  3. Hard Freeze when transmitting data
5 Posts 3 Posters 992 Views 2 Watching
  • Josh CoxJ
    Josh CoxJ
    Josh Cox
    I'm getting a hard freeze (even the hardware watchdog is failing to reset the device) during transmissions, I have code here:
    https://github.com/Bokbot/incubot/tree/mysensor
    its basically a pidloop controlling a lightbulb in an incubator for some eggs.
    so long as I comment out the send lines like this:
    everything runs continuously, but with those lines included the thing freezes randomly after an inconsistent amount of time. Meaning it does transmit for a good fifteen minutes usually before freezing.
    Has anyone else seen behavior like this?
    tekkaT 1 Reply Last reply
    • Josh CoxJ Josh Cox
      tekkaT
      tekkaT
      tekka
      @Josh-Cox Can you post the node debug when it happens?
      • mfalkviddM
        Sounds like a power issue. Do you have a capacitor for the radio? The troubleshooting flowchart can probably be useful.
        • Josh CoxJ
          Josh CoxJ
          Josh Cox
          that flowchart is good stuff, I'll definitely refer to it in the future.
          swapping to a 4.7uF cap seems to maybe have fixed the issue, I've only observed for a couple of hours so maybe it just likes the heat of the day here
          • Josh CoxJ
            Josh CoxJ
            Josh Cox
            I am definitely getting freezes still. Maybe it's just bad hardware, I'm going to try swapping components.
