  3. Automatic Water Meter Reading with a Webcam
15 Posts 9 Posters 28.1k Views 12 Watching
  • G
    G
    gol
    I'm currently working on version 2.0 of the Water Meter Reader. The new version will be based on an OpenWrt device called Dragino and will have a nice looking web GUI for setup and maintenance.
    Of course can I share my Raspberry Pi code. Attached you will find a copy of it. It has dependencies to:
    • libsdl1.2-dev
    • libmosquitto-dev
    The sdl library can you install the ordinary way with apt-get. But libmosquitto you have to install following these steps:
    • wget http://repo.mosquitto.org/debian/mosquitto-repo.gpg.key
    • sudo apt-key add mosquitto-repo.gpg.key
    • cd /etc/apt/sources.list.d/
    • sudo wget http://repo.mosquitto.org/debian/mosquitto-wheezy.list
    • apt-get update
    • apt-cache search mosquitto
    • apt-get install libmosquitto-dev
    It also has a dependency to an external MQTT-broker at 192.168.0.23. You probably have to adapt that to something else or remove it if you dont want to publish the values via MQTT.
    In the structure REGION the sizes and positions of the "Hit areas" are defined.
    water-meter.tar.gz
    • Moshe LivneM Moshe Livne
      cool project! why do you need to monitor the water meter?
      G
      G
      gol
      @Moshe-Livne
      Two main reasons to monitor the water meter
      1. Leakage monitoring. The system can detect very small leakages and send notifications to my mobile.
      2. I'm interested in my water consumption. The values are logged and displayed in my home automation system.
      • G gol
        @Moshe-Livne
        Moshe LivneM
        Moshe LivneM
        Moshe Livne
        @gol fair enough... Thanks!
        • G gol
          • libsdl1.2-dev
          • libmosquitto-dev
          • apt-get update
          water-meter.tar.gz
          ThinkPad
          @gol Thanks. Sounds quite complicated, but i will have a look at it.
          As a home automation controller i use Domoticz so i will probably have to convert it to HTTP GET-requests (http://domoticz.com/wiki/Domoticz_API/JSON_URL's). I don't have any knowledge about MQTT haha.
          • JohnJ
            JohnJ
            John
            Very nice! Gives a nice resolution in used water. I'm wondering in defining the leakage, are you measuring the time it takes to get from region to region?
            What software is used for the recognition? I'm currently busy with face recognition using opencv.
            G 1 Reply Last reply
            • JohnJ John
              G
              G
              gol
              @John
              The output from the water meter reader, published in MQTT, are:
              1. Average flow last minute (liter/minute)
              2. Average flow last 10 minute (liter/10minutes)
              3. Consumption last drain (liter). The number of liters between the last two times with no consumption.
              4. Total consumption (liter)
              The leakage monitoring is very simple. It uses only value 1 and checks if the flow > 0 during a couple of minutes. The accepted duration is very low at night and when nobody is at home.
              All info about the used software you will find earlier in this thread.
              • JohnJ
                JohnJ
                John
                @gol
                Ahh clear. I know the dependencies mentioned. Will later take a look at the software, did not had enough time to download the package to take a look into it ;)
                • P
                  P
                  pawwnu
                  wrote on last edited by pawwnu
                  Hey
                  @gol
                  First of all, this is an excellent job. I love to see that kind of achivements. I am trying to use your code in my university project. I'm going to be analysing how exactly does my heat pump work. I always loved technology as such, however I'm not so good at programming. 😉
                  Here comes my question. Would you be so kind and give me some more info on how to setup Mosquitto broker to work with your code?
                  Thanks in advance and once again congratulations on your idea as well as execution.
                  • F
                    F
                    fje
                    wrote on last edited by fje
                    @gol
                    Hi!
                    Thanks for sharing! I managed to get your code running, altered it to log to a round robin database instead of through Mosquitto, and I am now graphing my water usage! :)
                    I have posted a description of my setup and code (Swedish I'm afraid, google translate is your friend - everyone except @gol ) to http://blog.m.nu/vattenmatning-med-raspberry-pi-och-webkamera/
                    Thanks and Regards,
                    Jim, Linköping
                    • Rasmus7700R
                      Rasmus7700R
                      Rasmus7700
                      Wow that project seems awesome - exactly what i need to my openHab installation :)
                      @gol could you please post some more information regarding the setup? :)
                        A Former User
                        Hey @gol
                        I love this idea of this project. I wanted to see if you made any changes to your code since the last upload? I want to develop something like this for myself and I'm willing to contribute if you had the code uploaded to github or something like that.
                        Throdne
                          Matti Orrberg
                          wrote on last edited by Matti Orrberg
                          There are several solutions for this kind of water reading but all are lacking something for my needs.
                          I've been seeking for a solution which would combine best parts of different projects:
                          1. https://github.com/ecsfang/WaterMeter
                          • accuracy of 0,125 litres by reading only 1 liter dial with 8 trigger points. Easy and this data would be sufficient combined with time stamps.
                          1. https://github.com/jomjol/water-meter-measurement-system
                          • ESP32-CAM as camera and server running the OCR would be a lot cheaper than raspberry system. Usually someone building these have the server and really I wouldn't have any other needs for the Raspberry.
                          • Also this could be integrated ESPHome etc.? So it would be out of the box type design for ie. Home Assistant...
                          1. https://olammi.iki.fi/sw/dialEye/
                          • Possibility to define any IP web camera as source
                          But I'm not any good at programming or coding... I'm not even sure if I describe my wishes correctly, please pardon me.
                          Would I find someone interested enough to combine these three solutions?
                          TL;DR water meter solution development request:
                          • 1 liter dial OCR with 8 trigger points
                          • ESP to server and server OCR software (prefer Ubuntu systems)
                          • MQTT publish and/or Home assistant compatibility via ESPhome or similar systems?
                          Willing to throw in a coffee/beer or two for this matter...
                          Regards, Matti
