  3. I am a bit confused over wiring ethernet gateway
14 Posts 3 Posters 3.5k Views 2 Watching
  • hekH Offline
    hekH Offline
    Does the radio still fail If you remove power from the w5100 while starting up? It's quite power hungry.
    • mark_vennM Offline
      mark_vennM Offline
      mark_venn
      I am powering the Uno with 12 v not just the usb power.
      I have now set the uno up as a temp / humidity sensor and I am seeing:
      req id
      sensor started, id=255, parent=0, distance=1
      req id
      send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=fail:
      req id
      req id
      req id
      req id
      T: 23.00
      req id
      H: 49.00
      I can see some entries in the gateway serial when I restart the dht sensor:
      0;0;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
      255;255;3;0;3;
      255;255;3;0;3;
      255;255;3;0;3;
      255;255;3;0;3;
      255;255;3;0;3;
      255;255;3;0;3;
      255;255;3;0;3;
      so I assume the radio is working properly. Should I see the temp and humidity values in the gateway output in the way I do in the sensor output?
      • S Offline
        req id means it tries to fetch an ID from the controller - do you use a controller that can assign ID?
        mark_vennM 1 Reply Last reply
        • S sundberg84
          mark_vennM Offline
          mark_vennM Offline
          mark_venn
          @sundberg84
          Hi
          Yes, I am using a gateway that will hand out an address ok to another sensor so that seems ok. The gateway does seems to see something coming in when I restart the dht sensor so I am assuing it is something wrong in the software. I have swapped the radio over with the gateway and this seems ok with the motion sensor that has been handed id 105. I am not with the hardware at the moment, I will have a look at the software and see if I can see anytbing I have messed up but can't test till later. I might try a different sensor instead so I am using different software. I have a few different bits to play with.
          Thanks for the reply
          • S Offline
            @mark_venn The gateway does not hand out any ID - you need a controller like Vera or Domoticz behind to do that. If you dont have that the node will keep asking if you dont set it manually - do you have that (I guess since its worked with another node).
            If you think its in the software, clearing the eeprom might be useful
            • S sundberg84
              mark_vennM Offline
              mark_vennM Offline
              mark_venn
              wrote on last edited by mark_venn
              @sundberg84
              I am not attached to a controller at the moment; the traces on the gateway with a motion sensor have worked differently then. I assume the code for the motion sensor has a hard coded value in then?
              0;0;3;0;9;read: 105-105-0 s=255,c=3,t=15,pt=2,l=2,sg=0:0
              105;255;3;0;15;0
              0;0;3;0;9;read: 105-105-0 s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.4
              105;255;0;0;17;1.5.4
              0;0;3;0;9;read: 105-105-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
              105;255;3;0;6;0
              0;0;3;0;9;read: 105-105-0 s=255,c=3,t=11,pt=0,l=13,sg=0:Motion Sensor
              105;255;3;0;11;Motion Sensor
              0;0;3;0;9;read: 105-105-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
              105;1;1;0;16;1
              0;0;3;0;9;read: 105-105-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
              105;1;1;0;16;0
              105;1;1;0;16;1
              105;1;1;0;16;0
              The gateway I am using is the serial gateway running on a nano
              • S Offline
                @mark_venn - as i said, you need a controller if you want to use automatic ID.
                Your motion dec is probably hardcoded ID as many examples are in the forum.
                Use gw.begin(NULL, AUTO, true) change auto to nodeID and true to false if you have battery sensor
                • S sundberg84
                  mark_vennM Offline
                  mark_vennM Offline
                  mark_venn
                  @sundberg84
                  I am going to hok the whole system up to openHAB or possibly Domoticz once I have more sensors working. I am most likely to use MQTT as the final gateway but wanted to get something working, the ethernet gateway would not work properly. I think MQTT will give me more data space to pass messages around. I am going to tyr the ethernet gw again tonight once I get back from uni
                  • hekH Offline
                    hekH Offline
                    I would suggest using the development branch. No special configuration is needed for the W5100 sketch.
                      mark_vennM Offline
                      mark_vennM Offline
                      mark_venn
                      @hek
                      Does this include not needing the softspi fix?
                      • hekH Offline
                        hekH Offline
                        It's enabled automatically for the w5100 gateway.
