  3. Problems with first sensors
62 Posts 9 Posters 34.9k Views 11 Watching
  • blebbensB
    blebbensB
    blebbens
    This is what domoticz looks like...
    Connecting the serial gateway to my computer means, I can not connect it to domoticz ?
    For debugging I have to enable #define MY_DEBUG ?
    Or, is there a way to read the log file on the gateway ?
    AWIA 1 Reply Last reply
      I don't know about domoticz but perhaps you can get the logs. Or use MYSController.
      Otherwise, when you need it, you can debug gw and node on your computer. Just connect both devices to your computer. Then of course this is not connected to domoticz but for debugging i often do this, it's useful.
      So:
      • connect gw+node to your computer
      • then use Serial monitor from arduino if you want, to monitor one device. choose right baudrate and comport of course
      • and for other device, use another serial monitor like putty etc..
        or a sniffer if you really want to keep it connected to your controller. But for noobs, i would advice to simply use two serial monitor when you need to debug, easier..
      • blebbensB blebbens
        AWIA
        AWIA
        AWI
        @blebbens your domoticz screen looks fine. No errors but also no sensors reported. Only the node is known.
        As @scalz mentioned, just connect the node and gateway to your computer watch what happens on the serial monitor (arduino idea or whatever you are using) the node does not have to be connected to domoticz for initial debugging.
        • blebbensB
          blebbensB
          blebbens
          wrote on last edited by blebbens
          #21
          Okay, I have...
          The motion sensor connected to the Arduino IDE. The output of the serial monitor (at this time the gateway was connected to the controller):
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          !TSM:FPAR:FAIL
          !TSM:FAILURE
          TSM:PDT
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          An at this point I had the gateway connected to the arduino IDE (the motion sensor was not connected to the computer):
          0;255;3;0;9;TSM:INIT
          0;255;3;0;9;TSM:RADIO:OK
          0;255;3;0;9;TSM:GW MODE
          0;255;3;0;9;TSM:READY
          0;255;0;0;18;2.0.0
          0;255;3;0;9;TSP:SANCHK:OK
          I never had both, gateway and sensor, connected to the monitor at the same time. I am afraid, I didn´t understand to use MYScontroller. Did not find the com-port settings etc. It always tries to connect to gateway 192.168.0.x, my network is not set up to this IP.
          Does the output help ?
            #22
            nope, output can't help as it's only one device..
            I think you're talking about MYSController config when you say 192.168.0.x, isn't it? or i don't understand lol
            To know your serialports in use:
            • with Win for instance, go to something like Control Panel → Device Manager → COM & LPT ports
            • connect your devices to usb, and disconnect one by one. So now you know which one use which port.
            About MYSController: you will need to setup the serial port for GW.
            • With GW connected to usb, click Settings button and then click Gateway tab.
            • Check Serial GW and choose port&bauds.
            • Now, still in MYSController, you can click Connect button. There are tabs in MYSController for different debug levels. Look a bit at features.
            • It should connect, if it does not, un/replug your gw, and reclick Connect.
            Then you'll have the logs for your GW if it is enabled in sketch of course.
            As said above, if you would like, you could use another software (serial monitor) in place of MYSController. but not required here.
            Now, for the other device (node), you can monitor it in Arduino software by setting well port&bauds. you know it now ;)
            Could you try in this order, please :
            • plug GW only. And connect with MYSController
            • then plug node, and open your Arduino Serial monitor.
            does it work? if no, logs, thx ;)
            • blebbensB
              blebbensB
              blebbens
              #23
              Okay, done it... both connected, gw on MYScontroller, motion sensor monitored using IDE...
              Sensor output:
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              !TSM:FPAR:FAIL
              !TSM:FAILURE
              TSM:PDT
              And gateway output:
              MYScontroller debug:
              16.07.2016 19:43:42	INFO	Flushing FIFO
              16.07.2016 19:43:42	INFO	Connected to COM7
              16.07.2016 19:43:44	RX	0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0)
              16.07.2016 19:43:44	CHILD	New child discovered, node id=0, child id=internal
              16.07.2016 19:43:44	RX	0;255;3;0;9;TSM:INIT
              16.07.2016 19:43:44	RX	0;255;3;0;9;TSM:RADIO:OK
              16.07.2016 19:43:44	RX	0;255;3;0;9;TSM:GW MODE
              16.07.2016 19:43:44	RX	0;255;3;0;9;TSM:READY
              16.07.2016 19:43:44	RX	0;255;3;0;14;Gateway startup complete.
              16.07.2016 19:43:44	RX	0;255;0;0;18;2.0.0
              16.07.2016 19:43:44	DEBUG	Update child id=255, type=S_ARDUINO_REPEATER_NODE
              16.07.2016 19:43:44	RX	0;255;3;0;9;No registration required
              16.07.2016 19:43:44	RX	0;255;3;0;9;Init complete, id=0, parent=0, distance=0, registration=1
              16.07.2016 19:44:44	RX	0;255;3;0;9;TSP:SANCHK:OK
              16.07.2016 19:45:44	RX	0;255;3;0;9;TSP:SANCHK:OK
              MySensors debug:
              8	16.07.2016 19:43:44	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			required
              Nodes debug: this message was shown before I connected the sensor to power
              7	16.07.2016 19:43:44	0 - Gateway	S_ARDUINO_REPEATER_NODE	S_ARDUINO_REPEATER_NODE	2.0.0
              And messages tab:
              6	16.07.2016 19:43:44	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_GATEWAY_READY	Gateway startup complete.
              7	16.07.2016 19:43:44	RX	0 - Gateway	INTERNAL	C_PRESENTATION	NO	S_ARDUINO_REPEATER_NODE	2.0.0
              Okay, hope, this helps now.
              That´s strange, because there is no repeater... just a motion sensor sketch.
              • blebbensB
                blebbensB
                blebbens
                No one ? It is so frustrating...
                Read some more threads like this (https://forum.mysensors.org/topic/4280/simple-serial-gateway-and-sensor-does-not-work)... seems to be a common problem of MySensors 2.0 ?
                tekkaT 1 Reply Last reply
                • SGiS
                  SGiS
                  SGi
                  Try this: https://forum.mysensors.org/topic/4316/version-2-0-isn-t-working
                    tekkaT
                    tekkaT
                    tekka
                    wrote on last edited by tekka
                    #26
                    @blebbens Your logs look ok, but your radios don't seem to talk to each other - this could possibly hint to radio interference or HW issues. Try:
                    (1) reduce PA power by setting:
                    and recompile and reflash GW and node sketch.
                    (2) move node and GW further away from each other
                    (3) Switch off WiFi AP
                    Please report back on any of these solutions with log from GW and node.
                    • blebbensB
                      blebbensB
                      blebbens
                      #27
                      Now I defined MY_RF24_PA_LEVEL RF24_PA_LOW in both, gateway and sensor.
                      Before I have done this, I compiled and uploaded the ClearEpromConfig.
                      The logs... gateway:
                      17.07.2016 15:52:22	STARTUP	Initialize message logging
                      17.07.2016 15:52:22	STARTUP	1.0.0 (build 3314)
                      17.07.2016 15:52:22	STARTUP	FPC 3.0.0 / Lazarus 1.6
                      17.07.2016 15:52:22	STARTUP	still under development :) tekka 2016
                      17.07.2016 15:52:22	STARTUP	Load INI file...
                      17.07.2016 15:52:22	STARTUP	INI version 1.0.0 (build 3314)
                      17.07.2016 15:52:23	INFO	*** Logging START ***
                      17.07.2016 15:52:23	VERSION	1.0.0 (build 3314)
                      17.07.2016 15:52:23	INFO	Logging=TRUE
                      17.07.2016 15:52:23	INFO	AutoID=TRUE
                      17.07.2016 15:52:23	INFO	AutoFW=TRUE
                      17.07.2016 15:52:23	STARTUP	INI file loaded
                      17.07.2016 15:52:23	STARTUP	Loading FW repository...
                      17.07.2016 15:52:23	REPO	FW "Blink" loaded. t=10, v=1, blocks=80, crc=0x46D4
                      17.07.2016 15:52:23	REPO	FW "TimeReporter" loaded. t=20, v=1, blocks=736, crc=0xE923
                      17.07.2016 15:52:23	REPO	FW repository loaded. Items=2
                      17.07.2016 15:52:23	STARTUP	Initialize message types
                      17.07.2016 15:52:23	NODE	New node discovered, node id=0
                      17.07.2016 15:52:23	NODE	New node discovered, node id=255
                      17.07.2016 15:52:23	INFO	read MySensors.xml
                      17.07.2016 15:52:23	INFO	Application: MYSController
                      17.07.2016 15:52:23	INFO	Node id=0 skipped
                      17.07.2016 15:52:23	INFO	Node id=255 skipped
                      17.07.2016 15:52:30	UPDATE	current=1.0.0.3314 remote=1.0.0.3314
                      17.07.2016 15:52:32	INFO	Flushing FIFO
                      17.07.2016 15:52:32	INFO	Connected to COM9
                      17.07.2016 15:52:34	RX	0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0)
                      17.07.2016 15:52:34	CHILD	New child discovered, node id=0, child id=internal
                      17.07.2016 15:52:34	RX	0;255;3;0;9;TSM:INIT
                      17.07.2016 15:52:34	RX	0;255;3;0;9;TSM:RADIO:OK
                      17.07.2016 15:52:34	RX	0;255;3;0;9;TSM:GW MODE
                      17.07.2016 15:52:34	RX	0;255;3;0;9;TSM:READY
                      17.07.2016 15:52:34	RX	0;255;3;0;14;Gateway startup complete.
                      17.07.2016 15:52:34	RX	0;255;0;0;18;2.0.0
                      17.07.2016 15:52:34	DEBUG	Update child id=255, type=S_ARDUINO_REPEATER_NODE
                      17.07.2016 15:52:34	RX	0;255;3;0;9;No registration required
                      17.07.2016 15:52:34	RX	0;255;3;0;9;Init complete, id=0, parent=0, distance=0, registration=1
                      6	17.07.2016 15:52:34	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_GATEWAY_READY	Gateway startup complete.
                      7	17.07.2016 15:52:34	RX	0 - Gateway	INTERNAL	C_PRESENTATION	NO	S_ARDUINO_REPEATER_NODE	2.0.0
                      And, the sensor...
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      !TSM:FPAR:FAIL
                      !TSM:FAILURE
                      TSM:PDT
                      They now are far away from each other...
                      I think, all cables are connected to the right position.
                      EDIT:
                      Found a MQ-135 air quality sensor. Uploaded the mysensor example sketch. But, the same error output in serial monitor.
                      Please take a look at this picture of my NRF24L01 amplified. Perhaps, it is wrong wired ? On my NRF24 there is no mark for GND, so I took this picture.
                      But, isn´t my gateway (wired the same) working very well ? Is there a way to find out, if the wiring is wrong ? Would the gateway work like you can see in the log ?
                      Or another idea: I changed the gateway´s sketch to a baud rate of 115200. The sensor´s sketches don´t contain this information. Do I need to set their baud rate to 115200, too ?
                        And, the sensor...
                        TSM:INIT
                        TSM:RADIO:OK
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR
                        !TSM:FPAR:FAIL
                        !TSM:FAILURE
                        TSM:PDT
                        EDIT:
                        tekkaT
                        tekkaT
                        tekka
                        #28
                        @blebbens Looks like you have nRF24L01, not nRF24L01+. The nRF24L01 does not support 250Kbps (see here, page 8 ). MySensors is set (by default) to 250Kbps datarate. In your case, try this:
                        #define MY_RF24_DATARATE RF24_1MBPS
                        and recompile and reflash GW and node.
                          @blebbens
                          could you show a link where you bought radio modules you're using please. I think @tekka may have found the problem :)
                          For people who are getting same messages "FPAR FAIL", I think you may fall into the old case "st:fail", hardware related like using capa for radio, tekka advices above etc... where radio does not work properly and there is no ACK back so the comm is not validated. Then, after multiple retries, it fails.
                          I can confirm this at least for static nodes. On my side, the latest v2.0 from dev branch works ok for me. as expected ;) Config tested for the moment is serial gw with exotic mcu atsam (I mean compared to classic gw). And the node is a multisensors. Radio is RFM69.
                          • blebbensB
                            blebbensB
                            blebbens
                            Flashed ClearEpromConfig...
                            Added to the sketches...
                            Think, this overrides MyConfig.h ?
                            What a pity... just the same output... recognized as "unknown" S_ARDUINO_REPEATER_NODE.
                            I bought this NRF:
                            http://www.aliexpress.com/item/1sets-Special-promotions-1100-meter-long-distance-NRF24L01-PA-LNA-wireless-modules-with-antenna/32341792715.html?spm=2114.13010608.0.161.TbEXts
                            But, the delivered NRFs have no marked GND.
                            Oh, any ideas left ? Delivery of standard NRFs take 30-40 days.
                            Extract of MyConfig.h:
                             * @def MY_RF24_SPI_MAX_SPEED
                             * @def MY_RF24_CE_PIN
                            #ifndef MY_RF24_CE_PIN
                            		#define MY_RF24_CE_PIN 4
                            		#define MY_RF24_CE_PIN 27
                            		#define MY_RF24_CE_PIN 9
                             * @def MY_RF24_CS_PIN
                            #ifndef MY_RF24_CS_PIN
                            		#define MY_RF24_CS_PIN 15
                            		#define MY_RF24_CS_PIN 3
                            		#define MY_RF24_CS_PIN 10
                             * @def MY_RF24_PA_LEVEL
                            #ifndef MY_RF24_PA_LEVEL
                             * @def MY_RF24_CHANNEL
                            #ifndef MY_RF24_CHANNEL
                            #define MY_RF24_CHANNEL	76
                             * @def MY_RF24_DATARATE
                            #ifndef MY_RF24_DATARATE
                            • Tore André RosanderT
                              Tore André Rosander
                              Have you tried to use another sketch?
                              Just a random mysensors sketch to see if it that one also get presented as repeater node.
                              Maybe just take one with a button and make your own (if you dont have any) and see if the buttonpress gets transmitted.
                              blebbensB 1 Reply Last reply
                              • Tore André RosanderT Tore André Rosander
                                blebbensB
                                blebbensB
                                blebbens
                                @Tore-André-Rosander
                                Have tried out different sample-sketches from library, e.g. motion and air quality.
                                It is... so... frustrating. There has to be a stupid mistake causing the sensors to report their availability as repeater node.
                                  tekkaT
                                  tekkaT
                                  tekka
                                  #33
                                  @blebbens I totally understand your frustration but I'm afraid, your issue seems HW/radio-related. The logs look normal, also the repeater node message (which is actually emitted from the GW, see your domoticz screenshot and GW log). If you can get a different pair of nRF24L01+ (the P-version), I'd retry with those.
                                    Tore André Rosander
                                    wrote on last edited by Tore André Rosander
                                    #34
                                    Is it just me or does it look like the repeater node is not the actual sensor node?
                                    If you look at the logs " Gateway INTERNAL C_PRESENTATION NO S_ARDUINO_REPEATER_NODE 2.0.0" "New child discovered, node id=0, child id=internal" and "Update child id=255, type=S_ARDUINO_REPEATER_NODE"
                                    How about try to define the node id manually?
                                    And just to be sure the clear eeprom config sketch in the mySensors examples.
                                    You can also try the RF24 library ping-pong examples to test your radios.
                                    • SGiS
                                      SGiS
                                      SGi
                                      Ok so connections appear to be my major problem.... my dupont cables seem to be a bit dodgy... now wired with solid jumpers i can get the 'gettingstarted' sketch of the RF24 library working.
                                      Now i have the following log from the sensor which is encouraging but still weird:
                                      0_1468831166660_upload-4129d0ca-3934-4199-b4a4-5eb6553a1103
                                      Anything obvious now? The sketch on the sensor is the basic motionsensor one from the examples of 2.0.0 and the gateway is the serialgateway sketch... both no changes
                                      nielsokkerN 1 Reply Last reply
                                      • SGiS SGi
                                        nielsokkerN
                                        nielsokkerN
                                        nielsokker
                                        @SGi
                                        I am not an expert but i had the same problem. I think a controller determines the id. But since you have none, it can't be done this way. Set a static ID with
                                        #define MY_NODE_ID 11
                                        or something
                                        SGiS 1 Reply Last reply
                                        • nielsokkerN nielsokker
                                          @SGi
                                          or something
                                          SGiS
                                          SGiS
                                          SGi
                                          @nielsokker Yea you are probably right, no problem now though since as soon as i hooked it up to my controller everything works fine :) dodgy wires on the gateway was the issue all along.... using the very basic node sketch i can now see it in Domoticz and watch it turn on/off every 10 secs :)
