  3. Trying to upgrade my Ethernet GW -> 1.4
17 Posts 4 Posters 6.1k Views 1 Watching
  • HoffanH Offline
    HoffanH Offline
    Hoffan
    Hi
    I have tryied to upgrade my Ethernet GW to 1.4 but as i change the code
    for my Ethernet ENC28J60 shield i get this when i compiling the code
    In file included from /Users/nh/Documents/Arduino/libraries/UIPEthernet/Dhcp.h:7,
    from /Users/nh/Documents/Arduino/libraries/UIPEthernet/UIPEthernet.h:25,
    from EthernetGateway.ino:53:
    /Users/nh/Documents/Arduino/libraries/UIPEthernet/UIPUdp.h:26:29: error: utility/mempool.h: No such file or directory
    /Users/nh/Documents/Arduino/libraries/UIPEthernet/UIPUdp.h:28:28: error: utility/uip.h: No such file or directory
    In file included from EthernetGateway.ino:53:
    /Users/nh/Documents/Arduino/libraries/UIPEthernet/UIPEthernet.h:27:37: error: utility/Enc28J60Network.h: No such file or directory
    /Users/nh/Documents/Arduino/libraries/UIPEthernet/UIPEthernet.h:34:31: error: utility/uip_timer.h: No such file or directory
    /Users/nh/Documents/Arduino/libraries/UIPEthernet/UIPUdp.h:46: error: 'memaddress' does not name a type
    /Users/nh/Documents/Arduino/libraries/UIPEthernet/UIPUdp.h:47: error: 'memhandle' does not name a type
    /Users/nh/Documents/Arduino/libraries/UIPEthernet/UIPUdp.h:48: error: 'memhandle' does not name a type
    /Users/nh/Documents/Arduino/libraries/UIPEthernet/UIPUdp.h:49: error: 'memhandle' does not name a type
    In file included from /Users/nh/Documents/Arduino/libraries/UIPEthernet/UIPEthernet.h:28,
    /Users/nh/Documents/Arduino/libraries/UIPEthernet/UIPClient.h:48: error: 'memhandle' does not name a type
    /Users/nh/Documents/Arduino/libraries/UIPEthernet/UIPClient.h:54: error: 'memhandle' does not name a type
    /Users/nh/Documents/Arduino/libraries/UIPEthernet/UIPClient.h:55: error: 'memhandle' does not name a type
    /Users/nh/Documents/Arduino/libraries/UIPEthernet/UIPClient.h:56: error: 'memaddress' does not name a type
    /Users/nh/Documents/Arduino/libraries/UIPEthernet/UIPClient.h:85: error: 'UIP_CONNS' was not declared in this scope
    /Users/nh/Documents/Arduino/libraries/UIPEthernet/UIPClient.h:92: error: ISO C++ forbids declaration of 'memhandle' with no type
    /Users/nhDocuments/Arduino/libraries/UIPEthernet/UIPClient.h:92: error: expected ';' before '*' token
    /Users/nh/Documents/Arduino/libraries/UIPEthernet/UIPClient.h:93: error: 'memhandle' has not been declared
    /Users/nh/Documents/Arduino/libraries/UIPEthernet/UIPClient.h:94: error: 'memhandle' has not been declared
    /Users/nh/Documents/Arduino/libraries/UIPEthernet/UIPEthernet.h:88: error: field 'periodic_timer' has incomplete type
    /Users/nh/Documents/Arduino/libraries/UIPEthernet/UIPEthernet.h:90: error: 'memhandle' does not name a type
    /Users/nh/Documents/Arduino/libraries/UIPEthernet/UIPEthernet.h:91: error: 'memhandle' does not name a type
    /Users/nh/Documents/Arduino/libraries/UIPEthernet/UIPEthernet.h:95: error: 'Enc28J60Network' does not name a type
    What am i missing, i have download the new arduino file
    hekH 1 Reply Last reply
    • HoffanH Hoffan
      Hi
      hekH Offline
      hekH Offline
      @Hoffan
      Which version of the Arduino IDE are you using?
      HoffanH 1 Reply Last reply
        @Hoffan
        HoffanH Offline
        HoffanH Offline
        Hoffan
        @hek
        Hope i understand right 1.0.5 on MAC
        • hekH Offline
          hekH Offline
          Could you give a try with 1.5.5(+)?
            HoffanH Offline
            HoffanH Offline
            Hoffan
            @hek
            Yes i will, BRB
            • HoffanH Hoffan
              @hek
              Yes i will, BRB
              HoffanH Offline
              HoffanH Offline
              Hoffan
              I only find 1.5.7 beta No 1.5.5
              the only non beta i find is 1.0.5
              • hekH Offline
                hekH Offline
                Go for 1.5.7.
                • K Offline
                  K Offline
                  klim
                  Today i compiled it serveral times with IDE 1.0.5 under windows without a problem. And after some time i got exact the same error message as you. So i decited to use 1.5.7 beta to compile, there are some other ugly compiling messages, but at the end it was successfull for me.
                  • K klim
                    HoffanH Offline
                    HoffanH Offline
                    Hoffan
                    @klim
                    Yes i see the same message here, But i think i get it to work rikght now..
                    • HoffanH Hoffan
                      @klim
                      HoffanH Offline
                      HoffanH Offline
                      Hoffan
                      I get it to work to program my Gateway, But
                      nothing happens when i put the start button for inclusion new sensors
                      And i have pure the new files into my Vera and i have Ui5 on that one
                      The GW seriel log looks like this all the time
                      0;0;3;0;9;send: 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,st=fail:0
                      0;0;3;0;9;read: 255-255-255 s=255,c=3,t=7,pt=0,l=0:
                      0;0;3;0;9;send: 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,st=ok:0
                        Go for 1.5.7.
                        HoffanH Offline
                        HoffanH Offline
                        Hoffan
                        @hek
                        Do you have any solutions for my problem??
                        I have seen that i lost ping when i try to ping the gateway
                        it work to ping when i restart the GW but if i test for ex 10 minutes later it don't work
                        • HoffanH Offline
                          HoffanH Offline
                          Hoffan
                          Should it looks like this. Why is Lib version empty..
                          • hekH Offline
                            hekH Offline
                            Two threads with the same problem:
                            http://forum.mysensors.org/topic/371/errors-compiling-ethernetgateway-with-uipeternet-h
                            Lib is empty because your Vera plugin is unable to communicate with the ethernet gateway.
                            • M Offline
                              M Offline
                              mitekg
                              Hi, got some problems wth ethGW (wiznet + uno)
                              latest version from git is not for me (no blinks and eth communication with vera)
                              but old dev version http://pastebin.com/6YFrs6HT works fine. could someone help me plz.
                              thx
                              • M Offline
                                M Offline
                                mitekg
                                add: blinks and inclusion starts and stops works fine (with old version), but no lib version and new devices in vera after that
                                • HoffanH Offline
                                  HoffanH Offline
                                  Hoffan
                                  What ethernet module do you have?
                                  • M Offline
                                    M Offline
                                    mitekg
                                    @Hoffan - wiznet
