  3. Serial gateway with arduino nano inclusion problem
10 Posts 4 Posters 2.6k Views 3 Watching
  • miroM
    miroM
    miro
    I have connected my serial gateway to the vera edge and everything seems to be okay.
    When I try to include my door/window sensor in mysensors plugin, I click start and 1 sec after it says 0 devices found.
    I`m new to this and I have no idea what it could be?
    • miroM
      miroM
      miro
      This is my log file for the binarysleeping sensor:
      send: 1-1-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=fail:0
      send: 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=fail:1.5.4
      send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:0
      sensor started, id=1, parent=0, distance=1
      send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=13,sg=0,st=fail:Binary Sensor
      send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=fail:1.0
      send: 1-1-0-0 s=3,c=0,t=0,pt=0,l=0,sg=0,st=fail:
      find parent
      send: 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
      send: 1-1-0-0 s=4,c=0,t=0,pt=0,l=0,sg=0,st=fail:
      send: 1-1-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=fail:1
      send: 1-1-0-0 s=4,c=1,t=16,pt=2,l=2,sg=0,st=fail:0
      send: 1-1-0-0 s=4,c=1,t=16,pt=2,l=2,sg=0,st=fail:1
      find parent
      send: 1-1-0-0 s=4,c=1,t=16,pt=2,l=2,sg=0,st=fail:0```
      • SparkmanS
        SparkmanS
        Sparkman
        wrote on last edited by Sparkman
        st=fail typically means that the sensor is having trouble communicating to the gateway due to a power issue on the sensor. Search the forum for common resolutions to this and if those don't resolve it, post more details on your hardware setup.
        Al
        PS Have you checked http://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help
        • miroM
          miroM
          miro
          Is this log for the gateway okay?
          SparkmanS 1 Reply Last reply
          • miroM miro
            SparkmanS
            SparkmanS
            Sparkman
            @miro It's ok from a startup perspective which means you have programmed and wired it correctly. It could still have power issues when it is transmitting.
            Al
              On what pin is the inclusion mode button connected? Is the feature enabled?
              Make sure you didn't connect anything on this pin.
              • miroM
                miroM
                miro
                @hek
                #define INCLUSION_MODE_PIN 3 // Digital pin used for inclusion mode button
                This is what I have in the gateway
                Before I had no button connected at all. Now I tok two wires from digital pin 3 and ground to test.
                Still nothing happends when I click on start inlusion in my vera?
                • miroM
                  miroM
                  miro
                  Well, a conductor on the sensor radio and gateway radio did solve the inclusion of this sensor.
                  But now I try to include a motion sensor that I build exact the same but the gateway will not find it, what to do?
                  It looks okay in arduino monitor...
                  • sundberg84S
                    sundberg84S
                    @miro - its most of the times much easier for us if you provide the serial log. Any ST:fail on this one for example?
                    • miroM
                      miroM
                      miro
                      Now when I tested the sensor in arduino monitor it says just.
                      Req id
                      Also the other sensor have stop working.
                      Something wrong with gateway?
