  3. MQTT Broker gateway
MQTT Broker gateway
132 Posts 34 Posters 147.6k Views 7 Watching
  • JohnJ
    JohnJ
    John
    wrote on last edited by John
    @Damme
    I'm currently busy implementing an mqtt client plugin, and i'm going to use mysensors for it's first predefined implementation so i have a couple of questions
    I took a look at the api page and saw this in the mqtt documentation:
    [MQTT_BROKER_PREFIX]/[NodeID]/[SensorID]/V_[SensorType]
    Does this means as example:
    MyMQTT/[0-255]/[0-255]/[STRING]/[VALUE]
    OR this?
    MyMQTT/[0-255]/[0-255]/[0-endvarindex]/[VALUE]
    • Are variable types defined by their index used or by name?
    • Also it states it keeps track of node id's how are these reported by the broker, should the controller still hand out free id's?
    [EDIT]
    I currently do not have the hardware present to at least set it up to test and look at what exactly is happening.
    [/EDIT]
    DammeD 1 Reply Last reply
    • JohnJ John
      @Damme
      OR this?
      [EDIT]
      [/EDIT]
      DammeD
      DammeD
      Damme
      Code Contributor
      wrote on last edited by Damme
      @John MyMQTT/[0-255]/[0-255]/[STRING]/[VALUE]
      MQTT.cpp :
      sprintf(&buffer[buffsize],"/%i/%i/V_%s", msg.sender, msg.sensor, getType(convBuf, &vType[msg.type]));
      note V_%s -> MyMQTT/[0-255]/[0-255]/V_[STRING]/[VALUE]
      also note there is no trailing / before payload, as http://public.dhe.ibm.com/software/dw/webservices/ws-mqtt/mqtt-v3r1.html
      http://mqtt.org/wiki/doku.php/topic_format
      I choose not to have trailing slash, but if needed its easy to make it configurable.
      and get type translates from this list
        char V_0[] PROGMEM = "TEMP";		//V_TEMP
        char V_1[] PROGMEM = "HUM";		//V_HUM
        char V_2[] PROGMEM = "LIGHT";		//V_LIGHT
        char V_3[] PROGMEM = "DIMMER";		//V_DIMMER
        char V_4[] PROGMEM = "PRESSURE";	//V_PRESSURE
        char V_5[] PROGMEM = "FORECAST";	//V_FORECAST
        char V_6[] PROGMEM = "RAIN";		//V_RAIN
        char V_7[] PROGMEM = "RAINRATE";	//V_RAINRATE
        char V_8[] PROGMEM = "WIND";		//V_WIND
        char V_9[] PROGMEM = "GUST";		//V_GUST
        char V_10[] PROGMEM = "DIRECTON";	//V_DIRECTON
        char V_11[] PROGMEM = "UV";		//V_UV
        char V_12[] PROGMEM = "WEIGHT";		//V_WEIGHT
        char V_13[] PROGMEM = "DISTANCE";	//V_DISTANCE
        char V_14[] PROGMEM = "IMPEDANCE";	//V_IMPEDANCE
        char V_15[] PROGMEM = "ARMED";		//V_ARMED
        char V_16[] PROGMEM = "TRIPPED";	//V_TRIPPED
        char V_17[] PROGMEM = "WATT";		//V_WATT
        char V_18[] PROGMEM = "KWH";		//V_KWH
        char V_19[] PROGMEM = "SCENE_ON";	//V_SCENE_ON
        char V_20[] PROGMEM = "SCENE_OFF";	//V_SCENE_OFF
        char V_21[] PROGMEM = "HEATER";		//V_HEATER
        char V_22[] PROGMEM = "HEATER_SW";	//V_HEATER_SW
        char V_23[] PROGMEM = "LIGHT_LEVEL";	//V_LIGHT_LEVEL
        char V_24[] PROGMEM = "VAR1";		//V_VAR1
        char V_25[] PROGMEM = "VAR2";		//V_VAR2
        char V_26[] PROGMEM = "VAR3";		//V_VAR3
        char V_27[] PROGMEM = "VAR4";		//V_VAR4
        char V_28[] PROGMEM = "VAR5";		//V_VAR5
        char V_29[] PROGMEM = "UP";		//V_UP
        char V_30[] PROGMEM = "DOWN";		//V_DOWN
        char V_31[] PROGMEM = "STOP";		//V_STOP
        char V_32[] PROGMEM = "IR_SEND";	//V_IR_SEND
        char V_33[] PROGMEM = "IR_RECEIVE";	//V_IR_RECEIVE
        char V_34[] PROGMEM = "FLOW";		//V_FLOW
        char V_35[] PROGMEM = "VOLUME";		//V_VOLUME
        char V_36[] PROGMEM = "LOCK_STATUS";	//V_LOCK_STATUS
        char V_37[] PROGMEM = "DUST_LEVEL";	//V_DUST_LEVEL
        char V_38[] PROGMEM = "VOLTAGE";	//V_VOLTAGE
        char V_39[] PROGMEM = "CURRENT";	//V_CURRENT
        char V_40[] PROGMEM = "";		//
        char V_41[] PROGMEM = "";		//
        char V_42[] PROGMEM = "";		//
        char V_43[] PROGMEM = "";		//
        char V_44[] PROGMEM = "";		//
        char V_45[] PROGMEM = "";		//
        char V_46[] PROGMEM = "";		//
        char V_47[] PROGMEM = "";		//
        char V_48[] PROGMEM = "";		//
        char V_49[] PROGMEM = "";		//
        char V_50[] PROGMEM = "";		//
        char V_51[] PROGMEM = "";		//
        char V_52[] PROGMEM = "";		//
        char V_53[] PROGMEM = "";		//
        char V_54[] PROGMEM = "";		//
        char V_55[] PROGMEM = "";		//
        char V_56[] PROGMEM = "";		//
        char V_57[] PROGMEM = "";		//
        char V_58[] PROGMEM = "";		//
        char V_59[] PROGMEM = "";		//
        char V_60[] PROGMEM = "Started!\n";	//Custom for MQTTGateway
        char V_61[] PROGMEM = "SKETCH_NAME";	//Custom for MQTTGateway
        char V_62[] PROGMEM = "SKETCH_VERSION"; //Custom for MQTTGateway
        char V_63[] PROGMEM = "UNKNOWN"; 	//Custom for MQTTGateway
        char V_64[] PROGMEM = "FW_CREQ"; 	//Custom for MQTTGateway
        char V_65[] PROGMEM = "FW_CRES"; 	//Custom for MQTTGateway
        char V_66[] PROGMEM = "FW_REQ"; 	//Custom for MQTTGateway
        char V_67[] PROGMEM = "FW_RES"; 	//Custom for MQTTGateway
      The MQTTgateway hands out ID's; configured in MQTT.h:
        #define MQTT_FIRST_SENSORID	20  		// If you want manually configured nodes below this value. 255 = Disable
        #define MQTT_LAST_SENSORID	254 		// 254 is max! 255 reserved.
        #define MQTT_BROKER_PREFIX	"MyMQTT"	// First prefix in MQTT tree, keep short!
        #define MQTT_SEND_SUBSCRIPTION 1		// Send empty payload (request) to node upon MQTT client subscribe request.
        // NOTE above : Beware to check if there is any length on payload in your incommingMessage code:
        // Example: if (msg.type==V_LIGHT && strlen(msg.getString())>0) otherwise the code might do strange things.
      • JohnJ
        JohnJ
        John
        @Damme
        Clear!
        And how about the internal messages? Are these somewhat compatible with the Serial API? Like this one now has a "I_GATEWAY_READY" internal var, this one complies then with the "Started!\n" message?
        Also about the presentation (if the node does it), are these also passed through?
        I know it's a bit question banging... But i just want to do it right.
        • JohnJ John
          @Damme
          Clear!
          DammeD
          DammeD
          Damme
          Code Contributor
          @John No worries! :)
          Presentation is On Todo.. Or Rather To think About list is presentation . I dont do anything with that as it is (Just ignores it). I havn't had any good idea for that yet.
          Internal is nothing more or less, it connects and set a variable that it is connected. :) But sure, there could be transport for internal messages also.
          I do have an experimental version there I can send internal messages to reboot node, reboot gateway and set clear read eeprom values. (over mqtt-protocol) but this s not finnished yet.. Ideas are welcome!
          • DammeD Damme
            DammeD
            DammeD
            Damme
            Code Contributor
            @John About Presentation ; My idea was that next version of the variable system I will either store some bytes in the MQTT gateway about what S_types to V_types, or hopefully the next protocol contains both those so the GW doesnt have to remember. And then add an extra directory to the MQTT path ( MyMQTT/[0-255]/[0-255]/S_[STRING]/V_[STRING]/[VALUE]
            • JohnJ
              JohnJ
              John
              #21
              I think maybe it depends on the next protocol implementation. Personally i wouldn't mind if the full path mapping was /[0-255]/[0-255]/etc.. to keep (prog)mem print smaller (use the V_ and S_ array index values). It could leave space for more specific things or some extra gateway specific functions.
              it would be nice if the mqtt gateway output was "cloned" to the serial output. Controllers should/could be able to map the S_ and V_ types internally. I'm not aware of the openhab config if that would allow this, or that such a setup would require a lot of coding at openhab side.
              [EDIT]
              It would be more difficult to read though if a path would only exist of numbers. But could also introduce easier maintainability in your library because you wouldn't have to keep track on type namings.
              [/EDIT].
              • JohnJ John
                [EDIT]
                [/EDIT].
                DammeD
                DammeD
                Damme
                Code Contributor
                @John That was my first aproach, and I might set a define configuration to choose if the MQTT gateway should translate or not. As you say, the footprint would be much smaller.
                Might be next version of the MQTT, slectable address layout :)
                • JohnJ
                  JohnJ
                  John
                  #23
                  @Damme
                  That would be really cool :)
                  It would be nice though if there was a way to identify node id's with AUTO turned on. Maybe i'm missing something or do you have to know up front with auto enabled which node id is going to be assigned?
                  I'm just asking this because of identifying new/existing nodes in the network. Is it the V_SKETCH_NAME i can refer to?
                  And i hope some last questions protocol specific:
                  • Version compatibility is 3.1?
                  • All session are clean by default?
                  • JohnJ John
                    @Damme
                    DammeD
                    DammeD
                    Damme
                    Code Contributor
                    #24
                    @John upon node startup it translates gw.sendSketchInfo("Battery Meter", "1.0"); into MyMQTT/20/255/V_SKETCH_NAME and version
                    so you could have a list as in my first post and it would get filled up with all your sketch names
                    @John ; Yes and I hope so :) (I might have missed some stuff, I do not take regard of QOS etc)
                    if its not working,, I'll try to fix it :)
                    • JohnJ
                      JohnJ
                      John
                      @Damme
                      Thanks for all the info. It becomes more clear now, All nodes users add are persistent anyway.
                      • T ToSa
                        I can confirm it's working with UIPEthernet.h and the ENC28J60 module as well. You need to turn off debugging in MyConfig.h to make the code fit.
                        DammeD
                        DammeD
                        Damme
                        Code Contributor
                        @ToSa I'll update mqtt later with option to not translate V_TYPE into name string but to keep it as a byte, that would save a lot of memory and might solve problem you have. I'll keep you posted
                        • Z
                          Z
                          Zeph
                          wrote on last edited by Zeph
                          #27
                          As I understand it:
                          The packet on the left would be from the node, the packet on the right would be to the node. Besides swapping sender and destination, the difference is that in 1.4 the gateway does not have the information to binary encode the value, so it sends the value as a string (payload type 0).
                          EDIT: added alternate MQTT respresentation of V_code as numeric
                          • Z Zeph
                            As I understand it:
                            DammeD
                            DammeD
                            Damme
                            Code Contributor
                            @Zeph but soon there will be a choise to translate v_ to text string or keep it as a byte value
                            • Z
                              Z
                              Zeph
                              #29
                              At first, I thought MQTT would be a great extension to the functionality, in particular because it might systematize the idea of routing messages to more than one destination - eg: to both a HA controller and to a cloud storage service.
                              So I saw these possible advantages of MQTT:
                              • Route to multiple destinations, dynamically updated
                              • Subscription wildcards to filter for desired subsets
                              • Possibly easier to build plug-ins for some HA controllers
                              As I look deeper into it, I'm coming to wonder about that.
                              • There are lighter weight ways to send to more than one destination
                              • Does subscription wildcarding meet the filtering needs well (below)?
                              • Is it easier or not?
                              I'm wondering what subscription wildcards really get used - how valuable is the type of filtering functionality offered by MQTT for our purposes? The meaingful patterns I would imagine are:
                              • everything
                              • everything from one node
                              • everything from one child of one node
                              • everything of type V_RAIN from one child of one node (ie: one variable)
                              • everything of type V_RAIN from anywhere
                              Are any of these (or other options) in use except "everything"? Do you anticipate that they will be?
                              Just as "route to multiple destinations" could be lighter, filtering could be done differently as well. For example, suppose you wanted to receive all report of inside temperature (7 sensors in your network) or humidity (5 sensors), but not outside temp or humidity and not other v codes. That might take 12 subscriptions - and they would have to be manually set up, or make use of manually entered metadata tables in the controller plug-in (eg: the plug-in might be configured to know which nodes had temp and/or humidity, and which ones were considered "inside", if it was written to handled that).
                              I could imagine that even if the subscription filtering wasn't highly useful, MQTT might make it easier to create plug-ins for some HA controllers, than using semicolon separated values (serial text format). Is that the case?
                              I'm very open to hearing other advantages of MQTT, I'm not against it, just trying to understand the benefits vs cost aspect better.
                              • Z
                                Z
                                Zeph
                                #30
                                The other extension that occurs to me, in the gateway-as-transparent-switch model, is that if we ever wanted to encode binary values OTA from the gateway to the node, the plug-in would have to tell the gateway which payload_type to use. In the Semicolon Separted Values format, that could be another parameter, eg:
                                <node id>;<child id>;<command>;<ack>;<v_code>;<payload_type>;<value>
                                Or it could be added to one of the other fields with a comma sub-delimiter, etc.
                                How would a controller plug in tell the MQTT gateway to use payload type P_UNIT16 to send to node 7?
                                I'm thinking that it would be done in the value string, rather than encoded into the topic. So maybe the value string goes from "321" to "4,321" or something like that.
                                • JohnJ
                                  JohnJ
                                  John
                                  @Damme
                                  What happens if a node does not receive it's address when it requests one (because of failed send). It is not registered within the broker?
                                  • DammeD Damme
                                    ToSa
                                    Code Contributor
                                    I could not follow the discussions the last few days - will definitely have a look over the weekend and let you know if that worked. Thanks!
                                    • JohnJ
                                      JohnJ
                                      John
                                      @Damme
                                      When the MQTT gateway prints information about itself like "started", is this done with node id 0 or 255?
                                      • JohnJ John
                                        @Damme
                                        DammeD
                                        DammeD
                                        Damme
                                        Code Contributor
                                        @John 'started' is only a internal log message, I've changed how that part works.
                                        I've also fixed a couple of bugs and will test the changes tomorrow before I publish them.
                                        New functionallity there user can choose of MQTT should translate ID to V_TYPE or not too.
                                        • JohnJ
                                          JohnJ
                                          John
                                          @Damme
                                          Ok, my plugin will then just try to reconnect.
                                          Ok, i will check that then probably the day after tomorrow, i will make my code take no translation as first and if not found try the naming (internally), because the server takes over the semantics anyway because it also is going to include a MQTT broker service.
                                          Currently the MQTT implementation is being tested with an end user. Maybe he will help test the new possibility without V_TYPE translation when your changes are implemented.
