  3. Multisensor PIR based on IKEA Molgan
112 Posts 21 Posters 71.9k Views 37 Watching
  • T tomkxy
    @dynamite I see no clear pattern for the false triggers. Most of the time it is after about 7 minutes. But not strictly. Sometimes more than a half hour.. Well if I would power the sense bender directly from the battery I either would have to use a regulator or remove one of the batteries. Would the PIR still work reliable with about 2.4V? Would it make sense to try a capacitor between the 3V where I power the sense bender from to ground?
    @tomkxy you can just use 3 batteries to power the pir and only 2 to power the atmega and radio. Just c
    Use the same ground on them, and tap the arduino power after the second battery.
    I have some pirs running this way and they work just fine!
    dynamiteD 1 Reply Last reply
    • YveauxY Yveaux
      dynamiteD
      dynamiteD
      dynamite
      wrote on last edited by dynamite
      #56
      @Yveaux @tomkxy You were one step ahead of me, I was just thinking of that solution. At the moment I am also preparing version 2 of the MOLGAN PIR based on Arduino pro Mini I will check on the false positives as well. But I will feed both the PIR and pro Mini directly from the three batteries.
      • T
        tomkxy
        @Yveaux @dynamite Thanks for your suggestion. I followed @Yveaux suggestion and tapped the power for the sensebender after the second battery. It is now working for 2 hours without any false triggers. I will continue the test (for test purposes the sensor is sitting in a room with usually has no movement).
        • T tomkxy
          @tomkxy :+1:
          The same setup is working fine for me for quite a long time now!
          • T
            tomkxy
            @Yveaux Unfortunately, I still get false triggers. Do you also use a sensebender? Any ideas, what I can try. I tapped into as you suggested to the second battery.
            YveauxY dynamiteD 2 Replies Last reply
            • T tomkxy
              @tomkxy I have some ProMini's (8Mhz) with regulator bypassed which are 2xAA fed in this way.
              The PIRs are HC-SR501's, also with the regulator removed and 3xAA fed.
              I haven't tested this setup on the Molgan's yet, but assuming the IC's are both BISS0001 I expect results to be identical.
              Here's a picture of my setup:
              (Btw. components on the HC-SR501 have been moved to the side to decrease the unit's depth)
              • YveauxY
                FYI, I measured power comsumption on the Mogan when sleeping with and without regulator.
                The power consumption was significantly less with the voltage regulator, then when directly powered from 3xAAA (regulator removed).
                Therefore, my Molgan hack board design targets to use the PIR with regulator (3xAAA input) and the ATmega+nRF powered directly from 2xAAA.
                • T tomkxy
                  dynamiteD
                  dynamiteD
                  dynamite
                  #62
                  @tomkxy I Will put mine for a test run online tonight in the closet. If no trigger than it should be ok.
                  Edit: did something wrong when removing led from pro mini so some debugging is required.... No testing tonight :cry:
                  • T
                    tomkxy
                    I googled a bit regarding PIR false alarms and found a couple of links. Apart from small bugs - which I have not in the room - air vents could trigger false alarms. Thus, I put back the plastic dome and now have sind 4 hours no false alarms. I am now convinced that my false alarms a most probably triggered by placement and may be air vents.
                    http://de.actmeters.com/advice/five-causes-of-pir-false-alarms/
                    https://www.youtube.com/watch?v=h0bp91xy5vY
                    http://www.hkvstar.com/technology-news/how-to-install-pir-sensor-minimize-the-false-alarm.html
                    • T tomkxy
                      @tomkxy of course you should always mount the fresnel cover. It focuses the incoming IR on the sensor and forms a barrier. Without the cover the sensor will always be more sensitive and have a much smaller field of view, increasing sensitivity even more.
                      If an unmodified Molgan doesn't suffer from false triggers, a modified one also shouldn't.
                      This is one more confirmation of the importance of describing your setup accurately :smirk:
                      • T
                        tomkxy
                        I made a couple of additional modifications based on posts here and google results:
                        • put a short wait before the node goes to sleep -> based on reports from that forum
                        • read the motion pin twice with a small wait in between
                        • put a small alu foil between the radio and the PCB -> there are some reports in the internet that RF interference could cause false triggers
                        I had a close look at the sensor today and everything looked okay so far. However, I was moving into the room in and out. Let's see what the result tomorrow will be.
                        • T TimO
                          @tomkxy Nice write up! Do you have an idea on the accuracy of the humidity sensor within the case?
                          tomkxy
                          I did some comparison measure regarding temp and humidity. I place an open Sensebender just beside the modded Molgan. The humidity measured at the Molgan was about 11% lower than the humidity measured by the open Sensebender. With respect to temp the Molgans temp was about 6% lower than the temp measured by the open Sensebender.
                          • T tomkxy
                            TimO
                            @tomkxy Thank you for reporting back!
                            • Cliff KarlssonC
                              Cliff KarlssonC
                              Cliff Karlsson
                              Ok, so if I as a complete beginner want to use a the original pir and control the lights all I need to do is:
                              Tap the power from the regulator U1 and power a 3.3v mini-pro (keeping the 3 batteries)
                              Remove Resistor R17 and connect the solderpoint nearest the chip to an arduino input and I can then basicly be able to run the standard motion sketch ? (After removing the photodiode and bridging the connectors?)
                              I can connect the the other solderpoint to an arduino output and if uploading a sketch witch puts that output HIGH the leds will turn on?
                              If I am fine with 30secs of triggertime I do not have to do anything more?
                              Are all my assumptions correct?
                              dynamiteD rollercontainerR 2 Replies Last reply
                                dynamiteD
                                dynamiteD
                                dynamite
                                @Cliff-Karlsson correct!:smile:
                                  rollercontainerR
                                  rollercontainerR
                                  rollercontainer
                                  @Cliff-Karlsson
                                  Excellent summarized! Perfect HowTo!
                                  Voted Cliff-Karlson for Documentation Team :-D
                                  • Cliff KarlssonC
                                    Cliff KarlssonC
                                    Cliff Karlsson
                                    Haha, right. Last question, if I also want the sensor to report battery-usage. Is there any way to accomplish that without soldering any more resistors?
                                      @Cliff-Karlsson Yes, there is!
                                      Use my Vcc library!
                                      • YveauxY Yveaux
                                        Use my Vcc library!
                                        dynamiteD
                                        dynamiteD
                                        dynamite
                                        @Yveaux @Cliff-Karlsson but in the scheme of cliff he is taken the power after the power regulator. So you are not
                                        Measuring the battery with your VCC library.
                                        • dynamiteD dynamite
                                          @dynamite You're right then. I didn't read his howto, just answered how to read battery voltage without voltage divider ;-)
