  3. Combining BinarySwitch with PressureSensor
14 Posts 3 Posters 3.9k Views 3 Watching
  • Øyvind LauritzenØ
    Øyvind LauritzenØ
    Øyvind Lauritzen
    I've change the line
    gw.sleep(SLEEP_TIME);
    to
    gw.sleep(digitalPinToInterrupt(BUTTON_PIN), CHANGE, SLEEP_TIME);
    This was what you meant? It doesn't seem to do more than wake up as you said every 60 seconds to transfer the status of all sensors - pressure, switch and temp.
    Did I misunderstand what you meant maybe? :)
    TIA
    • mfalkviddM
      Good thinking. Let's make sure we have the same goal :-)
      • The sensor should send temp/pressure data at least every 60 seconds
      • The sensor should also send switch information every time there is a change (window is opened or closed)
      correct?
      Øyvind LauritzenØ 1 Reply Last reply
        correct?
        Øyvind LauritzenØ
        Øyvind LauritzenØ
        Øyvind Lauritzen
        @mfalkvidd Yes as far as I understand that should be it, unless the forecast algorithm is not for some reason depending on it updating exactly every 60 seconds?
        I am actually gonna be using the switch info to know the state of my garage door, making sure it's not by mistake left open when it shouldn't.
        • mfalkviddM
          Great. Then your code change should be enough. What does the serial debug log of the node say?
          • Øyvind LauritzenØ
            Øyvind LauritzenØ
            Øyvind Lauritzen
            wrote on last edited by Øyvind Lauritzen
            From what the serial monitor is telling me is that it is updating at least temp and pressure, I don't know where I see the actual switch? Domoticz only update temp and pressure every time the switch is triggered, it is not telling me the new state of the switch until at least 60sec from what it seems.
            send: 2-2-0-0 s=0,c=1,t=4,pt=7,l=5,sg=0,st=ok:1019
            Temperature = 25.40 *C
            Pressure = 1019.35 hPa
            Forecast = stable
            Pressure = 1019.32 hPa
            Forecast = stable
            Pressure = 1019.37 hPa
            Forecast = stable
            Pressure = 1019.38 hPa
            Forecast = stable
            • mfalkviddM
              Could you include output from startup as well? You should get at least one switch message when the node is reset.
              Next step is probably to add som Serial.println in various places to see what is happening.
              You have double-checked the wiring? The switch is connected to GND on one side and pin 3 on the other sie?
              • Øyvind LauritzenØ
                Øyvind LauritzenØ
                Øyvind Lauritzen
                Yes it is clear that it is working partly because it will eventually update the state of the switch, but it will not do this as often as temp/pressure. Temp/pressure is updated every time switch is triggered, but still the state of the switch is not reported every time , only when 60+ seconds have passed.
                This is the startup.
                send: 2-2-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
                send: 2-2-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.4
                send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                read: 0-0-2 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                sensor started, id=2, parent=0, distance=1
                send: 2-2-0-0 s=3,c=0,t=0,pt=0,l=0,sg=0,st=ok:
                send: 2-2-0-0 s=255,c=3,t=11,pt=0,l=15,sg=0,st=ok:Pressure Sensor
                send: 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
                send: 2-2-0-0 s=0,c=0,t=8,pt=0,l=0,sg=0,st=ok:
                send: 2-2-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                send: 2-2-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=ok:0
                Temperature = 25.30 *C
                Pressure = 1019.42 hPa
                Forecast = unknown
                send: 2-2-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:25.3
                send: 2-2-0-0 s=0,c=1,t=5,pt=0,l=7,sg=0,st=ok:unknown
                • mfalkviddM
                  If you load the pure binary switch example, does the switch work then? My best guess is that the reed switch is broken or incorrectly wired.
                  • Øyvind LauritzenØ
                    Øyvind LauritzenØ
                    Øyvind Lauritzen
                    I've actually already tried that, worked with no problem. Maybe i've missed something or something similair, lets see what happens after a good nights sleep. Thank you for you help so far. :)
                    • Øyvind LauritzenØ Øyvind Lauritzen
                      martinhjelmareM
                      martinhjelmareM
                      martinhjelmare
                      @Øyvind-Lauritzen
                      Debouncer Bounce won't work with sleep. Use a short sleep of 5 ms to debounce instead. Look at the binary switch sleep example.
