  3. {DEV} Multi-Sensor Node goes into boot loop
21 Posts 8 Posters 7.1k Views 8 Watching
  • rollercontainerR
    rollercontainerR
    rollercontainer
    wrote on last edited by rollercontainer
    Hm, MQTTGateway only comes up on PC, not on USB power supply. And it is not presenting itself, but sendig local DHT values.
    • rollercontainerR
      rollercontainerR
      rollercontainer
      MY_DEBUG disabled, MQTT Gateway comes up on regular power. Bug?
      • rollercontainerR
        rollercontainerR
        rollercontainer
        Well, 2.0 seems buggy. Now my Node is trying to find its parent. Funny, because I told him which to use:
        #define MY_NODE_ID 10
        #define MY_PARENT_NODE_ID 0
        TSM:INIT
        TSM:RADIO:OK
        TSP:ASSIGNID:OK (ID=10)
        TSM:FPAR
        TSP:MSG:SEND 10-10-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        !TSM:FPAR:FAIL
        !TSM:FAILURE
        TSM:PDT
        tekkaT 1 Reply Last reply
        • rollercontainerR rollercontainer
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          !TSM:FPAR:FAIL
          !TSM:FAILURE
          TSM:PDT
          tekkaT
          tekkaT
          tekka
          @rollercontainer We need to look into that - that's not the anticipated behaviour. Please submit an issue on git and we will investigate further. Thanks for the feedback.
          • D
            drock1985
            hi @rollercontainer
            Thanks for looking into this with me. I had some more luck believe it or not after upgrading to 2.0.0 on my Gateway. Using the same sketch as I posted for my node, and updating my ESP8266 Gateway to the 2.0 sketch solved the reboot issue. Only problem now is the DallasTemperature sensor does not seem to be registering with the gateway.
            Of curious notice, when I looked through the example sketches in the new MySensors 2.0 Library, i did not see an example sketch for the DallasTemperature sensors this time around.
            My Projects
            2 Door Chime Sensor
            Washing Machine Monitor
            YveauxY AWIA 2 Replies Last reply
            • D drock1985
              hi @rollercontainer
              For maintenance reasons, examples depending on external libraries have been removed in 2.0.0, to be placed in a separate repository (work in progress).
              • D
                drock1985
                Getting there.... I had to re-add the OneWire, Wire and DallasTemperature sensor and make a few modifications to the sketch, but I have the beginnings now and it is showing up properly in Home-Assistant and responding nicely. I'm off to make supper, but the only thing I can see needing to modify big time is adding "send temp on change only" and getting the temp to show to a decimal place.
                Here is the sketch for now:
                 * Version 1.0 - Henrik Ekblad
                // Enable debug prints
                #define MY_NODE_ID 21
                #include <OneWire.h>
                #include <BH1750.h>
                #define ONE_WIRE_BUS 4 // Pin where dallase sensor is connected
                int numSensors=0;
                boolean receivedConfig = false;
                boolean metric = true;
                #define CHILD_ID_MOTION 1   // Id of the sensor child
                #define CHILD_ID_TEMP 2   // ID of Temperature Sensor
                #define CHILD_ID_LUX 3  // ID of Lux Sensor
                BH1750 lightSensor;
                // Initialize motion message
                MyMessage msgMotion(CHILD_ID_MOTION, V_TRIPPED);
                MyMessage msgLux(CHILD_ID_LUX, V_LIGHT_LEVEL);
                uint16_t lastlux;
                  lightSensor.begin();
                  sensors.begin();
                void presentation()  {
                  sendSketchInfo("yes", "1.0");
                  present(CHILD_ID_MOTION, S_MOTION);
                  present(CHILD_ID_LUX, S_LIGHT_LEVEL);
                  // Read digital motion value
                  Serial.println(tripped);
                  send(msgMotion.set(tripped?"1":"0"));  // Send tripped value to gw
                  Serial.println(lux);
                  if (lux != lastlux) {
                      send(msgLux.set(lux));
                      lastlux = lux;
                    int temperature = (((sensors.getTempCByIndex(0)) * 10.)) / 10.;
                      send(msgTemp.set(temperature));
                My Projects
                2 Door Chime Sensor
                • D drock1985
                  hi @rollercontainer
                  AWIA
                  AWIA
                  AWI
                  @drock1985 I had similar problems with the failure messages. After an upgrade of my repeater it functions again. Development seems to have some issues with backward compatibility. Hard to reproduce the errors..
                  D 1 Reply Last reply
                  • AWIA AWI
                    drock1985
                    @AWI
                    Ah, never thought about that. I do have a node/repeater still on 1.5 running. Thanks; now I know my next project.
                    My Projects
                    2 Door Chime Sensor
                    • E
                      E
                      emc2
                      wrote on last edited by emc2
                      @rollercontainer said:
                      TSP:CHKUPL:FAIL (hops=255)
                      !TSM:UPL:FAIL
                      Did you end up finding what was the problem?
                      I have the same errors on new nodes compiled with the stable release. It was working fine on the dev branch before, and my old sensors still works, but not the new ones...
                      Edit:
                      I had to revert to https://github.com/mysensors/MySensors/tree/244f79771acb60588c6b4fd6dd0fa4b5daf4cb64
                      June 26th commit break everything for me. Unfortunately a lot of changes were made this day...
                      mitchellM 1 Reply Last reply
                      • rollercontainerR
                        rollercontainerR
                        rollercontainer
                        read above again:
                        Gateway 2.0.0beta with Node 2.0.0 = UPL:FAIL (which means UPLink)
                        Gateway 2.0.0 with Node 2.0.0 = FPAR:FAIL (which means FindPARent)
                        my error is reported to github, maybe you should do this too with yours?
                        https://github.com/mysensors/MySensors/issues
                        • E
                          E
                          emc2
                          Oh, so just switching from beta to 2.0 master "fixed" UPL:FAIL by switching it to a FPAR:FAIL?
                          I thought you did some fixes and then ended up with another error, my bad. Github it is I guess...
                          • rollercontainerR
                            rollercontainerR
                            rollercontainer
                            I am not a coder, just a user. So I am not able to fix errors here.
                            • E emc2
                              !TSM:UPL:FAIL
                              Edit:
                              mitchellM
                              mitchellM
                              mitchell
                              wrote on last edited by mitchell
                              !TSM:UPL:FAIL
                              Edit:
                              Thank you, had the same problem, replaced it with the files from the 26th and got it working.
                              • E
                                E
                                emc2
                                @mitchell Glad it was useful.
                                Do you also have a Raspberry Pi Gateway with the radio module directly on the GPIO? It seems the problem come from here, issue can now be tracked on https://github.com/mysensors/Raspberry/issues/31
                                Also if needed you can replace core/MyHwESP8266.h and core/MyMainESP8266.cpp with the release version so you can use an ESP8266 device too.
                                • E emc2
                                  mitchellM
                                  mitchellM
                                  mitchell
                                  @emc2 Indeed on a Raspberry with direct connection. Thank you for the link, I will follow the progress.
                                  • joachimJ
                                    joachimJ
                                    joachim
                                    I found out that adding a sleep(10) between 2 consecutive 'send' does help a lot
                                    12.5k
