  3. Simple Serial Gateway and sensor does not work...
14 Posts 5 Posters 7.1k Views 3 Watching
  • LOSTL
    LOSTL
    LOST
    It looks like it's similar to this: https://forum.mysensors.org/topic/4296/unable-to-get-simple-gateway-button-sensor-to-work-together
    I'm gonna try the debug for the NRF if it reveals any more...
    tekkaT 1 Reply Last reply
    • LOSTL LOST
      tekkaT
      tekkaT
      tekka
      @LOST @SGi also make sure GW and node are not too close from each other.
      SGiS 1 Reply Last reply
      • tekkaT tekka
        SGiS
        SGiS
        SGi
        @tekka my node and gateway are about 1m apart
        • SGiS
          SGiS
          SGi
          Hmmm even when I try the example battery status sketch I get the same results from the debug.... Maybe something to do with the Nano or wiring?
          • SGiS
            SGiS
            SGi
            Oh I am using a Uno for the gateway and a nano for the DHT node...
            • SGiS SGi
              tekkaT
              tekkaT
              tekka
              @SGi I suggest to put them even further away, I've had similar issues with the LNA PA RF24 version.
              • tekkaT tekka
                SGiS
                SGiS
                SGi
                @tekka thanks but that doesn't appear to change anything. Do you understand the error from the sensor debug? Is it not getting a response so it restarts or something? Basically is it more likely the sensor or gateway end with the problem?
                  A Former User
                  wrote on last edited by [[global:former-user]]
                  Here the same, a simple sketch sending a value every 2 seconds on Arduino Pro mini its working but on @scalz simple aa node with atmega328 1MHz bootloader i am getting this error
                  Starting sensor (RRNNA-, 2.0.0)
                  TSM:INIT
                  TSM:RADIO:OK
                  TSP:ASSIGNID:OK (ID=41)
                  TSM:FPAR
                  TSP:MSG:SEND 41-41-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  !TSM:FPAR:FAIL
                  !TSM:FAILURE
                  TSM:PDT
                  And this on the gateway
                  0;255;3;0;9;TSP:MSG:BC
                  0;255;3;0;9;TSP:MSG:FPAR REQ (sender=41)
                  0;255;3;0;9;TSP:MSG:GWL OK
                  0;255;3;0;9;!TSP:MSG:SEND 0-0-41-41 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
                  0;255;3;0;9;TSP:MSG:READ 41-41-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                  I am using RFM69 radio
                  Here is the code link text
                    @kenci which aa node? I don't think this is my design ;)
                    About your issue,I have not digged yet so I don't know. On my side, the stParentUpdate is working I guess as I have not this problem. I'm using RFM69 too with a serial GW. But I'm still on end june temp 2.0b rev so I have not completely migrated to the new lib as I had some sketch to finish. I will update and diffcheck tests device today. So I will see if I fall into this, and try to debug if I can replicate the problem ;)
                    Just in case, what is your GW? I have serial gw + esp mqtt on my side for testing.
                    ? 1 Reply Last reply
                    • SGiS
                      SGiS
                      SGi
                      https://forum.mysensors.org/topic/4316/version-2-0-isn-t-working this could be the fix... Have to try tomorrow night....
                      • scalzS scalz
                        A Former User
                        Sorry @scalz , it was another user who designed the board, user @m26872 was it. My gateway is an ESP8266 with MQTT. I will try to find out what the problem is. With the same sketch it's working on an Arduino Pro 328 3v3. But on @m26872's board with 1MHz it's not.
                        EDIT:
                        I found out that my Simple AA node is not receiving packets(ATMega328 1MHZ). So now i have to check why!
                        EDIT 2:
                        OK, i found out if i connect DI0 of RFM69 to D2 it's working. But if i want to use D3(because D2 is in use for a switch) it's not working, even if i set #define MY_RF69_IRQ_PIN 3 in my sketch!
                          @kenci ok, I think I know where is your problem. Try to add this in your sketch (before mysensors include of course)
                          #define MY_RF69_IRQ_NUM 1
                          That should work. I will do the change.
