  3. Battery button sensor
mysensor
18 Posts 10 Posters 9.4k Views 13 Watching
    oki I see :) so one onboard button, others are external. cool, can be useful. thx
    • AnticimexA
      AnticimexA
      Anticimex
      I see you use CERN OHL but I do not find the required files in the repo.
      Where do you store those?
      According to the CERN OHL 1.2 howto, you need to provide the following documentation with your project:
      LICENSE.PDF
      cern_ohl_v_1_2_howto.pdf
      PRODUCT.TXT
      CHANGES.TXT
      Please check the howto closely for how to use the license, or pick another license.
      • Ivan ZI
        Ivan ZI
        Ivan Z
        Append license info
        Debug device
        sam debug photo
        3_1455300763873_IMG_7113.JPG 2_1455300763873_IMG_7101.JPG 1_1455300763873_IMG_7099.JPG 0_1455300763873_IMG_7096.JPG image url)
        • rvendrameR
          rvendrameR
          rvendrame
          @Ivan-Z , how much do you expect for battery life (assuming a regular 250mA CR2032, in the scenario of a single button, regular daily usage in house lighting.
          ESP8266 GW + mySensors 2.3.2
          Alexa / Google Home
          • Ivan ZI
            Ivan ZI
            Ivan Z
            Update
            • Error. Reversed MISO and MOSI
            • Append Capacitor C1 on RESET
            • Change diode component size to SOD-123
            • Append Pad for external LED
            Calculate battery life
            Capacity rating of battery (mAh) = 250
            Current consumption of device during sleep (mA) = 0.02
            Current consumption of device during wake (mA) = 18
            Number of wakeups per hour = 1
            Duration of wake time (ms) = 20
            Estimated battery life is: 440.51 days, or 1.21 years.
            The device wakes up only when pressed button
              Samuel235
              This is pretty similar to what I'm currently doing, here. However, mine is just a light switch node, yours is more versatile by the looks of things. Looking pretty nifty though, nice work!
              MySensors 2.1.1
              • zeblongZ
                zeblongZ
                zeblong
                @Ivan-Z Добрый день. Я тут новичек но мне ваше устройство хотелось бы попробовать. Я верно понимаю что тут не хватает документации что бы просто заказать производство плат (или изделий целиком)? Можете ли/хотите ли вы выложить их?
                S 1 Reply Last reply
                • zeblongZ zeblong
                  Samuel235
                  @zeblong
                  As per the forum user guidelines, point 6 at the following link, https://forum.mysensors.org/topic/610/forum-user-guidelines, states;
                  "6. As this is an English-speaking community, we require that posted content be in the English language, so that it can be well received and properly monitored."
                  Please communicate using English spoken language, if anything it will help you get a response that is relevant.
                  MySensors 2.1.1
                  • zeblongZ
                    zeblongZ
                    zeblong
                    @Samuel235
                    Sorry. I will write in English.
                    I want order manufacture this device. But manufacturer said to me that he need gerber and bom files. I want know can I get this files from Ivan? May be I can get this files from design files? What programm need to this?
                    • zeblongZ zeblong
                      @Samuel235
                      Samuel235
                      @zeblong, you can generate these from the board files, however i'm leaving this one for @Ivan-Z to discuss with you as this is his device and he knows all details regarding this.
                      MySensors 2.1.1
