  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 466.6k Views 30 Watching
  • AnticimexA Anticimex
    @alexsh1 no, not really. If you have a atsha204a the only reason to not use it would be performance. Software signing executes slightly faster due to the single write protocol of the atsha.
    alexsh1A
    alexsh1A
    alexsh1
    @Anticimex Thanks very much for your help - I must admit it was a bit of a challenge to jump straight away from a stable 1.5.4 to 2.0 beta
    AnticimexA 1 Reply Last reply
    • alexsh1A alexsh1
      AnticimexA
      AnticimexA
      Anticimex
      @alexsh1 yes there have been a lot of changes but hopefully they are perceived as improvements. Feedback on signing usability is always welcome :)
      alexsh1A 1 Reply Last reply
        alexsh1A
        alexsh1A
        alexsh1
        @Anticimex BTW, is signing compatible between 1.5.4 and 2.0b?
        • alexsh1A alexsh1
          AnticimexA
          AnticimexA
          Anticimex
          @alexsh1 no, it is not
            alexsh1A
            alexsh1A
            alexsh1
            #263
            @Anticimex Right, this is why I am not able to sign 1.5.4 nodes with 2.0b GW.
            In fact when I inserted #define MY_SIGNING_REQUEST_SIGNATURES into the GW code, some nodes stopped working and I think it has to be with signing as GW is throwing a lot of messages that signing failed.
            Bottom line is that I need to upgrade pretty much all sensors :-(
            • alexsh1A alexsh1
              AnticimexA
              AnticimexA
              Anticimex
              @alexsh1 yes, Unfortunately. But it is a huge release upcoming. And a major version step, hence the incompatibilities. Hopefully, the changes made will make it easier to do future maintenance.
              • C
                C
                cingolanifede
                Hi. Is there any difference in using RFM69? Signing is supported using that radio? Thanks
                • C cingolanifede
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @cingolanifede signing has nothing to to with which radio you choose so yes. It supports any transport, but to my knowledge it has only been actually tested with nrf24 and rfm69.
                  • alexsh1A
                    alexsh1A
                    alexsh1
                    @Anticimex I must admit that signing is working really-really nicely on my custom made nodes (Soft sign and ATSHA204A)
                    Apart from a small issue with the sensebender, which I believe is not a signing issue, it is working like a charm. All credit to you! Thank you
                    Starting sensor (RNNNAS, 2.0.0-beta)
                    Radio init successful.
                    HTU21D Sensor1.1 - Online!
                    isMetric: 1
                    TempDiff :1098.00
                    HumDiff  :136.75
                    T: 998.00
                    H: 36.75
                    send: 5-5-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:998.0
                    send: 5-5-0-0 s=1,c=1,t=1,pt=7,l=5,sg=0,st=ok:36.7
                    send: 5-5-0-0 s=2,c=1,t=38,pt=7,l=5,sg=0,st=ok:3.29
                    send: 5-5-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=ok:106
                    Signing required
                    send: 5-5-0-0 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok:
                    Waiting for GW to send signing preferences...
                    Skipping security for command 3 type 15
                    read: 0-0-5 s=255,c=3,t=15,pt=0,l=2,sg=0:
                    Mark node 0 as one that do not require signed messages
                    Mark node 0 as one that do not require whitelisting
                    send: 5-5-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=ok:2.0.0-beta
                    send: 5-5-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                    Skipping security for command 3 type 16
                    read: 0-0-5 s=255,c=3,t=16,pt=0,l=0,sg=0:
                    Signing backend: ATSHA204Soft
                    SHA256: 2C4A871ACCAE26760F41E547DD39B7B816FE22EEBCD8DFA2FE00000000000000
                    Transmittng nonce
                    send: 5-5-0-0 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:2C4A871ACCAE26760F41E547DD39B7B816FE22EEBCD8DFA2FE
                    Signature in message: 01C31110DAE29D5DCD3771F68B6F29B5CCCF43A3D5397CC8
                    Message to process: 00050E0306FF4D
                    Current nonce: 2C4A871ACCAE26760F41E547DD39B7B816FE22EEBCD8DFA2FEAAAAAAAAAAAAAA
                    HMAC: 0CC31110DAE29D5DCD3771F68B6F29B5CCCF43A3D5397CC89A82A89D87E931B8
                    Signature OK
                    read: 0-0-5 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                    send: 5-5-0-0 s=255,c=3,t=11,pt=0,l=24,sg=0,st=ok:Temp/Hum Sensor - HTU21D
                    send: 5-5-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
                    send: 5-5-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                    send: 5-5-0-0 s=1,c=0,t=7,pt=0,l=0,sg=0,st=ok:
                    send: 5-5-0-0 s=2,c=0,t=13,pt=0,l=0,sg=0,st=ok:
                    Init complete, id=5, parent=0, distance=1
                    TempDiff :971.94
                    HumDiff  :0.02
                    T: 26.06
                    H: 36.72
                    send: 5-5-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:26.1
                    • alexsh1A alexsh1
                      isMetric: 1
                      TempDiff :1098.00
                      HumDiff  :136.75
                      T: 998.00
                      H: 36.75
                      Signing required
                      Transmittng nonce
                      Signature OK
                      TempDiff :971.94
                      HumDiff  :0.02
                      T: 26.06
                      H: 36.72
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @alexsh1 I'm really glad to hear that. Thank you! Glad that signing is being used and is perceived as something not to complicated to bother with. It sets us apart from many other projects dealing with the same thing :)
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @Anticimex I did not say it was not complicated :)
                        Just kidding - speaking just for myself, it did require some time investment to understand the concept and then upgrading my gateway and my nodes (I am still in the process of rolling signing across the rest of my nodes) to MySensors 2.0b. I probably spent more time upgrading MySensors lib and breaking some hardware in the meantime (the SMA connector on the nrf24l01+ PA+LNA) than the actual signing.
                        • alexsh1A alexsh1
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @alexsh1 yeah, well if there is room for improvement in the documentation then feel free to help put with suggestions if there is anything unclear about that :) I use doxygen to document signing features, and a link is available on the GitHub "front-page" (the readme.md)
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @Anticimex I think a noob's section would be good. Having said that, the point is that signing is not something beginners should touch. What do you think?
                            How about a section on the web-site? Somewhere here - https://www.mysensors.org/build/
                            • alexsh1A alexsh1
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @alexsh1 hm, yeah, perhaps something for @hek to consider. At least a link to the signing section of the doxygen docs could be placed there. I have tried to make the documentation as step-by-step friendly as I can. That said, as I also did the actual implementation, I may well be blind for certain aspects I take for granted that a "novice" does not.
                                The next release of the main site will be much more flexible and integrated with openhardware-added projects. The idea is to allow community members to maintain their projects and/or "articles" themselves. The how-to for signing is a good example of an article.
                                • F
                                  F
                                  Fabien
                                  This tutorial is up to date for 2.0 release ?
                                  • F Fabien
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @Fabien Yes, top post is now updated for 2.0.0. Documentation is in doxygen.
                                    • F
                                      F
                                      Fabien
                                      Thank you @Anticimex I will update my network soon and had RFM69 Encryption too.
                                      • NiklasON
                                        NiklasON
                                        NiklasO
                                        wrote on last edited by NiklasO
                                        #277
                                        Trying this:
                                        https://www.mysensors.org/build/raspberry
                                        How do I enable signing and give the gateway the serial, hmac and aes-key when running on Linux? (rPi).
                                        Edit: Pin 7 as random number generator maybe need some change?
                                        • NiklasON NiklasO
                                          Trying this:
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @NiklasO @marceloaqno is working on this.
