  3. {DEV} Multi-Sensor Node goes into boot loop
21 Posts 8 Posters 7.1k Views 8 Watching
  • D
    drock1985
    Getting there.... I had to re-add the OneWire, Wire and DallasTemperature sensor and make a few modifications to the sketch, but I have the beginnings now and it is showing up properly in Home-Assistant and responding nicely. I'm off to make supper, but the only thing I can see needing to modify big time is adding "send temp on change only" and getting the temp to show to a decimal place.
    Here is the sketch for now:
     * Version 1.0 - Henrik Ekblad
    // Enable debug prints
    #define MY_NODE_ID 21
    #include <OneWire.h>
    #include <BH1750.h>
    #define ONE_WIRE_BUS 4 // Pin where dallase sensor is connected
    int numSensors=0;
    boolean receivedConfig = false;
    boolean metric = true;
    #define CHILD_ID_MOTION 1   // Id of the sensor child
    #define CHILD_ID_TEMP 2   // ID of Temperature Sensor
    #define CHILD_ID_LUX 3  // ID of Lux Sensor
    BH1750 lightSensor;
    // Initialize motion message
    MyMessage msgMotion(CHILD_ID_MOTION, V_TRIPPED);
    MyMessage msgLux(CHILD_ID_LUX, V_LIGHT_LEVEL);
    uint16_t lastlux;
      lightSensor.begin();
      sensors.begin();
    void presentation()  {
      sendSketchInfo("yes", "1.0");
      present(CHILD_ID_MOTION, S_MOTION);
      present(CHILD_ID_LUX, S_LIGHT_LEVEL);
      // Read digital motion value
      Serial.println(tripped);
      send(msgMotion.set(tripped?"1":"0"));  // Send tripped value to gw
      Serial.println(lux);
      if (lux != lastlux) {
          send(msgLux.set(lux));
          lastlux = lux;
        int temperature = (((sensors.getTempCByIndex(0)) * 10.)) / 10.;
          send(msgTemp.set(temperature));
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
    • D drock1985
      hi @rollercontainer
      Thanks for looking into this with me. I had some more luck believe it or not after upgrading to 2.0.0 on my Gateway. Using the same sketch as I posted for my node, and updating my ESP8266 Gateway to the 2.0 sketch solved the reboot issue. Only problem now is the DallasTemperature sensor does not seem to be registering with the gateway.
      Of curious notice, when I looked through the example sketches in the new MySensors 2.0 Library, i did not see an example sketch for the DallasTemperature sensors this time around.
      AWIA
      AWIA
      AWI
      @drock1985 I had similar problems with the failure messages. After an upgrade of my repeater it functions again. Development seems to have some issues with backward compatibility. Hard to reproduce the errors..
      D 1 Reply Last reply
      • AWIA AWI
        drock1985
        @AWI
        Ah, never thought about that. I do have a node/repeater still on 1.5 running. Thanks; now I know my next project.
        My Projects
        2 Door Chime Sensor
        • E
          E
          emc2
          wrote on last edited by emc2
          @rollercontainer said:
          TSP:CHKUPL:FAIL (hops=255)
          !TSM:UPL:FAIL
          Did you end up finding what was the problem?
          I have the same errors on new nodes compiled with the stable release. It was working fine on the dev branch before, and my old sensors still works, but not the new ones...
          Edit:
          I had to revert to https://github.com/mysensors/MySensors/tree/244f79771acb60588c6b4fd6dd0fa4b5daf4cb64
          June 26th commit break everything for me. Unfortunately a lot of changes were made this day...
          mitchellM 1 Reply Last reply
          • rollercontainerR
            rollercontainerR
            rollercontainer
            read above again:
            Gateway 2.0.0beta with Node 2.0.0 = UPL:FAIL (which means UPLink)
            Gateway 2.0.0 with Node 2.0.0 = FPAR:FAIL (which means FindPARent)
            my error is reported to github, maybe you should do this too with yours?
            https://github.com/mysensors/MySensors/issues
            • E
              E
              emc2
              Oh, so just switching from beta to 2.0 master "fixed" UPL:FAIL by switching it to a FPAR:FAIL?
              I thought you did some fixes and then ended up with another error, my bad. Github it is I guess...
              • rollercontainerR
                rollercontainerR
                rollercontainer
                I am not a coder, just a user. So I am not able to fix errors here.
                • E emc2
                  !TSM:UPL:FAIL
                  Edit:
                  mitchellM
                  mitchellM
                  mitchell
                  wrote on last edited by mitchell
                  !TSM:UPL:FAIL
                  Edit:
                  Thank you, had the same problem, replaced it with the files from the 26th and got it working.
                  • E
                    E
                    emc2
                    @mitchell Glad it was useful.
                    Do you also have a Raspberry Pi Gateway with the radio module directly on the GPIO? It seems the problem come from here, issue can now be tracked on https://github.com/mysensors/Raspberry/issues/31
                    Also if needed you can replace core/MyHwESP8266.h and core/MyMainESP8266.cpp with the release version so you can use an ESP8266 device too.
                    • E emc2
                      mitchellM
                      mitchellM
                      mitchell
                      @emc2 Indeed on a Raspberry with direct connection. Thank you for the link, I will follow the progress.
                      • joachimJ
                        joachimJ
                        joachim
                        I found out that adding a sleep(10) between 2 consecutive 'send' does help a lot
                        12.5k
