  3. Changing baudrate to 57600 in VeraUI7 [SOLEVD]
5 Posts 2 Posters 1.9k Views 2 Watching
  • L Offline
    L Offline
    leeoz
    wrote on last edited by leeoz
    Re: [SOLVED] 8MHz Gateway : node not receiving any data
    Hey,
    I'm trying to change the baudrate in vera to 57600.
    In the arduino lib files (MyConfig.h) I changed it to 57600, and uploaded the Serial Gateway to the Nano I have. Iv'e connected it to VeraEdge and went to change the baudrate on the Apps->Develop apps->Serial Port configuration
    After saving it say's on the device to Change to baudrate to 115200, if I do so it doesn't communicate with the gateway (well it make sense, since it works now on 57600)
    Any ideas?
    tnx
    • H Offline
      H Offline
      You have to edit the .lua plugin file to get rid of the warning.
      • L Offline
        L Offline
        leeoz
        OK.
        tnx. found it... now i'll try...
        • L Offline
          L Offline
          leeoz
          Do I need the remove the mySensors plugin device from devices or just update the lua file?
          • L Offline
            L Offline
            leeoz
            Work fine, I have changed the lib myconfig.h file and the lua file.
            Removed MySensors plugin device from devices, updated the lua file on Vera.
            Reloaded engine, Plugged the arduino serialGateway back again.
            and flowed insturcations of Adding SerialGateWay again.
            Work fine, however I still have issues with Gateway to recognize devices and reading and sending info to devices
            I guess its a matter of power to the NRF24 radio, altough I use capasitor in between the 3.3v and gnd from the Nano, I think it's not enough.
            12.1k
