  3. MQTT Broker gateway
MQTT Broker gateway
132 Posts 34 Posters 147.6k Views 7 Watching
  • T ToSa
    I can confirm it's working with UIPEthernet.h and the ENC28J60 module as well. You need to turn off debugging in MyConfig.h to make the code fit.
    DammeD
    DammeD
    Damme
    Code Contributor
    wrote on last edited by Damme
    @ToSa Thanks! I havn't had time to get and test that module.
    • T ToSa
      ToSa
      Code Contributor
      Maybe that was a little too fast - it starts up and starting OpenHAB finds the gateway and connects. When I reset a node it appears that the gateway crashes (OpenHAB reports disconnect) and only a reset of the gateway helps to get it to work again. Problem is it's hard to debug without debugging enabled due to code size :(
      DammeD 1 Reply Last reply
      • T ToSa
        DammeD
        DammeD
        Damme
        Code Contributor
        @ToSa if possible you could make a tcpdump over the mqqt port and I'll look at it. Also a serial dump from the node would be great
        • DammeD Damme
          ToSa
          Code Contributor
          After changing the include from Ethernet.h to UIPEthernet.h the sketch fits into the m328 only with DEBUG (and TCPDUMP) turned off:
          DEBUG / TCPDUMP turned off:
          Sketch uses 30,626 bytes (99%) of program storage space. Maximum is 30,720 bytes.
          Global variables use 1,330 bytes (64%) of dynamic memory, leaving 718 bytes for local variables. Maximum is 2,048 bytes.
          DEBUG / TCPDUMP turned on:
          Sketch uses 32,354 bytes (105%) of program storage space. Maximum is 30,720 bytes.
          Global variables use 1,393 bytes (68%) of dynamic memory, leaving 655 bytes for local variables. Maximum is 2,048 bytes.
          processing.app.debug.RunnerException: Sketch too big;
          The only thing I have right now to look at is the OpenHAB output (appears that it's not happening when I reset a node but rather random):
          pi@openhab ~/runtime $ ./start.sh
          Launching the openHAB runtime...
          osgi> 19:54:19.384 INFO o.o.c.internal.CoreActivator[:61] - openHAB runtime has been started (v1.6.0).
          19:54:39.316 INFO o.o.i.t.mqtt.MqttService[:106] - MQTT Service initialization completed.
          19:54:39.322 INFO o.o.i.t.m.i.MqttBrokerConnection[:112] - Starting MQTT broker connection 'mysensor'
          19:54:42.838 INFO o.o.m.c.i.ModelRepositoryImpl[:79] - Loading model 'logging.persist'
          19:54:46.082 INFO o.o.m.c.i.ModelRepositoryImpl[:79] - Loading model 'exec.persist'
          19:54:46.261 INFO o.o.m.c.i.ModelRepositoryImpl[:79] - Loading model 'rrd4j.persist'
          19:54:46.494 INFO o.o.m.c.i.ModelRepositoryImpl[:79] - Loading model 'db4o.persist'
          19:54:47.009 INFO o.o.m.c.i.ModelRepositoryImpl[:79] - Loading model 'test.items'
          19:55:01.187 INFO o.o.i.s.i.DiscoveryServiceImpl[:72] - mDNS service has been started
          19:55:10.219 INFO o.o.m.c.i.ModelRepositoryImpl[:79] - Loading model 'test.sitemap'
          19:55:19.042 INFO o.o.io.rest.RESTApplication[:143] - Started REST API at /rest
          19:55:24.936 INFO o.o.u.w.i.s.WebAppServlet[:79] - Started Classic UI at /openhab.app
          19:55:35.271 ERROR o.o.i.t.m.i.MqttBrokerConnection[:478] - Error starting consumer
          org.eclipse.paho.client.mqttv3.MqttException: Connection lost
          at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:138)
          Caused by: java.net.SocketException: Connection reset
          at java.net.SocketInputStream.read(SocketInputStream.java:196)
          19:55:35.298 ERROR o.o.i.t.m.i.MqttBrokerConnection[:532] - MQTT connection to broker was lost
          19:55:35.305 ERROR o.o.i.t.m.i.MqttBrokerConnection[:536] - MQTT connection to 'mysensor' was lost: Connection lost : ReasonCode 32109 : Cause : Connection reset
          19:55:35.310 INFO o.o.i.t.m.i.MqttBrokerConnection[:543] - Starting connection helper to periodically try restore connection to broker 'mysensor'
          19:55:45.317 INFO o.o.i.t.m.i.MqttBrokerConnection[:112] - Starting MQTT broker connection 'mysensor'
          • T ToSa
            DammeD
            DammeD
            Damme
            Code Contributor
            @ToSa wireshark dump https://www.wireshark.org/ or tcpdump http://www.tcpdump.org/
            • DammeD Damme
              ToSa
              Code Contributor
              Thought you were referring to the "#define TCPDUMP" in MyMQTT.h :)
              I did "sudo tcpdump host 10.0.1.99 -i eth0 -w dump.pcap" on the RPi that is running the OpenHAB runtime (10.0.1.6 is the IP of the RPi with OpenHAB / 10.0.1.99 is the IP of the MQTT gateway) and then did the following:
              • power-on MQTT gateway
              • start OpenHAB and wait until startup finished
              • power-on node with DallasTemperature
              The pcap file is attached (not knowing a lot about the protocol it looks like a series of keep-alive messages only and suddenly a connection reset): dump2.pcap
              I do not see any messages arriving at OpenHAB... looking at the debug output from the node it appears that the "find parent" message is correctly handled by the gateway but the "node ID request" is not.
              ** OpenHAB output: **
              osgi> 21:55:31.305 INFO o.o.c.internal.CoreActivator[:61] - openHAB runtime has been started (v1.6.0).
              21:55:50.955 INFO o.o.i.t.mqtt.MqttService[:106] - MQTT Service initialization completed.
              21:55:50.974 INFO o.o.i.t.m.i.MqttBrokerConnection[:112] - Starting MQTT broker connection 'mysensor'
              21:55:57.178 INFO o.o.m.c.i.ModelRepositoryImpl[:79] - Loading model 'logging.persist'
              21:55:59.989 INFO o.o.m.c.i.ModelRepositoryImpl[:79] - Loading model 'exec.persist'
              21:56:00.137 INFO o.o.m.c.i.ModelRepositoryImpl[:79] - Loading model 'rrd4j.persist'
              21:56:00.303 INFO o.o.m.c.i.ModelRepositoryImpl[:79] - Loading model 'db4o.persist'
              21:56:01.162 INFO o.o.m.c.i.ModelRepositoryImpl[:79] - Loading model 'test.items'
              21:56:13.732 INFO o.o.m.c.i.ModelRepositoryImpl[:79] - Loading model 'test.sitemap'
              21:56:16.231 INFO o.o.i.s.i.DiscoveryServiceImpl[:72] - mDNS service has been started
              21:56:31.603 INFO o.o.io.rest.RESTApplication[:143] - Started REST API at /rest
              21:56:37.387 INFO o.o.u.w.i.s.WebAppServlet[:79] - Started Classic UI at /openhab.app
              21:59:50.613 ERROR o.o.i.t.m.i.MqttBrokerConnection[:532] - MQTT connection to broker was lost
              21:59:50.621 ERROR o.o.i.t.m.i.MqttBrokerConnection[:536] - MQTT connection to 'mysensor' was lost: Connection lost : ReasonCode 32109 : Cause : Connection reset
              21:59:50.625 INFO o.o.i.t.m.i.MqttBrokerConnection[:543] - Starting connection helper to periodically try restore connection to broker 'mysensor'
              22:00:00.633 INFO o.o.i.t.m.i.MqttBrokerConnection[:112] - Starting MQTT broker connection 'mysensor'
              ** The serial debug output of the node shows (more than that but always repeating as I did several resets of the node): **
              sensor started, id 255
              req node id
              send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,st=fail:
              req node id
              req node id
              req node id
              req node id
              req node id
              send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
              req node id
              req node id
              • T ToSa
                req node id
                req node id
                req node id
                req node id
                req node id
                req node id
                req node id
                req node id
                DammeD
                DammeD
                Damme
                Code Contributor
                @ToSa Thats odd. Everything looks good...(almost, there are some excess of trailing 0x00 but shouldn't matter, but I'll look at that anyways..)
                Can you compile with myconfig debug enabled, but define tcpdump disabled? or is it too big that way too?
                • JohnJ
                  JohnJ
                  John
                  wrote on last edited by John
                  @Damme
                  I'm currently busy implementing an mqtt client plugin, and i'm going to use mysensors for it's first predefined implementation so i have a couple of questions
                  I took a look at the api page and saw this in the mqtt documentation:
                  [MQTT_BROKER_PREFIX]/[NodeID]/[SensorID]/V_[SensorType]
                  Does this means as example:
                  MyMQTT/[0-255]/[0-255]/[STRING]/[VALUE]
                  OR this?
                  MyMQTT/[0-255]/[0-255]/[0-endvarindex]/[VALUE]
                  • Are variable types defined by their index used or by name?
                  • Also it states it keeps track of node id's how are these reported by the broker, should the controller still hand out free id's?
                  [EDIT]
                  I currently do not have the hardware present to at least set it up to test and look at what exactly is happening.
                  [/EDIT]
                  • JohnJ John
                    @Damme
                    OR this?
                    [EDIT]
                    [/EDIT]
                    DammeD
                    DammeD
                    Damme
                    Code Contributor
                    @John MyMQTT/[0-255]/[0-255]/[STRING]/[VALUE]
                    MQTT.cpp :
                    sprintf(&buffer[buffsize],"/%i/%i/V_%s", msg.sender, msg.sensor, getType(convBuf, &vType[msg.type]));
                    note V_%s -> MyMQTT/[0-255]/[0-255]/V_[STRING]/[VALUE]
                    also note there is no trailing / before payload, as http://public.dhe.ibm.com/software/dw/webservices/ws-mqtt/mqtt-v3r1.html
                    http://mqtt.org/wiki/doku.php/topic_format
                    I choose not to have trailing slash, but if needed its easy to make it configurable.
                    and get type translates from this list
                      char V_0[] PROGMEM = "TEMP";		//V_TEMP
                      char V_1[] PROGMEM = "HUM";		//V_HUM
                      char V_2[] PROGMEM = "LIGHT";		//V_LIGHT
                      char V_3[] PROGMEM = "DIMMER";		//V_DIMMER
                      char V_4[] PROGMEM = "PRESSURE";	//V_PRESSURE
                      char V_5[] PROGMEM = "FORECAST";	//V_FORECAST
                      char V_6[] PROGMEM = "RAIN";		//V_RAIN
                      char V_7[] PROGMEM = "RAINRATE";	//V_RAINRATE
                      char V_8[] PROGMEM = "WIND";		//V_WIND
                      char V_9[] PROGMEM = "GUST";		//V_GUST
                      char V_10[] PROGMEM = "DIRECTON";	//V_DIRECTON
                      char V_11[] PROGMEM = "UV";		//V_UV
                      char V_12[] PROGMEM = "WEIGHT";		//V_WEIGHT
                      char V_13[] PROGMEM = "DISTANCE";	//V_DISTANCE
                      char V_14[] PROGMEM = "IMPEDANCE";	//V_IMPEDANCE
                      char V_15[] PROGMEM = "ARMED";		//V_ARMED
                      char V_16[] PROGMEM = "TRIPPED";	//V_TRIPPED
                      char V_17[] PROGMEM = "WATT";		//V_WATT
                      char V_18[] PROGMEM = "KWH";		//V_KWH
                      char V_19[] PROGMEM = "SCENE_ON";	//V_SCENE_ON
                      char V_20[] PROGMEM = "SCENE_OFF";	//V_SCENE_OFF
                      char V_21[] PROGMEM = "HEATER";		//V_HEATER
                      char V_22[] PROGMEM = "HEATER_SW";	//V_HEATER_SW
                      char V_23[] PROGMEM = "LIGHT_LEVEL";	//V_LIGHT_LEVEL
                      char V_24[] PROGMEM = "VAR1";		//V_VAR1
                      char V_25[] PROGMEM = "VAR2";		//V_VAR2
                      char V_26[] PROGMEM = "VAR3";		//V_VAR3
                      char V_27[] PROGMEM = "VAR4";		//V_VAR4
                      char V_28[] PROGMEM = "VAR5";		//V_VAR5
                      char V_29[] PROGMEM = "UP";		//V_UP
                      char V_30[] PROGMEM = "DOWN";		//V_DOWN
                      char V_31[] PROGMEM = "STOP";		//V_STOP
                      char V_32[] PROGMEM = "IR_SEND";	//V_IR_SEND
                      char V_33[] PROGMEM = "IR_RECEIVE";	//V_IR_RECEIVE
                      char V_34[] PROGMEM = "FLOW";		//V_FLOW
                      char V_35[] PROGMEM = "VOLUME";		//V_VOLUME
                      char V_36[] PROGMEM = "LOCK_STATUS";	//V_LOCK_STATUS
                      char V_37[] PROGMEM = "DUST_LEVEL";	//V_DUST_LEVEL
                      char V_38[] PROGMEM = "VOLTAGE";	//V_VOLTAGE
                      char V_39[] PROGMEM = "CURRENT";	//V_CURRENT
                      char V_40[] PROGMEM = "";		//
                      char V_41[] PROGMEM = "";		//
                      char V_42[] PROGMEM = "";		//
                      char V_43[] PROGMEM = "";		//
                      char V_44[] PROGMEM = "";		//
                      char V_45[] PROGMEM = "";		//
                      char V_46[] PROGMEM = "";		//
                      char V_47[] PROGMEM = "";		//
                      char V_48[] PROGMEM = "";		//
                      char V_49[] PROGMEM = "";		//
                      char V_50[] PROGMEM = "";		//
                      char V_51[] PROGMEM = "";		//
                      char V_52[] PROGMEM = "";		//
                      char V_53[] PROGMEM = "";		//
                      char V_54[] PROGMEM = "";		//
                      char V_55[] PROGMEM = "";		//
                      char V_56[] PROGMEM = "";		//
                      char V_57[] PROGMEM = "";		//
                      char V_58[] PROGMEM = "";		//
                      char V_59[] PROGMEM = "";		//
                      char V_60[] PROGMEM = "Started!\n";	//Custom for MQTTGateway
                      char V_61[] PROGMEM = "SKETCH_NAME";	//Custom for MQTTGateway
                      char V_62[] PROGMEM = "SKETCH_VERSION"; //Custom for MQTTGateway
                      char V_63[] PROGMEM = "UNKNOWN"; 	//Custom for MQTTGateway
                      char V_64[] PROGMEM = "FW_CREQ"; 	//Custom for MQTTGateway
                      char V_65[] PROGMEM = "FW_CRES"; 	//Custom for MQTTGateway
                      char V_66[] PROGMEM = "FW_REQ"; 	//Custom for MQTTGateway
                      char V_67[] PROGMEM = "FW_RES"; 	//Custom for MQTTGateway
                    The MQTTgateway hands out ID's; configured in MQTT.h:
                      #define MQTT_FIRST_SENSORID	20  		// If you want manually configured nodes below this value. 255 = Disable
                      #define MQTT_LAST_SENSORID	254 		// 254 is max! 255 reserved.
                      #define MQTT_BROKER_PREFIX	"MyMQTT"	// First prefix in MQTT tree, keep short!
                      #define MQTT_SEND_SUBSCRIPTION 1		// Send empty payload (request) to node upon MQTT client subscribe request.
                      // NOTE above : Beware to check if there is any length on payload in your incommingMessage code:
                      // Example: if (msg.type==V_LIGHT && strlen(msg.getString())>0) otherwise the code might do strange things.
                    • JohnJ
                      JohnJ
                      John
                      @Damme
                      Clear!
                      And how about the internal messages? Are these somewhat compatible with the Serial API? Like this one now has a "I_GATEWAY_READY" internal var, this one complies then with the "Started!\n" message?
                      Also about the presentation (if the node does it), are these also passed through?
                      I know it's a bit question banging... But i just want to do it right.
                      • JohnJ John
                        @Damme
                        Clear!
                        DammeD
                        DammeD
                        Damme
                        Code Contributor
                        @John No worries! :)
                        Presentation is On Todo.. Or Rather To think About list is presentation . I dont do anything with that as it is (Just ignores it). I havn't had any good idea for that yet.
                        Internal is nothing more or less, it connects and set a variable that it is connected. :) But sure, there could be transport for internal messages also.
                        I do have an experimental version there I can send internal messages to reboot node, reboot gateway and set clear read eeprom values. (over mqtt-protocol) but this s not finnished yet.. Ideas are welcome!
                        • DammeD Damme
                          DammeD
                          DammeD
                          Damme
                          Code Contributor
                          @John About Presentation ; My idea was that next version of the variable system I will either store some bytes in the MQTT gateway about what S_types to V_types, or hopefully the next protocol contains both those so the GW doesnt have to remember. And then add an extra directory to the MQTT path ( MyMQTT/[0-255]/[0-255]/S_[STRING]/V_[STRING]/[VALUE]
                          • JohnJ
                            JohnJ
                            John
                            #21
                            I think maybe it depends on the next protocol implementation. Personally i wouldn't mind if the full path mapping was /[0-255]/[0-255]/etc.. to keep (prog)mem print smaller (use the V_ and S_ array index values). It could leave space for more specific things or some extra gateway specific functions.
                            it would be nice if the mqtt gateway output was "cloned" to the serial output. Controllers should/could be able to map the S_ and V_ types internally. I'm not aware of the openhab config if that would allow this, or that such a setup would require a lot of coding at openhab side.
                            [EDIT]
                            It would be more difficult to read though if a path would only exist of numbers. But could also introduce easier maintainability in your library because you wouldn't have to keep track on type namings.
                            [/EDIT].
                            • JohnJ John
                              [EDIT]
                              [/EDIT].
                              DammeD
                              DammeD
                              Damme
                              Code Contributor
                              @John That was my first aproach, and I might set a define configuration to choose if the MQTT gateway should translate or not. As you say, the footprint would be much smaller.
                              Might be next version of the MQTT, slectable address layout :)
                              • JohnJ
                                JohnJ
                                John
                                #23
                                @Damme
                                That would be really cool :)
                                It would be nice though if there was a way to identify node id's with AUTO turned on. Maybe i'm missing something or do you have to know up front with auto enabled which node id is going to be assigned?
                                I'm just asking this because of identifying new/existing nodes in the network. Is it the V_SKETCH_NAME i can refer to?
                                And i hope some last questions protocol specific:
                                • Version compatibility is 3.1?
                                • All session are clean by default?
                                • JohnJ John
                                  @Damme
                                  DammeD
                                  DammeD
                                  Damme
                                  Code Contributor
                                  #24
                                  @John upon node startup it translates gw.sendSketchInfo("Battery Meter", "1.0"); into MyMQTT/20/255/V_SKETCH_NAME and version
                                  so you could have a list as in my first post and it would get filled up with all your sketch names
                                  @John ; Yes and I hope so :) (I might have missed some stuff, I do not take regard of QOS etc)
                                  if its not working,, I'll try to fix it :)
                                  • JohnJ
                                    JohnJ
                                    John
                                    @Damme
                                    Thanks for all the info. It becomes more clear now, All nodes users add are persistent anyway.
                                    • T ToSa
                                      DammeD
                                      DammeD
                                      Damme
                                      Code Contributor
                                      @ToSa I'll update mqtt later with option to not translate V_TYPE into name string but to keep it as a byte, that would save a lot of memory and might solve problem you have. I'll keep you posted
                                      • Z
                                        Z
                                        Zeph
                                        wrote on last edited by Zeph
                                        #27
                                        As I understand it:
                                        The packet on the left would be from the node, the packet on the right would be to the node. Besides swapping sender and destination, the difference is that in 1.4 the gateway does not have the information to binary encode the value, so it sends the value as a string (payload type 0).
                                        EDIT: added alternate MQTT respresentation of V_code as numeric
                                        • Z Zeph
                                          As I understand it:
                                          DammeD
                                          DammeD
                                          Damme
                                          Code Contributor
                                          @Zeph but soon there will be a choise to translate v_ to text string or keep it as a byte value
