  2. Announcements
  3. Converting a sketch from 1.5.x to 2.0.x
52 Posts 21 Posters 37.9k Views 26 Watching
  • YveauxY Yveaux
    @chrlyra there is no such thing as if(presentation)...
    The presentation function implementation can be anywhere in your sketch.
    chrlyraC
    chrlyraC
    chrlyra
    @Yveaux rollercontainer pointed to this issue: https://github.com/mysensors/MySensors/issues/449, where hek asked him to add two lines of code, the first one being "if (presentation)".
    • chrlyraC chrlyra
      @chrlyra That's what happens if you deviate from the topic... Anyway, thanks for the hint!
      • R
        R
        Rolo6442u
        Great work ! This version looks a lot cleaner and the support for the RFM69 is more integrated. Thanks for that. One thing I'm missing and that's the specification of the encryption key for the RFM69. This was done in version 1.5.x by a user defined 16 bytes string. Now i see only a #define MY_RFM69_ENABLE_ENCRYPTION.
        How and where is the key specified ? How does this make my setup unique ?
        AnticimexA 1 Reply Last reply
          @Rolo6442u
          If I remember well, it is handled by SecurityPersonalizer.ino It is sketch for signing options, and i think you can set/generate your rf aes key there. It store it in eeprom. Then you upload the new sketch with encryption define enabled. For me it's ok, as i use signing which needs to use the personalizer.
          I think this works like this, not sure as i have not enabled encryption yet. Am I right @Anticimex ?
          • R Rolo6442u
            AnticimexA
            AnticimexA
            Anticimex
            @Rolo6442u
            @scalz is correct. Details are in the doxygen documentation for usage. Link is on the GitHub readme. Look under the signing module there.
            R 1 Reply Last reply
            • AnticimexA Anticimex
              @Rolo6442u
              R
              R
              Rolo6442u
              @Anticimex
              @scalz
              Thanks, I got it working. By setting it to "soft" this sketch writes all key's to eeprom and will not look for a hardware siging module. The RFM69 uses the EAS key for encryption. I defined my own key again in the sketch.
              Nice solution !
              • R Rolo6442u
                @Anticimex
                @scalz
                Nice solution !
                AnticimexA
                AnticimexA
                Anticimex
                @Rolo6442u precisely. Glad to hear that the docs are helping :) and thanks!
                • pascalgauthierP
                  pascalgauthierP
                  pascalgauthier
                  How can i call the process() inside a while in the loop() ?
                  nielsokkerN 1 Reply Last reply
                  • pascalgauthierP pascalgauthier
                    nielsokkerN
                    nielsokkerN
                    nielsokker
                    @pascalgauthier
                    I think the function "wait()" might be useful. It is like a sleep, but now it calls "process()"
                    pascalgauthierP 1 Reply Last reply
                    • nielsokkerN nielsokker
                      @pascalgauthier
                      pascalgauthierP
                      pascalgauthierP
                      pascalgauthier
                      @nielsokker said:
                      @pascalgauthier
                      I was thinking of using it with wait(0) but I was wondering if there was any way to call the process directly.
                        @nielsokker said:
                        @pascalgauthier
                        nielsokkerN
                        nielsokkerN
                        nielsokker
                        @pascalgauthier
                        I'm not sure. I think the developers will know.
                          @pascalgauthier why do you need to call process ? It's already done internally by the lib. Or is it for inside some longtime loop? you still can use process but now it's _process()
                          Wait is not the same as sleep.
                          Wait : wait for a time and call _process
                          sleep: does not call _process. it sleeps. for a time if set
                          • scalzS scalz
                            pascalgauthierP
                            pascalgauthierP
                            pascalgauthier
                            @scalz
                            Because i have while() that increment motion detected in a 30sec timeframe. And i would like to be sure that i'm not missing any cmd from the gateway. Do i need to define any additional library to use the _process() ?
                            AWIA 1 Reply Last reply
                              @scalz
                              AWIA
                              AWIA
                              AWI
                              @pascalgauthier I would recommend making your while loop non-blocking i.s.o. hacking into a MySensors function.
                                @pascalgauthier
                                yes it's better non blocking. for non blocking it's better to use "if" like. for beginning, I advise you to look at "blink without delay" concept. then learning a bit how a state machine works etc...could be useful to you. but it's a bit more advanced, or not..
                                • scalzS scalz
                                  @pascalgauthier
                                  pascalgauthierP
                                  pascalgauthierP
                                  pascalgauthier
                                  @scalz @AWI
                                  Thanks for your help ! :)
                                    moskovskiy82
                                    Little bit confused. reading through the release notes...
                                    Deprecated variables: V_DIMMER (use V_PERCENTAGE), V_HEATER (use V_HVAC_FLOW_STATE), V_LIGHT (use V_STATUS)
                                    Now back to the API page for 2.0...
                                    S_DIMMER	4	Dimmable device of some kind	V_STATUS (on/off), V_DIMMER (dimmer level 0-100), V_WATT
                                    WHICH ONE TRUST?!
                                      moskovskiy82
                                      And if my loop statement consists only of
                                      { gw.process(); }
                                      Rewrite like
                                      void loop() { }
                                      or exclude loop completely?
                                      • M moskovskiy82
                                        { gw.process(); }
                                        Rewrite like
                                        void loop() { }
                                        @moskovskiy82 said:
                                        Rewrite like
                                        void loop() { }
                                        That's correct
                                        • M moskovskiy82
                                          WHICH ONE TRUST?!
                                          @moskovskiy82 said:
                                          WHICH ONE TRUST?!
                                          The release notes (as I added this statement ;-) )
