  3. Unable to get simple Gateway + Button Sensor to work together
2 Posts 2 Posters 1.2k Views 3 Watching
  • thekeenoT Offline
    thekeenoT Offline
    thekeeno
    wrote on last edited by thekeeno
    Hi all,
    I started testing a simple configuration with a Serial Gateway and Binary Switch Sensor and I'm unable to get the two devices to interact with each other.
    The gateway is an Uno linked to a standard (no antenna) NRF24L01+ with a 47uF cap across 3v3 and GND. The code on it looks like so:
     * The ArduinoGateway prints data received from sensors on the serial link.
     * The gateway accepts input on seral which will be sent out on radio network.
     * The GW code is designed for Arduino Nano 328p / 16MHz
     * Wire connections (OPTIONAL):
     * - Inclusion button should be connected between digital pin 3 and GND
     * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
     * LEDs (OPTIONAL):
     * - To use the feature, uncomment MY_LEDS_BLINKING_FEATURE in MyConfig.h
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Flash leds on rx/tx/err
    #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // Enable inclusion mode
    void presentation() {
    The sensor is an Uno linked to a standard (no antenna) NRF24L01+ with a 47uF cap across 3v3 and GND. Code on it is as so:
     * Interrupt driven binary switch example with dual interrupts
     * Author: Patrick 'Anticimex' Fallberg
     * Connect one button or door/window reed switch between
     * digitial I/O pin 3 (BUTTON_PIN below) and GND and the other
     * one in similar fashion on digital I/O pin 2.
     * This example is designed to fit Arduino Nano/Pro Mini
    #define SKETCH_NAME "Binary Sensor"
    #define SKETCH_MAJOR_VER "1"
    #define SKETCH_MINOR_VER "0"
    #define PRIMARY_CHILD_ID 3
    #define SECONDARY_CHILD_ID 4
    #define PRIMARY_BUTTON_PIN 2   // Arduino Digital I/O pin for button/reed switch
    #define SECONDARY_BUTTON_PIN 3 // Arduino Digital I/O pin for button/reed switch
    #if (PRIMARY_BUTTON_PIN < 2 || PRIMARY_BUTTON_PIN > 3)
    #error PRIMARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
    #if (SECONDARY_BUTTON_PIN < 2 || SECONDARY_BUTTON_PIN > 3)
    #error SECONDARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
    #if (PRIMARY_BUTTON_PIN == SECONDARY_BUTTON_PIN)
    #error PRIMARY_BUTTON_PIN and BUTTON_PIN2 cannot be the same
    #if (PRIMARY_CHILD_ID == SECONDARY_CHILD_ID)
    #error PRIMARY_CHILD_ID and SECONDARY_CHILD_ID cannot be the same
    MyMessage msg(PRIMARY_CHILD_ID, V_TRIPPED);
    MyMessage msg2(SECONDARY_CHILD_ID, V_TRIPPED);
      // Setup the buttons
      pinMode(PRIMARY_BUTTON_PIN, INPUT);
      pinMode(SECONDARY_BUTTON_PIN, INPUT);
      // Activate internal pull-ups
      digitalWrite(PRIMARY_BUTTON_PIN, HIGH);
      digitalWrite(SECONDARY_BUTTON_PIN, HIGH);
      sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER "." SKETCH_MINOR_VER);
      // Register binary input sensor to sensor_node (they will be created as child devices)
      present(PRIMARY_CHILD_ID, S_DOOR);
      present(SECONDARY_CHILD_ID, S_DOOR);
      uint8_t value;
      static uint8_t sentValue=2;
      static uint8_t sentValue2=2;
      sleep(5);
      value = digitalRead(PRIMARY_BUTTON_PIN);
      if (value != sentValue) {
         // Value has changed from last transmission, send the updated value
         send(msg.set(value==HIGH ? 1 : 0));
         sentValue = value;
      value = digitalRead(SECONDARY_BUTTON_PIN);
      if (value != sentValue2) {
         send(msg2.set(value==HIGH ? 1 : 0));
         sentValue2 = value;
      // Sleep until something happens with the sensor
      sleep(PRIMARY_BUTTON_PIN-2, CHANGE, SECONDARY_BUTTON_PIN-2, CHANGE, 0);
    I managed to get the gateway to interact with both Domoticz and Home Assistant but neither reported the button to exist. I checked the serial output. On the gateway it says:
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    0;255;0;0;18;2.0.0
    0;255;3;0;9;TSP:SANCHK:OK
    On the Sensor it says:
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    How should I interpret this error? Can't find anything on specific debug messages in the FAQ.
    Sketches were uploaded from a computer running Win 10 Home, Arduino 1.6.9 and MySensors 2.0.0 and all the code used above is copied near-verbatim from the MySensors examples.
    Is there any way for me to verify that the problem doesn't lie with my NRF24L01+ devices themselves?
    All help is massively appreciated!
    T 1 Reply Last reply
    • thekeenoT thekeeno
      Hi all,
       * LEDs (OPTIONAL):
        uint8_t value;
        sleep(5);
           sentValue = value;
           sentValue2 = value;
      0;255;0;0;18;2.0.0
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR
      T Offline
      T Offline
      tekka
      @thekeeno You can enable verbose mode for the nRF24:
      #define MY_DEBUG_VERBOSE_RF24
      Please enable it for both, GW and node, and post the debug log here. Thanks.
