0x3F
                                        leonardo.bootloader.lock_bits=0x2F
                                        leonardo.build.mcu=atmega32u4
                                        leonardo.build.f_cpu=16000000L
                                        leonardo.build.vid=0x2341
                                        leonardo.build.pid=0x8036
                                        leonardo.build.usb_product="Arduino Leonardo"
                                        leonardo.build.board=AVR_LEONARDO
                                        leonardo.build.core=arduino
                                        leonardo.build.variant=leonardo
                                        leonardo.build.extra_flags={build.usb_flags}
                                        micro.name=Arduino/Genuino Micro
                                        micro.vid.0=0x2341
                                        micro.pid.0=0x0037
                                        micro.vid.1=0x2341
                                        micro.pid.1=0x8037
                                        micro.vid.2=0x2A03
                                        micro.pid.2=0x0037
                                        micro.vid.3=0x2A03
                                        micro.pid.3=0x8037
                                        micro.vid.4=0x2341
                                        micro.pid.4=0x0237
                                        # If the board is a 2341:0237 use 2341:8237 for build and set
                                        # other parameters as well
                                        micro.vid.4.build.vid=0x2341
                                        micro.vid.4.build.pid=0x8237
                                        micro.vid.4.build.usb_product="Genuino Micro"
                                        micro.vid.4.bootloader.file=caterina/Caterina-Genuino-Micro.hex
                                        micro.vid.5=0x2341
                                        micro.pid.5=0x8237
                                        # If the board is a 2341:8237 use 2341:8237 for build and set
                                        # other paramters as well
                                        micro.vid.5.build.vid=0x2341
                                        micro.vid.5.build.pid=0x8237
                                        micro.vid.5.build.usb_product="Genuino Micro"
                                        micro.vid.5.bootloader.file=caterina/Caterina-Genuino-Micro.hex
                                        micro.upload.tool=avrdude
                                        micro.upload.protocol=avr109
                                        micro.upload.maximum_size=28672
                                        micro.upload.maximum_data_size=2560
                                        micro.upload.speed=57600
                                        micro.upload.disable_flushing=true
                                        micro.upload.use_1200bps_touch=true
                                        micro.upload.wait_for_upload_port=true
                                        micro.bootloader.tool=avrdude
                                        micro.bootloader.low_fuses=0xff
                                        micro.bootloader.high_fuses=0xd8
                                        micro.bootloader.extended_fuses=0xcb
                                        micro.bootloader.file=caterina/Caterina-Micro.hex
                                        micro.bootloader.unlock_bits=0x3F
                                        micro.bootloader.lock_bits=0x2F
                                        micro.build.mcu=atmega32u4
                                        micro.build.f_cpu=16000000L
                                        micro.build.vid=0x2341
                                        micro.build.pid=0x8037
                                        micro.build.usb_product="Arduino Micro"
                                        micro.build.board=AVR_MICRO
                                        micro.build.core=arduino
                                        micro.build.variant=micro
                                        micro.build.extra_flags={build.usb_flags}
                                        esplora.name=Arduino Esplora
                                        esplora.vid.0=0x2341
                                        esplora.pid.0=0x003C
                                        esplora.vid.1=0x2341
                                        esplora.pid.1=0x803C
                                        esplora.vid.2=0x2A03
                                        esplora.pid.2=0x003C
                                        esplora.vid.3=0x2A03
                                        esplora.pid.3=0x803C
                                        esplora.upload.tool=avrdude
                                        esplora.upload.protocol=avr109
                                        esplora.upload.maximum_size=28672
                                        esplora.upload.maximum_data_size=2560
                                        esplora.upload.speed=57600
                                        esplora.upload.disable_flushing=true
                                        esplora.upload.use_1200bps_touch=true
                                        esplora.upload.wait_for_upload_port=true
                                        esplora.bootloader.tool=avrdude
                                        esplora.bootloader.low_fuses=0xff
                                        esplora.bootloader.high_fuses=0xd8
                                        esplora.bootloader.extended_fuses=0xcb
                                        esplora.bootloader.file=caterina/Caterina-Esplora.hex
                                        esplora.bootloader.unlock_bits=0x3F
                                        esplora.bootloader.lock_bits=0x2F
                                        esplora.build.mcu=atmega32u4
                                        esplora.build.f_cpu=16000000L
                                        esplora.build.vid=0x2341
                                        esplora.build.pid=0x803c
                                        esplora.build.usb_product="Arduino Esplora"
                                        esplora.build.board=AVR_ESPLORA
                                        esplora.build.core=arduino
                                        esplora.build.variant=leonardo
                                        esplora.build.extra_flags={build.usb_flags}
                                        mini.name=Arduino Mini
                                        mini.upload.tool=avrdude
                                        mini.upload.protocol=arduino
                                        mini.bootloader.tool=avrdude
                                        mini.bootloader.low_fuses=0xff
                                        mini.bootloader.unlock_bits=0x3F
                                        mini.bootloader.lock_bits=0x0F
                                        mini.build.f_cpu=16000000L
                                        mini.build.board=AVR_MINI
                                        mini.build.core=arduino
                                        mini.build.variant=eightanaloginputs
                                        ## Arduino Mini w/ ATmega328
                                        mini.menu.cpu.atmega328=ATmega328
                                        mini.menu.cpu.atmega328.upload.maximum_size=28672
                                        mini.menu.cpu.atmega328.upload.maximum_data_size=2048
                                        mini.menu.cpu.atmega328.upload.speed=115200
                                        mini.menu.cpu.atmega328.bootloader.high_fuses=0xd8
                                        mini.menu.cpu.atmega328.bootloader.extended_fuses=0x05
                                        mini.menu.cpu.atmega328.bootloader.file=optiboot/optiboot_atmega328-Mini.hex
                                        mini.menu.cpu.atmega328.build.mcu=atmega328p
                                        ## Arduino Mini w/ ATmega168
                                        mini.menu.cpu.atmega168=ATmega168
                                        mini.menu.cpu.atmega168.upload.maximum_size=14336
                                        mini.menu.cpu.atmega168.upload.maximum_data_size=1024
                                        mini.menu.cpu.atmega168.upload.speed=19200
                                        mini.menu.cpu.atmega168.bootloader.high_fuses=0xdd
                                        mini.menu.cpu.atmega168.bootloader.extended_fuses=0x00
                                        mini.menu.cpu.atmega168.bootloader.file=atmega/ATmegaBOOT_168_ng.hex
                                        mini.menu.cpu.atmega168.build.mcu=atmega168
                                        ethernet.name=Arduino Ethernet
                                        ethernet.upload.tool=avrdude
                                        ethernet.upload.protocol=arduino
                                        ethernet.upload.maximum_size=32256
                                        ethernet.upload.maximum_data_size=2048
                                        ethernet.upload.speed=115200
                                        ethernet.bootloader.tool=avrdude
                                        ethernet.bootloader.low_fuses=0xff
                                        ethernet.bootloader.high_fuses=0xde
                                        ethernet.bootloader.extended_fuses=0x05
                                        ethernet.bootloader.file=optiboot/optiboot_atmega328.hex
                                        ethernet.bootloader.unlock_bits=0x3F
                                        ethernet.bootloader.lock_bits=0x0F
                                        ethernet.build.variant=ethernet
                                        ethernet.build.mcu=atmega328p
                                        ethernet.build.f_cpu=16000000L
                                        ethernet.build.board=AVR_ETHERNET
                                        ethernet.build.core=arduino
                                        fio.name=Arduino Fio
                                        fio.upload.tool=avrdude
                                        fio.upload.protocol=arduino
                                        fio.upload.maximum_size=30720
                                        fio.upload.maximum_data_size=2048
                                        fio.upload.speed=57600
                                        fio.bootloader.tool=avrdude
                                        fio.bootloader.low_fuses=0xFF
                                        fio.bootloader.high_fuses=0xDA
                                        fio.bootloader.extended_fuses=0x05
                                        fio.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
                                        fio.bootloader.unlock_bits=0x3F
                                        fio.bootloader.lock_bits=0x0F
                                        fio.build.mcu=atmega328p
                                        fio.build.f_cpu=8000000L
                                        fio.build.board=AVR_FIO
                                        fio.build.core=arduino
                                        fio.build.variant=eightanaloginputs
                                        bt.name=Arduino BT
                                        bt.upload.tool=avrdude
                                        bt.upload.protocol=arduino
                                        bt.upload.speed=19200
                                        bt.upload.disable_flushing=true
                                        bt.bootloader.tool=avrdude
                                        bt.bootloader.low_fuses=0xff
                                        bt.bootloader.unlock_bits=0x3F
                                        bt.bootloader.lock_bits=0x0F
                                        bt.build.f_cpu=16000000L
                                        bt.build.board=AVR_BT
                                        bt.build.core=arduino
                                        bt.build.variant=eightanaloginputs
                                        ## Arduino BT w/ ATmega328
                                        bt.menu.cpu.atmega328=ATmega328
                                        bt.menu.cpu.atmega328.upload.maximum_size=28672
                                        bt.menu.cpu.atmega328.upload.maximum_data_size=2048
                                        bt.menu.cpu.atmega328.bootloader.high_fuses=0xd8
                                        bt.menu.cpu.atmega328.bootloader.extended_fuses=0x05
                                        bt.menu.cpu.atmega328.bootloader.file=bt/ATmegaBOOT_168_atmega328_bt.hex
                                        bt.menu.cpu.atmega328.build.mcu=atmega328p
                                        ## Arduino BT w/ ATmega168
                                        bt.menu.cpu.atmega168=ATmega168
                                        bt.menu.cpu.atmega168.upload.maximum_size=14336
                                        bt.menu.cpu.atmega168.upload.maximum_data_size=1024
                                        bt.menu.cpu.atmega168.bootloader.high_fuses=0xdd
                                        bt.menu.cpu.atmega168.bootloader.extended_fuses=0x00
                                        bt.menu.cpu.atmega168.bootloader.file=bt/ATmegaBOOT_168.hex
                                        bt.menu.cpu.atmega168.build.mcu=atmega168
                                        LilyPadUSB.name=LilyPad Arduino USB
                                        LilyPadUSB.vid.0=0x1B4F
                                        LilyPadUSB.pid.0=0x9207
                                        LilyPadUSB.vid.1=0x1B4F
                                        LilyPadUSB.pid.1=0x9208
                                        LilyPadUSB.upload.tool=avrdude
                                        LilyPadUSB.upload.protocol=avr109
                                        LilyPadUSB.upload.maximum_size=28672
                                        LilyPadUSB.upload.maximum_data_size=2560
                                        LilyPadUSB.upload.speed=57600
                                        LilyPadUSB.upload.disable_flushing=true
                                        LilyPadUSB.upload.use_1200bps_touch=true
                                        LilyPadUSB.upload.wait_for_upload_port=true
                                        LilyPadUSB.bootloader.tool=avrdude
                                        LilyPadUSB.bootloader.low_fuses=0xff
                                        LilyPadUSB.bootloader.high_fuses=0xd8
                                        LilyPadUSB.bootloader.extended_fuses=0xce
                                        LilyPadUSB.bootloader.file=caterina-LilyPadUSB/Caterina-LilyPadUSB.hex
                                        LilyPadUSB.bootloader.unlock_bits=0x3F
                                        LilyPadUSB.bootloader.lock_bits=0x2F
                                        LilyPadUSB.build.mcu=atmega32u4
                                        LilyPadUSB.build.f_cpu=8000000L
                                        LilyPadUSB.build.vid=0x1B4F
                                        LilyPadUSB.build.pid=0x9208
                                        LilyPadUSB.build.usb_product="LilyPad USB"
                                        LilyPadUSB.build.board=AVR_LILYPAD_USB
                                        LilyPadUSB.build.core=arduino
                                        LilyPadUSB.build.variant=leonardo
                                        LilyPadUSB.build.extra_flags={build.usb_flags}
                                        lilypad.name=LilyPad Arduino
                                        lilypad.upload.tool=avrdude
                                        lilypad.upload.protocol=arduino
                                        lilypad.bootloader.tool=avrdude
                                        lilypad.bootloader.unlock_bits=0x3F
                                        lilypad.bootloader.lock_bits=0x0F
                                        lilypad.build.f_cpu=8000000L
                                        lilypad.build.board=AVR_LILYPAD
                                        lilypad.build.core=arduino
                                        lilypad.build.variant=standard
                                        ## LilyPad Arduino w/ ATmega328
                                        lilypad.menu.cpu.atmega328=ATmega328
                                        lilypad.menu.cpu.atmega328.upload.maximum_size=30720
                                        lilypad.menu.cpu.atmega328.upload.maximum_data_size=2048
                                        lilypad.menu.cpu.atmega328.upload.speed=57600
                                        lilypad.menu.cpu.atmega328.bootloader.low_fuses=0xFF
                                        lilypad.menu.cpu.atmega328.bootloader.high_fuses=0xDA
                                        lilypad.menu.cpu.atmega328.bootloader.extended_fuses=0x05
                                        lilypad.menu.cpu.atmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
                                        lilypad.menu.cpu.atmega328.build.mcu=atmega328p
                                        ## LilyPad Arduino w/ ATmega168
                                        lilypad.menu.cpu.atmega168=ATmega168
                                        lilypad.menu.cpu.atmega168.upload.maximum_size=14336
                                        lilypad.menu.cpu.atmega168.upload.maximum_data_size=1024
                                        lilypad.menu.cpu.atmega168.upload.speed=19200
                                        lilypad.menu.cpu.atmega168.bootloader.low_fuses=0xe2
                                        lilypad.menu.cpu.atmega168.bootloader.high_fuses=0xdd
                                        lilypad.menu.cpu.atmega168.bootloader.extended_fuses=0x00
                                        lilypad.menu.cpu.atmega168.bootloader.file=lilypad/LilyPadBOOT_168.hex
                                        lilypad.menu.cpu.atmega168.build.mcu=atmega168
                                        pro.name=Arduino Pro or Pro Mini
                                        pro.upload.tool=avrdude
                                        pro.upload.protocol=arduino
                                        pro.bootloader.tool=avrdude
                                        pro.bootloader.unlock_bits=0x3F
                                        pro.bootloader.lock_bits=0x0F
                                        pro.build.board=AVR_PRO
                                        pro.build.core=arduino
                                        pro.build.variant=eightanaloginputs
                                        ## Arduino Pro or Pro Mini (5V, 16 MHz) w/ ATmega328
                                        pro.menu.cpu.16MHzatmega328=ATmega328 (5V, 16 MHz)
                                        pro.menu.cpu.16MHzatmega328.upload.maximum_size=30720
                                        pro.menu.cpu.16MHzatmega328.upload.maximum_data_size=2048
                                        pro.menu.cpu.16MHzatmega328.upload.speed=57600
                                        pro.menu.cpu.16MHzatmega328.bootloader.low_fuses=0xFF
                                        pro.menu.cpu.16MHzatmega328.bootloader.high_fuses=0xDA
                                        pro.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0x05
                                        pro.menu.cpu.16MHzatmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328.hex
                                        pro.menu.cpu.16MHzatmega328.build.mcu=atmega328p
                                        pro.menu.cpu.16MHzatmega328.build.f_cpu=16000000L
                                        ## Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega328
                                        pro.menu.cpu.8MHzatmega328=ATmega328 (3.3V, 8 MHz)
                                        pro.menu.cpu.8MHzatmega328.upload.maximum_size=30720
                                        pro.menu.cpu.8MHzatmega328.upload.maximum_data_size=2048
                                        pro.menu.cpu.8MHzatmega328.upload.speed=57600
                                        pro.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xFF
                                        pro.menu.cpu.8MHzatmega328.bootloader.high_fuses=0xDA
                                        pro.menu.cpu.8MHzatmega328.bootloader.extended_fuses=0x05
                                        pro.menu.cpu.8MHzatmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
                                        pro.menu.cpu.8MHzatmega328.build.mcu=atmega328p
                                        pro.menu.cpu.8MHzatmega328.build.f_cpu=8000000L
                                        ## Arduino Pro or Pro Mini (5V, 16 MHz) w/ ATmega168
                                        pro.menu.cpu.16MHzatmega168=ATmega168 (5V, 16 MHz)
                                        pro.menu.cpu.16MHzatmega168.upload.maximum_size=14336
                                        pro.menu.cpu.16MHzatmega168.upload.maximum_data_size=1024
                                        pro.menu.cpu.16MHzatmega168.upload.speed=19200
                                        pro.menu.cpu.16MHzatmega168.bootloader.low_fuses=0xff
                                        pro.menu.cpu.16MHzatmega168.bootloader.high_fuses=0xdd
                                        pro.menu.cpu.16MHzatmega168.bootloader.extended_fuses=0x00
                                        pro.menu.cpu.16MHzatmega168.bootloader.file=atmega/ATmegaBOOT_168_diecimila.hex
                                        pro.menu.cpu.16MHzatmega168.build.mcu=atmega168
                                        pro.menu.cpu.16MHzatmega168.build.f_cpu=16000000L
                                        ## Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega168
                                        pro.menu.cpu.8MHzatmega168=ATmega168 (3.3V, 8 MHz)
                                        pro.menu.cpu.8MHzatmega168.upload.maximum_size=14336
                                        pro.menu.cpu.8MHzatmega168.upload.maximum_data_size=1024
                                        pro.menu.cpu.8MHzatmega168.upload.speed=19200
                                        pro.menu.cpu.8MHzatmega168.bootloader.low_fuses=0xc6
                                        pro.menu.cpu.8MHzatmega168.bootloader.high_fuses=0xdd
                                        pro.menu.cpu.8MHzatmega168.bootloader.extended_fuses=0x00
                                        pro.menu.cpu.8MHzatmega168.bootloader.file=atmega/ATmegaBOOT_168_pro_8MHz.hex
                                        pro.menu.cpu.8MHzatmega168.build.mcu=atmega168
                                        pro.menu.cpu.8MHzatmega168.build.f_cpu=8000000L
                                        atmegang.name=Arduino NG or older
                                        atmegang.upload.tool=avrdude
                                        atmegang.upload.protocol=arduino
                                        atmegang.upload.speed=19200
                                        atmegang.bootloader.tool=avrdude
                                        atmegang.bootloader.unlock_bits=0x3F
                                        atmegang.bootloader.lock_bits=0x0F
                                        atmegang.build.mcu=atmegang
                                        atmegang.build.f_cpu=16000000L
                                        atmegang.build.board=AVR_NG
                                        atmegang.build.core=arduino
                                        atmegang.build.variant=standard
                                        ## Arduino NG or older w/ ATmega168
                                        atmegang.menu.cpu.atmega168=ATmega168
                                        atmegang.menu.cpu.atmega168.upload.maximum_size=14336
                                        atmegang.menu.cpu.atmega168.upload.maximum_data_size=1024
                                        atmegang.menu.cpu.atmega168.bootloader.low_fuses=0xff
                                        atmegang.menu.cpu.atmega168.bootloader.high_fuses=0xdd
                                        atmegang.menu.cpu.atmega168.bootloader.extended_fuses=0x00
                                        atmegang.menu.cpu.atmega168.bootloader.file=atmega/ATmegaBOOT_168_ng.hex
                                        atmegang.menu.cpu.atmega168.build.mcu=atmega168
                                        ## Arduino NG or older w/ ATmega8
                                        atmegang.menu.cpu.atmega8=ATmega8
                                        atmegang.menu.cpu.atmega8.upload.maximum_size=7168
                                        atmegang.menu.cpu.atmega8.upload.maximum_data_size=1024
                                        atmegang.menu.cpu.atmega8.bootloader.low_fuses=0xdf
                                        atmegang.menu.cpu.atmega8.bootloader.high_fuses=0xca
                                        atmegang.menu.cpu.atmega8.bootloader.file=atmega8/ATmegaBOOT-prod-firmware-2009-11-07.hex
                                        atmegang.menu.cpu.atmega8.build.mcu=atmega8
                                        robotControl.name=Arduino Robot Control
                                        robotControl.vid.0=0x2341
                                        robotControl.pid.0=0x0038
                                        robotControl.vid.1=0x2341
                                        robotControl.pid.1=0x8038
                                        robotControl.vid.2=0x2A03
                                        robotControl.pid.2=0x0038
                                        robotControl.vid.3=0x2A03
                                        robotControl.pid.3=0x8038
                                        robotControl.upload.tool=avrdude
                                        robotControl.upload.protocol=avr109
                                        robotControl.upload.maximum_size=28672
                                        robotControl.upload.maximum_data_size=2560
                                        robotControl.upload.speed=57600
                                        robotControl.upload.disable_flushing=true
                                        robotControl.upload.use_1200bps_touch=true
                                        robotControl.upload.wait_for_upload_port=true
                                        robotControl.bootloader.tool=avrdude
                                        robotControl.bootloader.low_fuses=0xff
                                        robotControl.bootloader.high_fuses=0xd8
                                        robotControl.bootloader.extended_fuses=0xcb
                                        robotControl.bootloader.file=caterina-Arduino_Robot/Caterina-Robot-Control.hex
                                        robotControl.bootloader.unlock_bits=0x3F
                                        robotControl.bootloader.lock_bits=0x2F
                                        robotControl.build.mcu=atmega32u4
                                        robotControl.build.f_cpu=16000000L
                                        robotControl.build.vid=0x2341
                                        robotControl.build.pid=0x8038
                                        robotControl.build.usb_product="Robot Control"
                                        robotControl.build.board=AVR_ROBOT_CONTROL
                                        robotControl.build.core=arduino
                                        robotControl.build.variant=robot_control
                                        robotControl.build.extra_flags={build.usb_flags}
                                        robotMotor.name=Arduino Robot Motor
                                        robotMotor.vid.0=0x2341
                                        robotMotor.pid.0=0x0039
                                        robotMotor.vid.1=0x2341
                                        robotMotor.pid.1=0x8039
                                        robotMotor.vid.2=0x2A03
                                        robotMotor.pid.2=0x0039
                                        robotMotor.vid.3=0x2A03
                                        robotMotor.pid.3=0x8039
                                        robotMotor.upload.tool=avrdude
                                        robotMotor.upload.protocol=avr109
                                        robotMotor.upload.maximum_size=28672
                                        robotMotor.upload.maximum_data_size=2560
                                        robotMotor.upload.speed=57600
                                        robotMotor.upload.disable_flushing=true
                                        robotMotor.upload.use_1200bps_touch=true
                                        robotMotor.upload.wait_for_upload_port=true
                                        robotMotor.bootloader.tool=avrdude
                                        robotMotor.bootloader.low_fuses=0xff
                                        robotMotor.bootloader.high_fuses=0xd8
                                        robotMotor.bootloader.extended_fuses=0xcb
                                        robotMotor.bootloader.file=caterina-Arduino_Robot/Caterina-Robot-Motor.hex
                                        robotMotor.bootloader.unlock_bits=0x3F
                                        robotMotor.bootloader.lock_bits=0x2F
                                        robotMotor.build.mcu=atmega32u4
                                        robotMotor.build.f_cpu=16000000L
                                        robotMotor.build.vid=0x2341
                                        robotMotor.build.pid=0x8039
                                        robotMotor.build.usb_product="Robot Motor"
                                        robotMotor.build.board=AVR_ROBOT_MOTOR
                                        robotMotor.build.core=arduino
                                        robotMotor.build.variant=robot_motor
                                        robotMotor.build.extra_flags={build.usb_flags}
                                        gemma.vid.0=0x2341
                                        gemma.pid.0=0x0c9f
                                        gemma.name=Arduino Gemma
                                        gemma.bootloader.low_fuses=0xF1
                                        gemma.bootloader.high_fuses=0xD5
                                        gemma.bootloader.extended_fuses=0xFE
                                        gemma.bootloader.tool=avrdude
                                        gemma.bootloader.lock_bits=
                                        gemma.bootloader.unlock_bits=
                                        gemma.bootloader.file=gemma/gemma_v1.hex
                                        gemma.build.mcu=attiny85
                                        gemma.build.f_cpu=8000000L
                                        gemma.build.core=arduino
                                        gemma.build.variant=gemma
                                        gemma.build.board=AVR_GEMMA
                                        gemma.upload.tool=avrdude
                                        gemma.upload.maximum_size=5310
                                        menu.cpu=Processor
                                        ## Sensebender Micro
                                        MysensorsMicro.name=Sensebender Micro
                                        MysensorsMicro.upload.tool=arduino:avrdude
                                        MysensorsMicro.upload.protocol=arduino
                                        MysensorsMicro.upload.maximum_size=30720
                                        MysensorsMicro.upload.maximum_data_size=2048
                                        MysensorsMicro.upload.speed=57600
                                        MysensorsMicro.bootloader.tool=arduino:avrdude
                                        MysensorsMicro.bootloader.unlock_bits=0x3F
                                        MysensorsMicro.bootloader.lock_bits=0x0F
                                        MysensorsMicro.bootloader.low_fuses=0xE2
                                        MysensorsMicro.bootloader.high_fuses=0xD2
                                        MysensorsMicro.bootloader.extended_fuses=0x06
                                        MysensorsMicro.bootloader.file=DualOptiboot/optiboot_atmega328_pro_8MHz.hex
                                        MysensorsMicro.build.board=AVR_MICRO8
                                        MysensorsMicro.build.core=arduino:arduino
                                        MysensorsMicro.build.variant=micro
                                        MysensorsMicro.build.mcu=atmega328p
                                        #MysensorsMicro.build.f_cpu=8000000L
                                        MysensorsMicro.menu.cpu.8Mhz=Atmega328 8Mhz
                                        MysensorsMicro.menu.cpu.8Mhz.build.f_cpu=8000000L
                                        MysensorsMicro.menu.cpu.1Mhz=Atmega328 1Mhz
                                        MysensorsMicro.menu.cpu.1Mhz.build.f_cpu=1000000L
                                        I'm using a Mac if it is important.
                                        • A
                                          alexeinz
                                          Is it possible to use the ftdi or isp vcc / gnd to connect a pir ?
                                          or do i need to source separate power and gnd for pir ?
                                          mqtt gw 1.4 /openhab / zwave
