  3. Problem with optimizing power consumption
8 Posts 3 Posters 2.1k Views 4 Watching
  • vgaV Offline
    vgaV Offline
    vga
    i´ve made a sensor with the following hardware:
    Arduino Mini Pro 3,3v 8Mhz: removed regulator, removed power-LED
    NRF24L01+ Tranceiver
    Water-Flow Sensor
    The Flow-Sensor works, but now i want to power it with a battery:
    In measuring mode, the consumption is 19mA, when entering gw.sleep the power consumption of the Sensor reduces to 2mA.
    (also if I disconnect the Flow Sensor, and only the Transceiver is connected to the Arduino, it is still 2mA)
    Is there a way to optimize the power consumption more?
    I´ve heard about 120uA in sleep mode?
    Maybe the gw.sleep does not turn of the ADC, SPI, BOD, like the LowPower library?
    BTW, when i try to include the LowPower library, the arduino IDE says, it is not possible to compile LowPower for Arduino Pro Mini.
    Here is my code:
    // Sleep Mode Libraries laden
    #include <avr/sleep.h>
    #include <avr/power.h>
    // MySensor Library hinzufügen
    #define CHILD_ID 0   // Id of the sensor child
    //Batteriestatus
    int oldBatteryPcnt = 0;
    MyMessage flowMsg(CHILD_ID,V_FLOW);
    MyMessage volumeMsg(CHILD_ID,V_VOLUME);
    volatile int NbTopsFan; //measuring the rising edges of the signal
    float Calc;
    int hallsensor = 3;    //The pin location of the sensor
    unsigned int flowMilliLitres;
    unsigned int lastFlowVal;
    long totalMilliLitres;
    long lastTotalVal;
    void rpm ()     //This is the function that the interupt calls
      NbTopsFan++;  //This function measures the rising and falling edge of the hall effect sensors signal
    // The setup() method runs once, when the sketch starts
    void setup() //
      // Start Gateway Kommunikation
      gw.begin();
      gw.sendSketchInfo("Water Flow Sensor", "1.0");
      gw.present(CHILD_ID, S_WATER);
      pinMode(hallsensor, INPUT); //initializes digital pin 2 as an input
      Serial.begin(115200); //This is the setup function where the serial port is initialised,
      attachInterrupt(1, rpm, RISING); //and the interrupt is attached 1 = Digital Pin 3!
      // Batteriestatus
       analogReference(INTERNAL1V1);
       analogReference(INTERNAL);
    // the loop() method runs over and over again,
    // as long as the Arduino has power
    void loop ()
      NbTopsFan = 0;   //Set NbTops to 0 ready for calculations
      sei();      //Enables interrupts
     if(flowMilliLitres == 0){
        delay (500);
        gw.sleep(300000);
      delay (1000);   //Wait 1 second
      cli();      //Disable interrupts
      Calc = (NbTopsFan / 7.5); //(Pulse frequency) / 7.5Q, = flow rate in L/min
      Serial.print (Calc); //Prints the number calculated above
      Serial.print (" L/min\r\n"); //Prints "L/min" and returns a  new line
      int val=(int)Calc;
      // Divide the flow rate in litres/minute by 60 to determine how many litres have
      // passed through the sensor in this 1 second interval, then multiply by 1000 to
      // convert to millilitres.
      flowMilliLitres = (Calc / 60) * 1000;
      // Add the millilitres passed in this second to the cumulative total
      totalMilliLitres += flowMilliLitres;
      // Print the number of litres flowed in this second
      Serial.print("  Current Liquid Flowing: ");             // Output separator
      Serial.print(flowMilliLitres);
      Serial.print("mL/Sec");
      if(lastFlowVal != flowMilliLitres){
        gw.send(flowMsg.set(flowMilliLitres));
        lastFlowVal = flowMilliLitres;
      // Print the cumulative total of litres flowed since starting
      Serial.print("  Output Liquid Quantity: ");             // Output separator
      Serial.print(totalMilliLitres);
      Serial.println("mL");
      if(lastTotalVal != totalMilliLitres){
        gw.send(volumeMsg.set(totalMilliLitres));
        lastTotalVal = totalMilliLitres;
        //Starting at the first byte on the eeprom.
        //EEPROMWritelong(address, totalMilliLitres);
      // get the battery Voltage
       #ifdef DEBUG
       Serial.println(sensorValue);
       #ifdef DEBUG
       Serial.print(batteryV);
       Serial.println(" V");
       Serial.print(batteryPcnt);
       Serial.println(" %");
    Would be nice to get some tipps for reducing the power consumption more, thanks!
    Y 1 Reply Last reply
    • vgaV vga
      Water-Flow Sensor
      Here is my code:
      //Batteriestatus
      float Calc;
      long lastTotalVal;
      void setup() //
        gw.begin();
        // Batteriestatus
      void loop ()
          delay (500);
          gw.sleep(300000);
        int val=(int)Calc;
         #ifdef DEBUG
         #ifdef DEBUG
      Y Offline
      Y Offline
      @vga did you try searching the forum first?
      There are numerous topics on power consumption in sleep mode, containing many tips!
      • vgaV Offline
        vgaV Offline
        vga
        yes, i used the search function, but there are no tips which are helpful for my problem.
        While sleep mode, using gw.sleep, the power consumption is still 2mA.
        A 1 Reply Last reply
        • vgaV vga
          A Offline
          A Offline
          AWI
          @vga The gw.sleep() lets you go as low as 2uA so there must be something else in your circuit which still consumes.. Maybe (internal) pull-ups?
          • vgaV Offline
            vgaV Offline
            vga
            @AWI you are right. My fault, I checked again my wiring. the flow sensor is connected to vcc, so it consumes permanently. disconnected and restarted the arduino, the consumption in sleep is 0,1mA.
            so i tried to connect the flow sensor to a digital pin, set it to output mode and put it HIGH.
            When it go to sleep i set it to LOW.
            But I fail to see that it wake up again with interruptpin, when sensor change, but if it has no power, of course it can not change! :smirk:
            any idea how to make the best of it?
            timer interrupt is no alternative, cause of possible missing sensor activity.
            • vgaV vga
              A Offline
              A Offline
              AWI
              @vga What kind of flow sensor are you using? If you could use a passive type (i.e. reed contact) that would make the difference..
              • vgaV Offline
                vgaV Offline
                vga
                i am using this sensor:
                http://www.seeedstudio.com/wiki/images/b/b7/Water_flow_sensor_datasheet.pdf
                Do you know a "reed Sensor" for such a my sensor project?
                • vgaV vga
                  A Offline
                  A Offline
                  AWI
                  @vga The sensor you are referring to is working with "hall" effect. I can't find the internal schematics of the thing but I assume there are some active components to give you a nice square wave output. Another principle would be a magnet with reed (magnetic) contact which you can read with minimal current.
                  You can find the " rest" current by measuring the power line of the sensor .
