  3. Version 2.0 isn't working...
9 Posts 4 Posters 11.6k Views 3 Watching
  • mk55M Offline
    mk55M Offline
    mk55
    Everything was working fine, before I copied the new version to the arduino libraries
    I tried the clear eeprom sketch without success.
    When I try the pingpongsensors sketch I get this:
    TSM:INIT
    TSM:RADIO:OK
    !TSP:ASSIGNID:FAIL (ID=0)
    !TSM:FAILURE
    TSM:PDT
    TSM:FPAR
    TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    !TSM:FAILURE
    TSM:PDT
    TSM:FPAR
    TSM:FPAR
    TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:```
    • T Offline
      T Offline
      tbowmo
      Have you updated both GW and node to 2.0.0? If I remember right, a node on 2.0.0 requires a GW on 2.0.0.
      From the logs the node is trying to get a nodeid from GW.
      • mk55M Offline
        mk55M Offline
        mk55
        I'm using the pingpongsensors sketch on both nodes
        A 1 Reply Last reply
        • mk55M mk55
          A Offline
          A Offline
          AWI
          @mk55 You would still need the nodeid from the gateway.
          mk55M 1 Reply Last reply
          • A AWI
            mk55M Offline
            mk55M Offline
            mk55
            @AWI Even when I try different sketches It just won't work...
            Reverting back makes everything works again..
            This what I get when I try 1 node with GatewaySerial sketch and 1 node with Relayactuator
            TSM:FPAR
            Starting repeater (RNNRA-, 2.0.0)
            TSM:INIT
            TSM:RADIO:OK
            !TSM:FAILURE
            TSM:PDT
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            !TSM:FPAR:FAIL
            !TSM:FAILURE
            TSM:PDT
            TSM:INIT
            TSM:RADIO:OK
            !TSM:FAILURE
            TSM:PDT
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            A T 2 Replies Last reply
            • mk55M mk55
              TSM:FPAR
              TSM:INIT
              TSM:RADIO:OK
              !TSM:FAILURE
              TSM:PDT
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              !TSM:FPAR:FAIL
              !TSM:FAILURE
              TSM:PDT
              TSM:INIT
              TSM:RADIO:OK
              !TSM:FAILURE
              TSM:PDT
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              A Offline
              A Offline
              AWI
              @mk55 as @tbowmo mentioned the node is not getting an id. For me the new debug output is also not complete clear. It could indicate that you have a transmission problem. A way to find out is look at the debug output from both nodes.
              • mk55M mk55
                TSM:FPAR
                TSM:INIT
                TSM:RADIO:OK
                !TSM:FAILURE
                TSM:PDT
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                !TSM:FPAR:FAIL
                !TSM:FAILURE
                TSM:PDT
                TSM:INIT
                TSM:RADIO:OK
                !TSM:FAILURE
                TSM:PDT
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                T Offline
                T Offline
                tekka
                wrote on last edited by tekka
                @mk55 The issue here is, that the node has ID 0 which is not allowed, hence
                How did you clear the EEPROM? It looks like you used the Arduino eeprom_clr example - this is not compatible with the MySensors setup. Instead, you should use the MySensors ClearEepromConfig.
                Next step, if you do not have a controller that assigns ID, you can assign a static ID , e.g. 1, using
                #define MY_NODE_ID 1
                • T tekka
                  mk55M Offline
                  mk55M Offline
                  mk55
                  @tekka Omg tekka you're awsome!!
                  I did used the arduino eeprom_clr example, and when tried the ClearEepromConfig everything magically worked! :)
                  Thanks all!
                  • mk55M mk55
                    Thanks all!
                    T Offline
                    T Offline
                    tekka
                    @mk55 Excellent, happy to hear :)
