  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 658.9k Views 35 Watching
  • ximinezX ximinez
    Writing key to slot 0...
    Data not locked. Define LOCK_DATA to lock for real.
    Configuration is LOCKED
    Data is UNLOCKED
    AnticimexA
    AnticimexA
    Anticimex
    @ximinez looks good. You should be done with personalization. Remember to require signatures from the SenseBender in addition to "enabling" it. You can also require signature on the GW, thus forcing all communications between them to be signed. The serial console will reveal how it goes. You can enable verbose debug (MY_DEBUG_VERBOSE_SIGNING) for the signing if you want more details on the signing parts.
    • ximinezX
      ximinezX
      ximinez
      I have the sensor sketch mostly done, but I'll have to do some soldering again tomorrow. It looks like D7 got burnt when I plugged in my ESP8266, giving ~0,5v out on that pin. Will have to work around that:
      Sôártinç óensor (RÎONA-, 2.0.0-beta)
      Raäio init æáiìåd. Ãèeck wiring.
      When that is OK, I'll look at the GW sketch.
      AnticimexA 1 Reply Last reply
      • ximinezX ximinez
        AnticimexA
        AnticimexA
        Anticimex
        Sounds good. Bedtime here too.
        • ximinezX
          ximinezX
          ximinez
          D3, D4 and D7 are all funky, and do not give ~3v when set high. So I'm back to the radio being on all the time.
          D5 and D6 mysteriously work just fine.
          Radio is now OK, but the sensebender reboots before it gets to setup().
          Stárting óensor (ÒÎONA-, 2.0.0-beôá)
          Ráäio init suããessæuì.
          æéîä parenô
          send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,óô=bc:
          [reboot and repeat]
          • tbowmoT
            tbowmoT
            tbowmo
            @ximinez
            Sounds like it's on its way to the "other side"..
            • ximinezX
              ximinezX
              ximinez
              Yup. Setting up my other sensebender as a proper signing sensor and my uno as a gateway. This will have to wait until I get a couple more working sensors.
              • ximinezX
                ximinezX
                ximinez
                Ok. I set up my GW, and set up my healthy sensebender as an outdoor sensor. The zombie sensor is now a working indoor sensor.
                I have enabled signing and set up whitelisting, but enabling signing debugging makes the sketch oversize, so I can't actually check if signing works - but atleast now I have two sensors.
                Domoticz up
                • AnticimexA
                  AnticimexA
                  Anticimex
                  You will still be notified without verbose logging. And if you have enabled and require signing, you won't get any data if something fails (assuming signing is properly activated).
                  ximinezX 1 Reply Last reply
                  • user2334U user2334
                    I just received two Sensebenders, but have problems getting the device to consume little power. I get totally different values as displayed above.
                    #include <LowPower.h>
                    #include "RF24.h"
                    RF24 radio(9, 10);
                        delay(8000);
                    user2334U
                    user2334U
                    user2334
                    #include "RF24.h"
                    RF24 radio(9, 10);
                        delay(8000);
                    As a follow-up to my previous posting, I can confirm, that using original nRF24-modules (best source seems to be https://www.itead.cc/nrf24l01-module.html), I get 0,023mA (=23µA) with nrf24 attached during sleep mode (no difference between the libraries JeeLib->Sleepy::loseSomeTime or LowPower->LowPower.powerDown).
                    It is quite interesting, that so many nRF24 Modules (bought from eBay, from Amazon UK) are clones with higher power consumption. Some of them use 3mA, some have electrical short, ...
                    • AnticimexA Anticimex
                      ximinezX
                      ximinezX
                      ximinez
                      @Anticimex I've set MY_SIGNING_SOFT, MY_SIGNING_REQUEST_SIGNATURES and MY_SIGNING_NODE_WHITELIST on the GW, and reenabled (normal) debug but not signing debug since that is too big.
                      With those enabled, if the sending node does not sign, I should not get this?
                      0;255;3;0;9;read: 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:6.3
                      0;255;3;0;9;read: 2-2-0 s=2,c=1,t=1,pt=2,l=2,sg=0:59
                      • ximinezX ximinez
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @ximinez The GW will only require signatures from a node that in turn require signatures.
                        It is the sg-flag that indicate if a message is signed, in your case, both messages are unsigned.
                        If you only have node->gw communication, both gw and node has to require signatures for you to see signed messages.
                        If you have gw->node communication, it is enough that the node require signatures, the gw will then sign them, no matter if the gw require signatures or not.
                        • ximinezX
                          ximinezX
                          ximinez
                          0;255;3;0;9;read: 3-3-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
                          0;255;3;0;9;read: 3-3-0 s=2,c=3,t=16,pt=0,l=0,sg=0:
                          0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:57ACB4BD46843BFCC7ABA693CC5AA527F7724531F525338E8A
                          0;255;3;0;9;read: 3-3-0 s=2,c=0,t=7,pt=0,l=0,sg=0:
                          I feel more secure now :-P
                          • ximinezX ximinez
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @ximinez Hm, good, but I still see no signed message. But at least a nonce was sent
                              ximinezX
                              ximinezX
                              ximinez
                              @Anticimex Sensor values are getting through though. And signing is requested on both ends (for one sensor so far). I can't see any other #defines that should be set to enable signing. I get the same result on both the zombie sensor and the unmodded one.
                              I get three "sign fail" (showing up as verify fail on gw) before the sketch reaches setup(), where the ATSHA gets powered up. I will need to power the ATSHA somewhere in the mysensors library. However, once setup() is reached, the ATSHA seems to handle powering down and up just fine.
                              I can however say that it the Si7021 doesn't like being powered off and back on again after sleep. That causes the MCU to reset.
                              • ximinezX ximinez
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @ximinez Ah, yes, on development branch the signing backend clear the sign flag when it verifies the message. so it will always show as 0 without verbose signing debug enabled.
                                I know there have been discussions about a "pre setup" to be used for early sketch init. You probably want to power the atsha for early handshaking as well to get the sketch name and such to propagate properly. @hek perhaps has the latest on such features.
                                  ximinezX
                                  ximinezX
                                  ximinez
                                  wrote on last edited by ximinez
                                  #439
                                  I've built a nicer-looking serial gateway instead of the rather large ethernet gateway. I thought that would basically be a "slot-in" as long as I personalize the GW it with the same SOFT_HMAC_KEY, SOFT_SERIAL and AES_KEY as the original GW. Are there more steps that need to be taken to get the sensors to connect?
                                  Serial Gateway
                                  • ximinezX
                                    ximinezX
                                    ximinez
                                    No matter what I do now, this is what I get:
                                    send: 2-2-0-0 s=1,c=3,t=16,pt=0,l=0,sg=0,st=fail:
                                    sign fail
                                    send: 2-2-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=fail:26.0
                                    send: 2-2-0-0 s=2,c=3,t=16,pt=0,l=0,sg=0,st=fail:
                                    sign fail
                                    send: 2-2-0-0 s=2,c=1,t=1,pt=2,l=2,sg=0,st=fail:34
                                    send: 2-2-0-0 s=255,c=3,t=16,pt=0,l=0,sg=0,st=fail:
                                    sign fail
                                    • AnticimexA
                                      AnticimexA
                                      Anticimex
                                      You must not use the same serial across nodes. Serial have to be unique. HMAC have to be identical.
                                      • ximinezX
                                        ximinezX
                                        ximinez
                                        Yes, I know serial must be unique. Serials go in the whitelist for the corresponding node ID. It turned out to be the NRF24L01+-modules with antennas. Replaced it with a regular module and it worked fine.
                                        (Which is strange, because one of those modules worked fine on the ethernet gw. It doesn't eat that much power does it?)
                                        • ximinezX ximinez
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @ximinez The signing failing is due to messages not arriving (st=fail). So it is not signing that is your problem here.
                                          However, with signing, messages are now "full size" which strains the RF link so if it is "weak" fewer messages get through if they are "longer". I suspect that is the problem here. Basically the usual stuff; adding caps, using a dedicated regulator and so on...
