  3. MySensors API ver 1.6.1: MQTTClientGateway - RF69 - Arduino Uno - W5100 Shield
12 Posts 4 Posters 4.4k Views 3 Watching
  • X
    X
    xefil
    Hello to all!
    I've moved my structure to the new API version 1.6.1 succesfully. Then I've recompiled the MQTT Gateway with my NRF24L01+ to use the MQTTClientGateway and send the messages to a mosquitto server. Until here all works well.
    Now I would like to add a second radio network because seems (AFAYK) the RF69 has a better range. I'm starting to setup the MQTT Client Gateway but I'm getting always "check wires". Maybe the MQTT Client Gateway is not supported with the RF69?
    Let's start with my hardware setup:
    • Arduino Uno R3
    • W5100 Shield
    • HopeRF RFM69W 868Mhz
    I've connected the radio as follow:
    HopeRF RFM69W 868Mhz ----> Arduino W5100 Shield
    3.3V -> 3.3V
    Groud -> Ground
    DI00 -> Digital 2
    NSS -> Digital 6
    MISO -> A2
    MOSI -> A1
    SCK -> A0
    Then, into MyConfig.h I've set:
    #define MY_SOFTSPI
    Here both files:
    mymqttgatewayrf69.ino
    //#define MY_RADIO_NRF24
    #define MY_RADIO_RFM69
    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway2-out"
    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway2-in"
    // Set MQTT client id
    #define MY_MQTT_CLIENT_ID "mysensors-2"
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
      #define MY_SOFTSPI
    #define MY_RF24_CE_PIN 5
    #define MY_RF24_CS_PIN 6
    #define MY_IP_ADDRESS 192,168,1,52
    // MQTT broker ip address.
    #define MY_CONTROLLER_IP_ADDRESS 192,168,1,50
    #define MY_PORT 1883
    // Flash leds on rx/tx/err
    // Set blinking period
    // Enable inclusion mode
    #include <Ethernet.h>
    MyConfig.h
     * @file MyConfig.h
    #ifndef MyConfig_h
    #define MyConfig_h
    #include <stdint.h>
    *  Serial and debug options
    // Enables this in sketch to show debug prints. This option will add a lot to the size of the
    // Enable MY_DEBUG_VERBOSE flag for verbose debug prints. Requires DEBUG to be enabled.
    //#define MY_DEBUG_VERBOSE
    //#define MY_DISABLED_SERIAL
    #ifdef MY_DISABLED_SERIAL
    #undef MY_DEBUG
    // Serial output baud rate (debug prints and serial gateway speed)
    #ifndef MY_BAUD_RATE
    #define MY_BAUD_RATE 115200
    //#define MY_RS485
    // Node id defaults to AUTO (tries to fetch id from controller)
    #ifndef MY_NODE_ID
    #define MY_NODE_ID AUTO
    // Node parent defaults to AUTO (tries to find a parent automatically)
    #ifndef MY_PARENT_NODE_ID
    // The wait period before going to sleep when using smartSleep-functions
    // This period has to be long enough for controller to be able to send out
    // potential buffered messages.
    #ifndef MY_OTA_FLASH_SS
    #define MY_OTA_FLASH_SS 8
    // Flash jdecid
    #ifndef MY_OTA_FLASH_JDECID
    *  Gateway config
    // Max buffersize needed for messages coming from controller
    // Max buffer size when sending messages
    // Max number of parallel clients (sever mode)
    *  Information LEDs blinking
    // disabled in the gateway.
    //#define MY_LEDS_BLINKING_FEATURE
    // off when blinking
    #ifndef MY_DEFAULT_LED_BLINK_PERIOD
    // The RX LED default pin
    #ifndef MY_DEFAULT_RX_LED_PIN
    		#define MY_DEFAULT_RX_LED_PIN 8
    		#define MY_DEFAULT_RX_LED_PIN 6
    // The TX LED default pin
    #ifndef MY_DEFAULT_TX_LED_PIN
    		#define MY_DEFAULT_TX_LED_PIN 9
    		#define MY_DEFAULT_TX_LED_PIN 5
    // The Error LED default pin
    #ifndef MY_DEFAULT_ERR_LED_PIN
    		#define MY_DEFAULT_ERR_LED_PIN 7
    		#define MY_DEFAULT_ERR_LED_PIN 4
    // The default input pin used for the inclusion mode button
    // Number of seconds (default one minute) inclusion mode should be enabled
    *  Message Signing Settings
     * @def MY_SIGNING_ATSHA204
    //#define MY_SIGNING_ATSHA204
     * @def MY_SIGNING_SOFT
    //#define MY_SIGNING_SOFT
     * @def MY_SIGNING_SOFT_SERIAL
     * @brief Serial number for SW signing enabled node
     * Set the soft_serial value to an arbitrary value for proper security.
     * It should be random and unique for each node.
    #ifndef MY_SIGNING_SOFT_SERIAL
    #define MY_SIGNING_SOFT_SERIAL 0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09
     * @def MY_SIGNING_SOFT_HMAC_KEY
     * @brief Key to use for HMAC calculation in MySigningAtsha204Soft (32 bytes)
    #ifndef MY_SIGNING_SOFT_HMAC_KEY
    #define MY_SIGNING_SOFT_HMAC_KEY 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
    *  RS485 Driver Defaults
    #ifndef MY_RS485_BAUD_RATE
    *  NRF24L01 Driver Defaults
    // Enables RF24 encryption (all nodes and gateway must have this enabled)
    // Default encryption key. Override in sketch if needed.
    #ifndef MY_RF24_ENCRYPTKEY
    #define MY_RF24_ENCRYPTKEY 0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x10,0x11,0x12,0x13,0x14,0x15,0x16
    // Default pin settings. Override in sketch if needed.
    #ifndef MY_RF24_CE_PIN
    		#define MY_RF24_CE_PIN 4
    		#define MY_RF24_CE_PIN 27
    		#define MY_RF24_CE_PIN 9
    #ifndef MY_RF24_CS_PIN
    		#define MY_RF24_CS_PIN 15
    		#define MY_RF24_CS_PIN 3
    		#define MY_RF24_CS_PIN 10
    #ifndef MY_RF24_PA_LEVEL
    #ifndef MY_RF24_CHANNEL
    #define MY_RF24_CHANNEL	76
    #ifndef MY_RF24_DATARATE
    #ifndef MY_RF24_BASE_RADIO_ID
    #define MY_RF24_BASE_RADIO_ID ((uint64_t)0xA8A8E1FC00LL)
    #define MY_SOFTSPI
    #ifndef MY_SOFT_SPI_SCK_PIN
    #ifndef MY_SOFT_SPI_MISO_PIN
    #ifndef MY_SOFT_SPI_MOSI_PIN
    *  RFM69 Driver Defaults
    #ifndef MY_RFM69_FREQUENCY
    // #define MY_RFM69_FREQUENCY   RF69_433MHZ
    //#define MY_RFM69_FREQUENCY     RF69_915MHZ
    // Enable this if you're running the RFM69HW model
    #ifdef MY_IS_RFM69HW
    	#define MY_RFM69HW true
    	#define MY_RFM69HW false
    #ifndef MY_RFM69_NETWORKID
    #ifndef MY_RF69_IRQ_PIN
    #ifndef MY_RF69_SPI_CS
    #ifndef MY_RF69_IRQ_NUM
    #ifndef MY_RFM69_ENCRYPTKEY
    #define MY_RFM69_ENCRYPTKEY    "sampleEncryptKey" //exactly the same 16 characters/bytes on all nodes!
    //#define MY_GATEWAY_W5100
    //#define MY_GATEWAY_ENC28J60
    //#define MY_GATEWAY_ESP8266
    // The port to open on controller or gateway
    #ifndef MY_PORT
    #define MY_PORT 5003
    //#define MY_USE_UDP
    // DHCP, default renewal setting
    #ifndef MY_MAC_ADDRESS
    #if DOXYGEN
    If I try to start the node:
    0;255;3;0;9;Starting gateway (RRNGA-, 1.6.0-beta)
    0;255;3;0;9;Radio init failed. Check wiring.
    Any idea or help?
    Thanks!!
    Simon
    • X xefil
      Hello to all!
      • Arduino Uno R3
      • W5100 Shield
      3.3V -> 3.3V
      Groud -> Ground
      DI00 -> Digital 2
      NSS -> Digital 6
      MISO -> A2
      MOSI -> A1
      SCK -> A0
      #define MY_SOFTSPI
      Here both files:
        #define MY_SOFTSPI
      MyConfig.h
       * @file MyConfig.h
      #ifndef MyConfig_h
      #define MyConfig_h
      #include <stdint.h>
      #undef MY_DEBUG
      //#define MY_RS485
      #ifndef MY_NODE_ID
      // Flash jdecid
      *  Gateway config
      #define MY_SOFTSPI
      #ifndef MY_PORT
      #if DOXYGEN
      Any idea or help?
      Thanks!!
      Simon
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      @xefil
      Hi!
      NSS, MOSI and SCK on the RFM69 are not 5 V tolerant. Are you using a logic level converter?
      X 1 Reply Last reply
        hi. I'm not using softspi on my side. but as I'm understanding this you're connecting rfm69 and w5100 on softspi together.
        I guess you should have your rfm69 on regular hardware spi pins, and the w5100 on softspi (or vice versa).
        And then be careful like said above, rfm69 is not 5v tolerant and UNO pins are 5v if i remember right (I have no uno ..). You have to use a logic level converter for spi pins (to convert 5v uno signals to 3v rfm69 etc..).
          @xefil
          Hi!
          X
          X
          xefil
          @martinhjelmare
          Hi, well. I'm not so proof with that at all. Feeding it with 3.3V I was thinking it's enough. Isn't the same as for the NRF24L01+. It has it own 3.3V pin on the shield. I've an Arduino Diemilanove with W5100 for the NRF24L01+ as MQTTClientGateway and it works great.
          @scalz
          Hi! For the 5v question see above.
          For the pins, could you give me some pratical code hints based on the above sketch I've posted?
          Thanks to all!
          Simon
            @xefil
            you have connected radio and ethernet together on same spi bus. in theory, you could do but you wouldn't need softspi in this case ;) actually (I don't know if it's fixed), you can't do this when using w5100.
            Here connection is explained
            https://www.mysensors.org/build/ethernet_gateway
            for pin configuration then, look at myconfig.h
            but I don't use softspi with my rfm69 so I can't tell you. I would prefer use a board with two hardware spi bus like tbowmo GW for instance (I'm using an usb gw, and another one wifi esp8266 for the moment)
            • X
              X
              xefil
              wrote on last edited by xefil
              Hi @scalz again :)
              I've found this that could help to use SOFTSPI (https://github.com/gieemek/) but seems related to API 1.5 and I'm using 1.6 and it doesn't have the MQTTClient version.
              I'm still in big doubt on WHY I have to use SOFTSPI. AFAYK it's 'cause it shares SPI and one of them needs to use software emulation.
              If so, isn't enough if W5100 uses SOFT? But being a shield it's connected to the SPI port directly so the radio must be set to SOFT-SPI?
              For the logic level converter it's something like that?
              http://www.circuitointegrato.com/3071-thickbox_default/ebay.jpg
              (IIC I2C level converter module, 5-3v system compatible, arduino sensor module)
              Could I have damaged the radio without the level converter?
              I would like to prevent buying more components and find out that I cannot reach the needed goal.
              Any suggestion to create the MQTTClientGateway with the aboce hardware?
              I'm using Openhab as Controller. Any other alternative could be apreciated.
              I should have a Arduino Pro Mini 3.3V (so it doesn't require level converter) and could use the SerialGateway connecting it directly to the Raspberry Openhab?
              Simon
              • X
                X
                xefil
                Hi again to all!
                Noone has suggestions or answers for what asked above?
                I would have a ENC28J60 network controller. Would this help in solving the issue in any way?
                Main goal: MQTTGatewayClient. Alternatives are accepted as well :+1:
                Simon
                • X xefil
                  Hi again to all!
                  Simon
                  martinhjelmareM
                  martinhjelmareM
                  martinhjelmare
                  @xefil
                  For the Uno you have to use a logic level converter to connect the RFM69. If you use a Pro Mini 3.3 V you don't need a logic converter but you need to be able to decrease the baudrate at the controller for the serial connection to work, if using that gateway type.
                  Regarding ethernet gateway and SPI, I suggest you follow the build guide. I don't recommend the ENC module as it's notoriously hard to get working together with mysensors.
                    @xefil
                    X
                    X
                    xefil
                    @martinhjelmare said:
                    @xefil
                    Ok, I'll order one. My big doubt is if I can then use the radio RFM69 + the W5100 for a MQTTClientGateway. I've tested it only for W5100 with NRF24L01+ and I fear the MQTTClientgateway doen't work with RFM69.
                    Do you mean decrease it from 115200 to lower? Which speed? why?
                    Ok to not use then ENC. I've followed the build guide, but, as written before, I think there is an incompatibility to use RFM69 and W5100 as gateway, especially as mqttclientgateway. Any experience would be great to be shared ;)
                    Simon
                    • X xefil
                      @xefil
                      Simon
                      martinhjelmareM
                      martinhjelmareM
                      martinhjelmare
                      @xefil
                      115200 is too fast for Arduino at 8 MHz. Use 38400.
                      I haven't tested the RFM69 myself yet, but I don't remember reading that it should be incompatible with the W5100 either.
                      • X
                        X
                        xefil
                        I've purchased this i2C level converter to use the RFM69 radio on my Arduino Uno:
                        http://www.ebay.it/itm/222115738795
                        Ehm, how do I use it :-)
                        Thanks for the support!
                        PS: As written at the beginning of this thread, I need to use the Arduino Uno as a gateway, so it has the ethernet shield as well.
                        THANKS!
                        Simon
                        • mfalkviddM
                          If anyone answers @xefil's question above, please answer in this thread to avoid confusion.
                          @xefil: Please don't post the same question in more than one place. People will waste their time answering in one thread while the question might have been answered in another thread already.
