  3. Looking to switch automation controller software
27 Posts 10 Posters 11.9k Views 8 Watching
  • dbemowskD
    dbemowskD
    @pjr that is exactly what I am talking about. The only thing on my RS485 network is my thermostat. As I mentioned before, I had written a plugin for a project called Open Source Automation that I worked on a few years back and will be trying to find that code. Can't remember if I did that one in Visual Basic or C#. If I did it in VB, it may take a bit to port it to arduino, but if I did it in C#, porting it shouldn't be that hard at all. I just need to bridge that gap.
    K 1 Reply Last reply
    • P
      P
      pjr
      wrote on last edited by pjr
      @AWI I'm kinda waiting that someone with more skills could implement this. Then I can finalize my functionality and a post project topic about it.
      If someone wants to have current version of the source just pm me!
      @dbemowsk what protocol your thermostat is "speaking"?
      • dbemowskD
        dbemowskD
        The protocol as far as I know is specific to RCS hardware. I have never compared it to modus or anything, but it may be similar.
        • dbemowskD dbemowsk
          K
          K
          kimot
          @dbemowsk You can use NODE RED as a translator between your hardware and protokol and then send translated messages to Domoticz ( for example). I think NODE RED + any sw controller is very powerfull combination.
          • dbemowskD
            dbemowskD
            @kimot Does NODE RED have any kind of web interface for flows that are created? I am not seeing anything on their website.
            • mfalkviddM
              This is what node red looks like
              From https://learn.adafruit.com/raspberry-pi-hosting-node-red/what-is-node-red
              • dbemowskD
                dbemowskD
                @mfalkvidd I can see that being nice for the logic side, but what I was asking about when I mentioned a web interface was some nice easy way of looking up the status of devices from something like a floorplan or list view, and a way to control those devices manually if I see the need.
                D K 2 Replies Last reply
                  drock1985
                  @dbemowsk
                  Domoticz. Domoticz offers floorplan setup (just upload a .jpg of the plan) and has manual switches you can set up. As well, the automation uses blocky - an easy to use GUI way of automating. Or LUA; if you are feeling brave.
                  My Projects
                  2 Door Chime Sensor
                  Washing Machine Monitor
                    K
                    K
                    kimot
                    @dbemowsk I think, that for example Domoticz does not understood your RS485 thermostat. So you can recieve its message by serial node in NODE RED,
                    decode message and send it via HTTP to the Domnoticz. Or you are not happy with Domoticz graph style end limitation only 7 days for detail teperature storage. So you can first recieve data from sensor by NODE RED, store them to the file or database and then send them to the Domoticz. I wrote that NODE RED is good for cooperation with other sw controllers, witch do visualisation measured data.
                    • dbemowskD
                      dbemowskD
                      @kimot I see, you are only using NODE RED as a go between for Domoticz, not as the actual controller itself. Like a way to interface hardware that Domoticz doesn't normally recognize.
                      • DidiD
                        DidiD
                        Didi
                        Read this for a Nodered userinterface
                        http://tech.scargill.net/node-red-ui/
                        http://tech.scargill.net/more-node-red-ui/
                        • F
                          F
                          Fabien
                          node-red-ui is currently switching to node-red-dashboard and maintained by the core team.
                          • DidiD
                            DidiD
                            Didi
                            I don´t have noticed that.
                            Here is the github link
                            • dbemowskD
                              dbemowskD
                              So in the interest of keeping my current HA setup running while I get this set up and tested, I figured that this might be a place to use a new controller I got a while back. The controller is an Orange Pi. When a guy from work said he could get me one for $18 US, I couldn't say no. I have had it sitting around for a couple months now waiting to find a use for it. I think I found my use.
                              The unit that I have is an Orange Pi PC which has a 1.6GHz quad coreprocessor with 1GB ram. A lot of choices for OS. Need to find me an 8GB class 10 MicroSD card (Might have one laying around). Then I want to find an automation software that is easy to install and use with this computer. Has anyone in here used an Orange Pi, and if so, what automation software have you used with it?
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @dbemowsk
                                As some of the other posts in this thread indicate, you can use node-red as a middleware, between domoticz (or any other controller frontends you like) and sensors.
                                I'm using it here, between my mysensors GW and domoticz. I have one arduino on my utility meter, that isn't wireless, and doesn't use mysensors protocol. I have used node-red to change it's protocol into mysensors format, and are injecting that into the mysensors datastream into domoticz.
                                At the same time, I have influxdb / grafana installed, and node-red publishes all sensor data into influxdb, so I can use that package as graphing solution.
                                I have been running two controllers at the same time at one point in time, where node-red was feeding the two controllers the same mysensors datastream, and both controllers could send data to mysensors nodes.
                                The possibilities are endless with node-red :)
                                D 1 Reply Last reply
                                • tbowmoT tbowmo
                                  @dbemowsk
                                  drock1985
                                  @tbowmo
                                  Oh wow, going to have to look into this now. Any links to get a person started? Only ever heard of Node-Red so far.
                                  My Projects
                                  2 Door Chime Sensor
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @drock1985
                                    Search the forum, as there are some threads with setup hints etc.
                                    For installation of nodered, you should follow the guides at nodereds website.
                                    • DidiD
                                      DidiD
                                      Didi
                                      Here is a package you can start without installing anything ;-)
