  3. 42v LED dimmer
42v LED dimmer
11 Posts 6 Posters 4.6k Views 6 Watching
  • SweebeeS
    SweebeeS
    Sweebee
    The example you posted uses a irlz44n. According the data sheet it can handle 55v, so that should work. To power the arduino you can look for a stepdown module.
    • the cosmic gateT
      the cosmic gateT
      the cosmic gate
      wrote on last edited by the cosmic gate
      But maybe the arduino input on the RAW ports ?
      I think i need some Step Down dc-dc convertor for this
      There's more than meets the eye
      • sundberg84S
        sundberg84S
        Yes - you do. Ardunio can handle 12v on raw (in best cases - clones can fry).
        the cosmic gateT 1 Reply Last reply
        • sundberg84S sundberg84
          the cosmic gateT
          the cosmic gateT
          the cosmic gate
          Thnx , thnx the layout would be different. Because the LEDs needs 48v
          • TheoLT
            TheoLT
            TheoL
            I fried a ProMini 3.3V while putting 12V on the raw pin. I suggest you add some power regulator and feed the Arduino with no more than 9V. Better safe than sorry.
            I'm lucky I can still feed the ProMini throught the FDTI pins, but it's not ideally.
            • TheoLT TheoL
              the cosmic gateT
              the cosmic gateT
              the cosmic gate
              aaai frying one would cost you €5 :) i already ordered some power regulators to set the input on this raw ports.
              But the re-think the design a bit
              TheoLT 1 Reply Last reply
              • the cosmic gateT the cosmic gate
                TheoLT
                TheoLT
                TheoL
                @the-cosmic-gate I think I order 5 ProMini's for around 8 dollars. So the damage wasn't too big ;-)
                • E
                  E
                  emc2
                  I'm in the process of building a 34V LED dimmer (waiting for my dirtypcbs to be delivered). I'm doing a 34V -> 12V (I plan to also control a 12V cpu fan) -> 3.3V
                  I've been using http://www.mouser.com/ds/2/281/dms-78xxsr-47233.pdf (12V version) on my breadboard but 5V and 3.3V versions are also available.
                  These modules are awesome, no heat, very stable, well filtered, available on mouser for ~$9. Usually overpriced on ebay (~$30)
                  Technically the datasheet say it should be able to handle 40V for low currents even up to 45V maximum.
                  If you only power the arduino / radio this step down module at 5 or 3.3V may be a good option for you.
                  Another option is http://www.ebay.com/itm/3-Terminal-12V-1A-Switching-Voltage-Regulator-Power-Supply-/251971614470
                  I bought 2 of these to be on my final PCB. Max is supposed to be 40V but it may be worth testing at 42V. Seller is the maker, he is very friendly and should be able to tell you if 42V is fine.
                  • the cosmic gateT
                    the cosmic gateT
                    the cosmic gate
                    i just recieved the voltage regulator and tried it without result :(
                    The LED light i;'ve got lphilips InStyle
                    In the spec's i read that i have to use for dimming : phase cutting dimmers , that's something different the PWM i think ;S ?
                    Is there oneother solution i can try / use ?
                    • B
                      B
                      boozz
                      @the-cosmic-gate
                      That should be a leading edge (Triac based, relatively cheap) or trailing edge (expensive) dimmer I suppose.
                      a leading edge dimmer is discussed in this thread: https://forum.mysensors.org/topic/3953/4-channel-ac-dimer/2
                      Is there anyone here that combined a mysensors-sketch with a trailing edge dimmer?
                      BR,
                      Boozz
