  3. Simple Serial Gateway and sensor does not work...
14 Posts 5 Posters 7.0k Views 3 Watching
  • LOSTL Offline
    LOSTL Offline
    LOST
    wrote on last edited by LOST
    I've downloaded the latest release of MySensors (2.0.0) and uploaded the GatewaySerial sketch (unmodified) to a NANO [1] with a NRF24L01+ [2] with the extra antenna like in the tutorial video [3]
    I've also uploaded a sketch to a Mini Pro 5v with a DHT22
     * TEST SKETCH
    // Enable debug prints
    // SET NODE ID
    #define MY_NODE_ID 10
    #define CHILD_ID_TEMP 11
    #define CHILD_ID_HUM 12
    unsigned long SLEEP_TIME = 5*1000; // Sleep time between reads (in milliseconds)
    DHT dht;
    float lastTemp = -100;
    float lastHum = -100;
    boolean metric = true;
      sendSketchInfo("TestSketch 1.0");
      present(CHILD_ID_HUM, S_HUM);
      Serial.println("Setting up..");
      Serial.flush();
      // put your main code here, to run repeatedly:
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");Serial.println(temperature);
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");Serial.println(humidity);
      sleep(SLEEP_TIME);
    This is the output of the gateway:
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    0;255;0;0;18;2.0.0
    0;255;3;0;9;TSP:SANCHK:OK
    This is the output of the sensor:
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=10)
    TSM:FPAR
    TSP:MSG:SEND 10-10-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    I'm guessing they are not communicating with each-other? And I'm a little lost here and don't know where to continue troubleshooting.. I've replaced the SerialGateway with another radio and nano and both have the same issue.
    I've also tried several other mini's and radios, but no difference.
    Using Arduino 1.6.9 and capacitors on the radios...
    Any suggestions what to do next?
    [1]Nano
    [2]NRF24L01+
    [3]Video
    • SGiS Offline
      SGiS Offline
      SGi
      I have exactly the same problem.....
      • LOSTL Offline
        LOSTL Offline
        LOST
        It looks like it's similar to this: https://forum.mysensors.org/topic/4296/unable-to-get-simple-gateway-button-sensor-to-work-together
        I'm gonna try the debug for the NRF if it reveals any more...
        • LOSTL LOST
          T Offline
          T Offline
          tekka
          @LOST @SGi also make sure GW and node are not too close from each other.
          SGiS 1 Reply Last reply
          • T tekka
            SGiS Offline
            SGiS Offline
            SGi
            @tekka my node and gateway are about 1m apart
            • SGiS Offline
              SGiS Offline
              SGi
              Hmmm even when I try the example battery status sketch I get the same results from the debug.... Maybe something to do with the Nano or wiring?
              • SGiS Offline
                SGiS Offline
                SGi
                Oh I am using a Uno for the gateway and a nano for the DHT node...
                • SGiS SGi
                  T Offline
                  T Offline
                  tekka
                  @SGi I suggest to put them even further away, I've had similar issues with the LNA PA RF24 version.
                  • T tekka
                    SGiS Offline
                    SGiS Offline
                    SGi
                    @tekka thanks but that doesn't appear to change anything. Do you understand the error from the sensor debug? Is it not getting a response so it restarts or something? Basically is it more likely the sensor or gateway end with the problem?
                    • ? Offline
                      ? Offline
                      A Former User
                      wrote on last edited by A Former User
                      Here the same, a simple sketch sending a value every 2 seconds on Arduino Pro mini its working but on @scalz simple aa node with atmega328 1MHz bootloader i am getting this error
                      Starting sensor (RRNNA-, 2.0.0)
                      TSM:INIT
                      TSM:RADIO:OK
                      TSP:ASSIGNID:OK (ID=41)
                      TSM:FPAR
                      TSP:MSG:SEND 41-41-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      !TSM:FPAR:FAIL
                      !TSM:FAILURE
                      TSM:PDT
                      And this on the gateway
                      0;255;3;0;9;TSP:MSG:BC
                      0;255;3;0;9;TSP:MSG:FPAR REQ (sender=41)
                      0;255;3;0;9;TSP:MSG:GWL OK
                      0;255;3;0;9;!TSP:MSG:SEND 0-0-41-41 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
                      0;255;3;0;9;TSP:MSG:READ 41-41-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                      I am using RFM69 radio
                      Here is the code link text
                      • S Offline
                        @kenci which aa node? I don't think this is my design ;)
                        About your issue,I have not digged yet so I don't know. On my side, the stParentUpdate is working I guess as I have not this problem. I'm using RFM69 too with a serial GW. But I'm still on end june temp 2.0b rev so I have not completely migrated to the new lib as I had some sketch to finish. I will update and diffcheck tests device today. So I will see if I fall into this, and try to debug if I can replicate the problem ;)
                        Just in case, what is your GW? I have serial gw + esp mqtt on my side for testing.
                        ? 1 Reply Last reply
                        • SGiS Offline
                          SGiS Offline
                          SGi
                          https://forum.mysensors.org/topic/4316/version-2-0-isn-t-working this could be the fix... Have to try tomorrow night....
                          • S scalz
                            ? Offline
                            ? Offline
                            A Former User
                            Sorry @scalz , it was another user who designed the board, user @m26872 was it. My gateway is an ESP8266 with MQTT. I will try to find out what the problem is. With the same sketch it's working on an Arduino Pro 328 3v3. But on @m26872's board with 1MHz it's not.
                            EDIT:
                            I found out that my Simple AA node is not receiving packets(ATMega328 1MHZ). So now i have to check why!
                            EDIT 2:
                            OK, i found out if i connect DI0 of RFM69 to D2 it's working. But if i want to use D3(because D2 is in use for a switch) it's not working, even if i set #define MY_RF69_IRQ_PIN 3 in my sketch!
                            • S Offline
                              @kenci ok, I think I know where is your problem. Try to add this in your sketch (before mysensors include of course)
                              #define MY_RF69_IRQ_NUM 1
                              That should work. I will do the change.
