  3. Over the air updates
87 Posts 15 Posters 64.3k Views 12 Watching
  • DammeD Damme
    @ToSa I've been looking through the ota bootloader and noticed there are alot of uint16_t wich can be replaced with uint8_t.. saves 128bytes of code. Still needs ~900bytes less until 1024 words bootloader though but is makes more space for other stuff :)
    ToSa
    Code Contributor
    wrote on last edited by ToSa
    #43
    I'll have a look. I've taken the code from an earlier project and adjusted to MySensors - didn't review the variable types that much. I'm using CRC16 as well where CRC8 might be sufficient...
    EDIT: got it down a little from 0x0E18 to 0x0DD0 (72 bytes) changing a few loop counters from uint16 to uint8. I don't want to change type to 8bit looking at the large amount of sensors people are asking for / working on. FOr version I'm planning to keep some of these running for a long time with as little maintenance as possible. With some software improvements over time and minor version changes during development 16bit for version seems to be the better fit as well.
    Z 1 Reply Last reply
    • T ToSa
      @JeJ @mikeones : how is your serial gateway connected? using a USB-Rs232 cable or via the GPIO pins on the RPi? Did you check the Readme.md in the NodeJsController directory?
      mikeones
      @ToSa I use a Mini-B USB cable between my PRi and my gateway.
      • M mikeones
        ToSa
        Code Contributor
        @mikeones said:
        dev/ttyUSB0
        Then /dev/ttyUSB0 is correct. /dev/ttyAMA0 would only be valid for the on-board serial port on the GPIO pinheads.
        Are you running into any issues once you set the port in NodeJsGateway accordingly?
        • T ToSa
          J
          J
          JeJ
          @ToSa I have my gateway connected via the GPIO and i have followed the steps in the Readme.md.
          I will try to use a USB-Rs232 cable and see what happens.
          • J JeJ
            ToSa
            Code Contributor
            @JeJ one potential reason is that the port is already in use. I mentioned somewhere that the startup script doesn't yet stop the NodeJsController correctly. Maybe you already have a NodeJsController process running? Try "sudo killall node" and then try starting it again. To check if the port itself is working you can try to open a simple terminal (minicom etc.) and reset the gateway.
            • T ToSa
              Z
              Z
              Zeph
              Hmm. That seems like overkill, if I'm understanding correctly. (So maybe I am not understanding).
              What I heard was:
              Each sensactuator node has a "node type" and a "version" within that node type. Each combination of sensors and pin assignments has a unique "node type" (within a given wireless network). A node can only be OTA updated to a newer (higher) version of the same "node type" of the current firmware, and all nodes of that "node type" will be updated.
              And extra byte for "version" isn't a big deal tho.
              Will there be one or two bytes for "node type"?
              DammeD T 2 Replies Last reply
              • Z Zeph
                What I heard was:
                DammeD
                DammeD
                Damme
                Code Contributor
                @Zeph 16bit calculations on a 8bit mcu will always come to a price. Imo I think we should try to keep things to 8bit as much as possible. but I dont know if its possible to shred another 900bytes out of the bootloader to fit in one less size of space (1024 words instead of 2048 words). Might be if we make a mini version of mysensors/mymessage
                • Z Zeph
                  What I heard was:
                  ToSa
                  Code Contributor
                  Actually that's part of the question - as @hek mentioned there is a desire to sell MySensors hardware - at some point there might be not just generic pinhead PCBs but real fit-for-use devices. Ideally these would have a unique node type assigned not just within a given network. New firmware could be published on mysensors.org (or via codebender or...) and based on the unique (but common across networks) node type less tech-savvy people could be secured from sending a firmware that doesn't fit the hardware... I know - a LOT of "IF"s...
                  @Damme
                  you are right - probably not the full 900 bytes but additional space could be used for encryption etc. so every reduced byte is beneficial at this point. I'll check later how much can be saved by using CRC8 instead of CRC16.
                  I'm already using a mini version of mysensors / mymessage: not using the cpp code files at all but just the headers and if you have a look at the "#ifdef __cplusplus" statements just added for that purpose, there is almost nothing left (the MyMessage class is stripped down to a struct and the MySensors class removed completely / enums and #defines should not consume space after compilation)
                  • Z
                    Z
                    Zeph
                    @ToSa
                    I'm realizing how similar the implementations of your model of updates and mine might be. This is just an early inspiration, not fully thought out.
                    uint8_t   node_type_id;  // same for multiple nodes
                    uint16_t version;   // loaded version for given node_type_id
                    if(new_version > version) {  // test for OTA update needed
                    versus
                    uint8_t   node_id;   // unique per node
                    uint16_t  progmem_crc;  // calculated from PROGMEM
                    if(new_progmem_crc != progmem_crc) { // test for OTA update needed
                    This might mean that I could (eventually) use a relatively minor fork of the OTA programming code to get the per-node flexibility that I seek.
                    • Z Zeph
                      @ToSa
                      versus
                      ToSa
                      Code Contributor
                      #52
                      @Zeph
                      yes, that's what I meant - you might not even need any fork of the bootloader itself and just a slight adjustment on the controller end - because the nodeID is contained in the packet (not in the payload but in the header as sender address) so you have all you need for your setup
                      • T ToSa
                        @Zeph
                        Z
                        Z
                        Zeph
                        wrote on last edited by Zeph
                        #53
                        @ToSa
                        The other half is testing inequality between the computed CRC of the application firmware in PROGMEM, with the CRC of the available replacement (rather than comparing for higher version number).
                        An example use case of the ability to load arbitrary new code into any given node. If I was diagnosing some kind of interference, I might temporarily replace the sensor firmware in some nodes (of varying node-type) with a custom radio test firmware, then later restore each with it's original sensor node firmware.
                        Suppose we have:
                         node 5, node type 17, version 2, PROGMEM CRC 0x4567  // attic
                         node 6, node type 3, version 5, PROGMEM CRC 0xABCD  // crawlspace
                         node 7, node type 3, version 5, PROGMAM CRC 0xABCD // living room
                        And I want to temporarily replace the firmware in node 5 and 6, but keep 7 still running as a sensor.
                        I make RF test code available on the server, with CRC 0x7E57. This is not type 17 or type 3.
                        I edit the server's table of firmware assignments:
                        node 5, 0x7E57
                        node 6, 0x7E57
                        node 7, 0xABCD  // unchanged
                        This causes node 5 and 6 (formerly of different types) to load the test firmware when reload is triggered.
                        Then when testing is done, I edit the table back:
                        node 5, 0x4567   // back to its old type and version
                        node 6, 0xABCD  // back to the same type and version as node 7
                        node 7, 0xABCD  // still unaffected
                        This causes the normal sensor firmware (type and version) to be loaded back in on the next reload.
                        There could be more than just a CRC to identify the firmware (in order to avoid the birthday paradox), this is just an example.
                        An alternate use case is loading in my Halloween firmware to the front yard nodes (but not other nodes) for a week or two, then back..
                        Or an beta version of type 3, version 6, which I'd like to load on some type 3 nodes for in-situ testing (eg: in the crawlspace), but not all of the type 3 nodes because I want most of the system to continue functioning normally while I test. If the beta is bad, I may revert the test nodes to version 5; once the new version is good, I may convert all type 3 nodes to version 6.
                        These are some of the reasons I'd like to be able to use OTA programming of any arbitrary firmware into any given node, without being constrained to:
                          Only upgrades of the same node type
                          Only upgrades to higher version numbers
                          Only upgrades of all nodes of the same type or none
                        And so that's why inequaity testing of the PROGMEM signature on a per-node basis is attractive, not just testing for a higher version number. For similar complexity, we can upgrade to a higher version number, downgrade to a different version number, or change the node type back and forth.
                        The type and version dynamics (which certainly IS a common use case) can be handled on the server. For example, the server can know what type every node is (kind of a good idea anyway), and can change the node -> signature entry for every node of type 3 to the signature of the next version, and then let it proceed as above to get them all updated. But that's just one option, centrally controlled.
                        • Z Zeph
                          @ToSa
                          Suppose we have:
                          node 5, 0x7E57
                          node 6, 0x7E57
                          ToSa
                          Code Contributor
                          #54
                          @Zeph
                          from the MyOtaBootloader.c:
                          if (firmwareConfigResponse->version == fc.version)
                          	if (firmwareConfigResponse->blocks == fc.blocks)
                          		if (firmwareConfigResponse->crc == fc.crc)
                          so as long as you send the same version / blocks / crc back to the node as what iscurrently installed, no update is started. As soon as one of the three elements differs an update is loaded. It's completely in control of the server if (and which) firmware is bootloaded.
                          • T ToSa
                            @Zeph
                            Z
                            Z
                            Zeph
                            #55
                            @ToSa
                            OK, so version is tested for != rather than for > ? Downgrading is OK?
                            And CRC is used as well (and block count?) where CRC is based on what's in PROGMEM now?
                            Cool.
                            Then I think all that would be needed is for the server to be able to potentially feed back a different firmwareConfigResponse to each node. In my above example (which has been edited for clarity recently BTW, so re-read it), node 6 could receive a different response than node 7 (even tho they both have the same type initially). And thus nodes 5 and 6 (but not 7) could be told to load the test firmware and then later to go back to the old version. Etc.
                            Is that correct?
                            It would be a nice enhancement if we could query the node for the CRC (and block count?) of the current PROGMEM, just to help the server stay in sync with what's out there (eg: after a node joins the network). That could be done in the application code, so we don't even have to invoke the bootloader. Then the server could figure out which nodes need to be bootloaded and trigger just those to go into the bootloader (possibly one at a time). These two together support what I call push dynamics.
                            DammeD 1 Reply Last reply
                            • Z Zeph
                              @ToSa
                              Cool.
                              Is that correct?
                              DammeD
                              DammeD
                              Damme
                              Code Contributor
                              @Zeph I've been working on a read / write eeprom address thing in MQTT to be able to reset a node and stuff. But it seams there are more usage for it then. This might be coded into mysensors instead. (utilizing c_internal or somthing as the protocol is today)
                              • DammeD Damme
                                ToSa
                                Code Contributor
                                #57
                                Good idea - that would allow to check for current value in normal operation - not just during bootloading.
                                @Zeph
                                If you urgently want to have the CRC of the current firmware submitted during bootloading, we can add this as a third parameter to the FirmwareConfigRequest message. Actually I was thinking about getting rid of request/response and use the same format for both which would mean crc would be included anyways.
                                • T ToSa
                                  Really really nice project !!!
                                  I worked on a similar setup about two years ago with different RF modules but didn't finish. Now I was about to restart and realized that the nRF24 modules are waaaaay less expensive. I just started adjusting the old code for the nRF24 modules I ordered when I found this great project. The raspberry PI for me is the way to go as I own two sitting almost idle and don't own a Vera.
                                  The one feature I'm missing after reading through the majority of the available documentation is over the air updates of the sensor node software. As this is one of the features I completed for my old design, I'll go ahead and try to port the bootloader and the RPi based state-less firmware server to work with the protocol and routing implemented here... if successful I'll post the results.
                                  If you worked already on over the air updates or you know somebody who did, please let me know and I'll focus my efforts on something else :-)
                                  Tobias
                                  DammeD
                                  DammeD
                                  Damme
                                  Code Contributor
                                  wrote on last edited by Damme
                                  #58
                                  • DammeD
                                    DammeD
                                    Damme
                                    Code Contributor
                                    #59
                                    I deleted my last message because I though I made a big mistake..
                                    I've been working on a SD <-> OTA loader node, and got most of if working but got stuck on the last piece which is communication.. (i'll release it then I'm finished Ive made a small change in myotabootloader, add on line ~156 msg.destination = OTAGATEWAY; to configure custom ota address)
                                    I cant figure the following out:
                                    Just ignore contents of packages. not relevant.
                                    • Node: (Ota<->sd loader)
                                      read: 34-0-254 s=255,c=4,t=0,pt=6,l=4:FFFFFFFF
                                      send: 254-254-0-34 s=255,c=4,t=1,pt=8,l=4,st=ok:0100020000304200
                                    • GW:
                                      0;0;3;0;9;read: 34-34-0 s=255,c=3,t=7,pt=0,l=0:
                                      0;0;3;0;9;send: 0-0-34-34 s=255,c=3,t=8,pt=1,l=1,st=ok:0
                                      0;0;3;0;9;read: 34-34-254 s=255,c=4,t=0,pt=6,l=4:FFFFFFFF
                                      0;0;3;0;9;send: 34-0-254-254 s=255,c=4,t=0,pt=6,l=4,st=ok:FFFFFFFF
                                      0;0;3;0;9;read: 254-254-34 s=255,c=4,t=1,pt=6,l=8:0100020000304200
                                      0;0;3;0;9;send: 254-0-0-34 s=255,c=4,t=1,pt=6,l=8,st=fail:0100020000304200
                                    • OTA bootloader:
                                      Go
                                      <- 34,34,0,2,3,7,255,
                                      -> 0,0,34,10,35,8,255,0,
                                      <- 34,34,254,34,196,0,255,255,255,255,255,
                                    What am I missing? package from 254 to 34 wont get delivered.
                                    I've also noticed that then 254 tries to send, it wont receive the next transmitted message from OTAbootloader. the next thereafter is received.
                                    • DammeD Damme
                                      • GW:
                                      • OTA bootloader:
                                        Go
                                      ToSa
                                      Code Contributor
                                      @Damme
                                      I need to better understand the setup to think about what's going on. My take from the above:
                                      You have three nodes:
                                      • Gateway (address 0)
                                      • SD OTA Loader Node ?!? (address 254)
                                      • Sensor Node (address 34)
                                      Is that right?
                                      • T ToSa
                                        @Damme
                                        Is that right?
                                        DammeD
                                        DammeD
                                        Damme
                                        Code Contributor
                                        @ToSa Yes, And I think I figured it out.. I by mistake changed BROADCAST_ADDRESS to GATEWAY_ADDRESS in the bootloader then I was playing around. Testing the correct version now.. :)
                                        • DammeD Damme
                                          ToSa
                                          Code Contributor
                                          #62
                                          @Damme
                                          interesting setup :+1:
                                          to make it work with non-static addressed nodes you should probably keep the destination set to GATEWAY_ADDRESS for the REQUEST_ID call and only change afterwards.
                                          Never mind - looking at the line number you mentioned that's probably what you did :)
