  2. Announcements
  3. Converting a sketch from 1.5.x to 2.0.x
52 Posts 21 Posters 37.9k Views 26 Watching
  • rollercontainerR
    rollercontainerR
    rollercontainer
    wrote on last edited by rollercontainer
    Maybe related to this problem?
    https://github.com/mysensors/MySensors/issues/449
    My gateway does the same. No presentation, but sending data.
    chrlyraC 1 Reply Last reply
    • hugowsH
      hugowsH
      hugows
      wrote on last edited by hugows
      The API looks very clean and simple, I look forward to use it more.
      Does Arduino/MySensors uses C++ features (namespaces?) to prevent name collision? In typical C projects I've seen the functions all beginning with some prefix (mysensors_).
      • rollercontainerR rollercontainer
        chrlyraC
        chrlyraC
        chrlyra
        @rollercontainer Where should the "if (presentation).." be? At the setup()?
        • chrlyraC chrlyra
          @chrlyra there is no such thing as if(presentation)...
          The presentation function implementation can be anywhere in your sketch.
          • YveauxY Yveaux
            chrlyraC
            chrlyraC
            chrlyra
            @Yveaux rollercontainer pointed to this issue: https://github.com/mysensors/MySensors/issues/449, where hek asked him to add two lines of code, the first one being "if (presentation)".
            • chrlyraC chrlyra
              @chrlyra That's what happens if you deviate from the topic... Anyway, thanks for the hint!
              • R
                R
                Rolo6442u
                Great work ! This version looks a lot cleaner and the support for the RFM69 is more integrated. Thanks for that. One thing I'm missing and that's the specification of the encryption key for the RFM69. This was done in version 1.5.x by a user defined 16 bytes string. Now i see only a #define MY_RFM69_ENABLE_ENCRYPTION.
                How and where is the key specified ? How does this make my setup unique ?
                AnticimexA 1 Reply Last reply
                  @Rolo6442u
                  If I remember well, it is handled by SecurityPersonalizer.ino It is sketch for signing options, and i think you can set/generate your rf aes key there. It store it in eeprom. Then you upload the new sketch with encryption define enabled. For me it's ok, as i use signing which needs to use the personalizer.
                  I think this works like this, not sure as i have not enabled encryption yet. Am I right @Anticimex ?
                  • R Rolo6442u
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @Rolo6442u
                    @scalz is correct. Details are in the doxygen documentation for usage. Link is on the GitHub readme. Look under the signing module there.
                    R 1 Reply Last reply
                    • AnticimexA Anticimex
                      @Rolo6442u
                      R
                      R
                      Rolo6442u
                      @Anticimex
                      @scalz
                      Thanks, I got it working. By setting it to "soft" this sketch writes all key's to eeprom and will not look for a hardware siging module. The RFM69 uses the EAS key for encryption. I defined my own key again in the sketch.
                      Nice solution !
                      • R Rolo6442u
                        @Anticimex
                        @scalz
                        Nice solution !
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @Rolo6442u precisely. Glad to hear that the docs are helping :) and thanks!
                        • pascalgauthierP
                          pascalgauthierP
                          pascalgauthier
                          How can i call the process() inside a while in the loop() ?
                          nielsokkerN 1 Reply Last reply
                          • pascalgauthierP pascalgauthier
                            nielsokkerN
                            nielsokkerN
                            nielsokker
                            @pascalgauthier
                            I think the function "wait()" might be useful. It is like a sleep, but now it calls "process()"
                            pascalgauthierP 1 Reply Last reply
                            • nielsokkerN nielsokker
                              @pascalgauthier
                              pascalgauthierP
                              pascalgauthierP
                              pascalgauthier
                              @nielsokker said:
                              @pascalgauthier
                              I was thinking of using it with wait(0) but I was wondering if there was any way to call the process directly.
                                @nielsokker said:
                                @pascalgauthier
                                nielsokkerN
                                nielsokkerN
                                nielsokker
                                @pascalgauthier
                                I'm not sure. I think the developers will know.
                                  @pascalgauthier why do you need to call process ? It's already done internally by the lib. Or is it for inside some longtime loop? you still can use process but now it's _process()
                                  Wait is not the same as sleep.
                                  Wait : wait for a time and call _process
                                  sleep: does not call _process. it sleeps. for a time if set
                                  • scalzS scalz
                                    pascalgauthierP
                                    pascalgauthierP
                                    pascalgauthier
                                    @scalz
                                    Because i have while() that increment motion detected in a 30sec timeframe. And i would like to be sure that i'm not missing any cmd from the gateway. Do i need to define any additional library to use the _process() ?
                                    AWIA 1 Reply Last reply
                                      @scalz
                                      AWIA
                                      AWIA
                                      AWI
                                      @pascalgauthier I would recommend making your while loop non-blocking i.s.o. hacking into a MySensors function.
                                        @pascalgauthier
                                        yes it's better non blocking. for non blocking it's better to use "if" like. for beginning, I advise you to look at "blink without delay" concept. then learning a bit how a state machine works etc...could be useful to you. but it's a bit more advanced, or not..
                                        • scalzS scalz
                                          @pascalgauthier
                                          pascalgauthierP
                                          pascalgauthierP
                                          pascalgauthier
                                          @scalz @AWI
                                          Thanks for your help ! :)
