  3. Battery button sensor
mysensor
18 Posts 10 Posters 9.2k Views 13 Watching
  • Ivan ZI
    Ivan ZI
    Ivan Z
    wrote on last edited by Ivan Z
    I wanted to make the most cheap device. And not set hardware debouncing.
    But set external pull-up resistors to reduce power consumption
    Sostware debouncing by delay in interrupt
      Cool. Are the 6 buttons onboard, I don't think so??? does it need to wire them external?
      Is it a reset button on the pic? Maybe I am too curious lol, I can't read your schem (I don't have diptrace). A schematic img could be useful.
      anyway, thx for share :) I have a more complex actuator in design progress, but your can be useful too and is simple :)
      • Ivan ZI
        Ivan ZI
        Ivan Z
        Shem in PDF https://www.openhardware.io/download/56b1cc6b3363a1515ea71115/design/Btn1.pdf
          oki I see :) so one onboard button, others are external. cool, can be useful. thx
          • AnticimexA
            AnticimexA
            Anticimex
            I see you use CERN OHL but I do not find the required files in the repo.
            Where do you store those?
            According to the CERN OHL 1.2 howto, you need to provide the following documentation with your project:
            LICENSE.PDF
            cern_ohl_v_1_2_howto.pdf
            PRODUCT.TXT
            CHANGES.TXT
            Please check the howto closely for how to use the license, or pick another license.
            • Ivan ZI
              Ivan ZI
              Ivan Z
              Append license info
              Debug device
              sam debug photo
              3_1455300763873_IMG_7113.JPG 2_1455300763873_IMG_7101.JPG 1_1455300763873_IMG_7099.JPG 0_1455300763873_IMG_7096.JPG image url)
              • rvendrameR
                rvendrameR
                rvendrame
                @Ivan-Z , how much do you expect for battery life (assuming a regular 250mA CR2032, in the scenario of a single button, regular daily usage in house lighting.
                ESP8266 GW + mySensors 2.3.2
                Alexa / Google Home
                • Ivan ZI
                  Ivan ZI
                  Ivan Z
                  Update
                  • Error. Reversed MISO and MOSI
                  • Append Capacitor C1 on RESET
                  • Change diode component size to SOD-123
                  • Append Pad for external LED
                  Calculate battery life
                  Capacity rating of battery (mAh) = 250
                  Current consumption of device during sleep (mA) = 0.02
                  Current consumption of device during wake (mA) = 18
                  Number of wakeups per hour = 1
                  Duration of wake time (ms) = 20
                  Estimated battery life is: 440.51 days, or 1.21 years.
                  The device wakes up only when pressed button
                    Samuel235
                    This is pretty similar to what I'm currently doing, here. However, mine is just a light switch node, yours is more versatile by the looks of things. Looking pretty nifty though, nice work!
                    MySensors 2.1.1
                    • zeblongZ
                      zeblongZ
                      zeblong
                      @Ivan-Z Добрый день. Я тут новичек но мне ваше устройство хотелось бы попробовать. Я верно понимаю что тут не хватает документации что бы просто заказать производство плат (или изделий целиком)? Можете ли/хотите ли вы выложить их?
                      S 1 Reply Last reply
                      • zeblongZ zeblong
                        Samuel235
                        @zeblong
                        As per the forum user guidelines, point 6 at the following link, https://forum.mysensors.org/topic/610/forum-user-guidelines, states;
                        "6. As this is an English-speaking community, we require that posted content be in the English language, so that it can be well received and properly monitored."
                        Please communicate using English spoken language, if anything it will help you get a response that is relevant.
                        MySensors 2.1.1
                        • zeblongZ
                          zeblongZ
                          zeblong
                          @Samuel235
                          Sorry. I will write in English.
                          I want order manufacture this device. But manufacturer said to me that he need gerber and bom files. I want know can I get this files from Ivan? May be I can get this files from design files? What programm need to this?
                          • zeblongZ zeblong
                            @Samuel235
                            Samuel235
                            @zeblong, you can generate these from the board files, however i'm leaving this one for @Ivan-Z to discuss with you as this is his device and he knows all details regarding this.
                            MySensors 2.1.1
