  3. GatewayW5100MQTTClient + MY_SIGNING_SOFT + Development Branch + ATMega328 Nano = Sketch Too Large
9 Posts 3 Posters 4.1k Views 3 Watching
  • brendanlB Offline
    brendanlB Offline
    brendanl
    Hi there
    Firstly, thanks for all the great info and advice around the place. I've been quite active and successful on the build front since I started here a few weeks ago. Here's my gateway, a remote temp/switch sensor and a combo RGB controller and temp sensor/ir unit. With the exception of the ir stuff, all are working and connected to OpenHAB via Mosquitto.
    The sensor currently under construction will be smartening up the garage door controller. For this, I'm coming back around and activating Signing. Trouble is, with adding #define MY_SIGNING_SOFT to the stock Dev branch GatewayW5100MQTTClient sketch, I'm getting "Sketch uses 31,070 bytes (101%) of program storage space. Maximum is 30,720 bytes." (MY_DEBUG has been commented out)
    I've got all the HMAC personalization done and loaded into the gateway and the sensor. With the gateway missing the MY_SIGNING_SOFT, the sensor reports "Message is not signed, but it should have been! verify fail" when told to do something.
    I can't figure out why the gateway is too large for the Nano. Besides configuring SoftSPI and the necessary network connectivity IPs (including a static one on the gateway), I've done nothing else to the sketch. The only hint that I'm not alone with this issue is this quote from Anticimex "Soft signing on master with a ethernet gw will not fit as master looks currently and on a AtMega328" This was here 4 months ago.
    Can someone please verify that Soft signing is currently not possible with the MQTT Gateway on the Development branch (2.0.0-beta). If it should be possible, any ideas where I could have gone wrong? (appreciate this is a pretty open question)
    • brendanlB brendanl
      Hi there
      @brendanl you just confirmed it yourself :)
      The ethernet library, mqtt library, soft spi library and soft signing library all add to the total size and at some point it will become too much for the flash size of the mcu.
      Since you are so close, (101%) you might be able to find things to remove to get within the size limit, but it will require some creativity and reading up on different guides on the net.
      If you post your sketch we might be able to help you.
      • brendanlB Offline
        brendanlB Offline
        brendanl
        Thanks. As mentioned, sketch is pretty much stock. I'll have a poke around the core code and see if I can't remove something I'm not using - though I'm expecting 'optional' features to be configurable and defaulted to off, so as mentioned, it will take some creativity.
        cheers
        // Set MQTT client id
        //#define MY_W5100_SPI_EN 4
        // radio on the same spi bus.
          #define MY_SOFTSPI
        #define MY_RF24_CE_PIN 5
        #define MY_RF24_CS_PIN 6
        #define MY_IP_ADDRESS 192,168,1,150
        #define MY_IP_GATEWAY_ADDRESS 192,168,1,254
        #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 100
        #define MY_PORT 1883
        // Flash leds on rx/tx/err
        // Set blinking period
        // Enable inclusion mode
        #include <Ethernet.h>
        • mfalkviddM Offline
          Yup, not much to remove from that sketch. It is already very lean. You could shorten the mqtt prefixes (use just "gw1out" and "gw1in" for example) but I doubt that will save much space.
          • brendanlB Offline
            brendanlB Offline
            brendanl
            wrote on last edited by brendanl
            @mfalkvidd thanks again for your thoughts.
            I wasn't having much luck reducing things, so came across another cunning plan. Initial info here https://bigdanzblog.wordpress.com/2014/10/23/installing-the-optiboot-loader-on-an-arudino-nano-to-fix-the-watch-dog-timer-wdt-issue
            Turn Nano into Uno to free-up more memory (load optiboot bootloader)
            1. Use Uno as programmer – see here: https://learn.sparkfun.com/tutorials/installing-an-arduino-bootloader
            2. Upload Examples/AudrinoISP sketch to Uno
            3. Select type of Board Nano needs to be e.g. Adruino/Genuino Uno
            4. Select Tools/Burn Bootloader – this loads Uno bootloader into Nano. Behind the scenes, this bootloader is C:\Program Files (x86)\Arduino\hardware\arduino\avr\bootloaders\optiboot\optiboot_atmega328.hex (at least for my IDE setup)
            Nano now has 32,256 bytes free instead of 30,720. Plenty enough to store the 31,070 my MQTT/SoftSPI/SigningSoft gateway needs. And after re-running SecurityPersonalizer (because bootloading cleared EEPROM), Signing is now working:
            Signing backend: ATSHA204Soft
            SHA256: EBB61F82572BBB42676ADA13705C918B05588F926D3E15F58800000000000000
            Transmittng nonce
            send: 46-46-0-0 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:EBB61F82572BBB42676ADA13705C918B05588F926D3E15F588
            Signature in message: 0194DB798EFE5B3543EEA0381D7817591E6E5A279A28FC13
            Message to process: 002E0E00020131
            Current nonce: EBB61F82572BBB42676ADA13705C918B05588F926D3E15F588AAAAAAAAAAAAAA
            HMAC: A794DB798EFE5B3543EEA0381D7817591E6E5A279A28FC13A7716480D1820181
            Signature OK
            read: 0-0-46 s=1,c=0,t=2,pt=0,l=1,sg=0:1
            Fantastic!
            A 1 Reply Last reply
              Transmittng nonce
              Signature OK
              Fantastic!
              A Offline
              A Offline
              Anticimex
              @brendanl And that is with the verbose signing output which generate quite a lot of code by itself. Turn off the debugging and you get even more space.
              • brendanlB Offline
                brendanlB Offline
                brendanl
                Thanks for that. However, the above output was at the sensor end, not the gateway. I've got all I was going to get out of the gateway.
                Interestingly the HMAC reported above is not what was stored and reported by SecurityPersonalizer - I had checked before I posted. It must be HMAC along with some other stuff - regardless, I've changed my HMACs now in case anyone in New Zealand felt so inclined to reverse engineer things.
                cheers
                  cheers
                  A Offline
                  A Offline
                  Anticimex
                  @brendanl You are mixing apples and pears :)
                  HMAC is a signature. The personalizer stors a HMAC KEY. The KEY is used to calculate the signature. You will never see the KEY from a UART log (other than the personalizer).
                  • brendanlB Offline
                    brendanlB Offline
                    brendanl
                    Good to know - thanks for pointing that out.
