  3. Problems with first sensors
62 Posts 9 Posters 34.9k Views 11 Watching
  • blebbensB
    blebbensB
    blebbens
    wrote on last edited by blebbens
    #27
    Now I defined MY_RF24_PA_LEVEL RF24_PA_LOW in both, gateway and sensor.
    Before I have done this, I compiled and uploaded the ClearEpromConfig.
    The logs... gateway:
    17.07.2016 15:52:22	STARTUP	Initialize message logging
    17.07.2016 15:52:22	STARTUP	1.0.0 (build 3314)
    17.07.2016 15:52:22	STARTUP	FPC 3.0.0 / Lazarus 1.6
    17.07.2016 15:52:22	STARTUP	still under development :) tekka 2016
    17.07.2016 15:52:22	STARTUP	Load INI file...
    17.07.2016 15:52:22	STARTUP	INI version 1.0.0 (build 3314)
    17.07.2016 15:52:23	INFO	*** Logging START ***
    17.07.2016 15:52:23	VERSION	1.0.0 (build 3314)
    17.07.2016 15:52:23	INFO	Logging=TRUE
    17.07.2016 15:52:23	INFO	AutoID=TRUE
    17.07.2016 15:52:23	INFO	AutoFW=TRUE
    17.07.2016 15:52:23	STARTUP	INI file loaded
    17.07.2016 15:52:23	STARTUP	Loading FW repository...
    17.07.2016 15:52:23	REPO	FW "Blink" loaded. t=10, v=1, blocks=80, crc=0x46D4
    17.07.2016 15:52:23	REPO	FW "TimeReporter" loaded. t=20, v=1, blocks=736, crc=0xE923
    17.07.2016 15:52:23	REPO	FW repository loaded. Items=2
    17.07.2016 15:52:23	STARTUP	Initialize message types
    17.07.2016 15:52:23	NODE	New node discovered, node id=0
    17.07.2016 15:52:23	NODE	New node discovered, node id=255
    17.07.2016 15:52:23	INFO	read MySensors.xml
    17.07.2016 15:52:23	INFO	Application: MYSController
    17.07.2016 15:52:23	INFO	Node id=0 skipped
    17.07.2016 15:52:23	INFO	Node id=255 skipped
    17.07.2016 15:52:30	UPDATE	current=1.0.0.3314 remote=1.0.0.3314
    17.07.2016 15:52:32	INFO	Flushing FIFO
    17.07.2016 15:52:32	INFO	Connected to COM9
    17.07.2016 15:52:34	RX	0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0)
    17.07.2016 15:52:34	CHILD	New child discovered, node id=0, child id=internal
    17.07.2016 15:52:34	RX	0;255;3;0;9;TSM:INIT
    17.07.2016 15:52:34	RX	0;255;3;0;9;TSM:RADIO:OK
    17.07.2016 15:52:34	RX	0;255;3;0;9;TSM:GW MODE
    17.07.2016 15:52:34	RX	0;255;3;0;9;TSM:READY
    17.07.2016 15:52:34	RX	0;255;3;0;14;Gateway startup complete.
    17.07.2016 15:52:34	RX	0;255;0;0;18;2.0.0
    17.07.2016 15:52:34	DEBUG	Update child id=255, type=S_ARDUINO_REPEATER_NODE
    17.07.2016 15:52:34	RX	0;255;3;0;9;No registration required
    17.07.2016 15:52:34	RX	0;255;3;0;9;Init complete, id=0, parent=0, distance=0, registration=1
    6	17.07.2016 15:52:34	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_GATEWAY_READY	Gateway startup complete.
    7	17.07.2016 15:52:34	RX	0 - Gateway	INTERNAL	C_PRESENTATION	NO	S_ARDUINO_REPEATER_NODE	2.0.0
    And, the sensor...
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    They now are far away from each other...
    I think, all cables are connected to the right position.
    EDIT:
    Found a MQ-135 air quality sensor. Uploaded the mysensor example sketch. But, the same error output in serial monitor.
    Please take a look at this picture of my NRF24L01 amplified. Perhaps, it is wrong wired ? On my NRF24 there is no mark for GND, so I took this picture.
    But, isn´t my gateway (wired the same) working very well ? Is there a way to find out, if the wiring is wrong ? Would the gateway work like you can see in the log ?
    Or another idea: I changed the gateway´s sketch to a baud rate of 115200. The sensor´s sketches don´t contain this information. Do I need to set their baud rate to 115200, too ?
    tekkaT 1 Reply Last reply
    • blebbensB blebbens
      And, the sensor...
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      EDIT:
      tekkaT
      tekkaT
      tekka
      wrote on last edited by tekka
      #28
      @blebbens Looks like you have nRF24L01, not nRF24L01+. The nRF24L01 does not support 250Kbps (see here, page 8 ). MySensors is set (by default) to 250Kbps datarate. In your case, try this:
      #define MY_RF24_DATARATE RF24_1MBPS
      and recompile and reflash GW and node.
        @blebbens
        could you show a link where you bought radio modules you're using please. I think @tekka may have found the problem :)
        For people who are getting same messages "FPAR FAIL", I think you may fall into the old case "st:fail", hardware related like using capa for radio, tekka advices above etc... where radio does not work properly and there is no ACK back so the comm is not validated. Then, after multiple retries, it fails.
        I can confirm this at least for static nodes. On my side, the latest v2.0 from dev branch works ok for me. as expected ;) Config tested for the moment is serial gw with exotic mcu atsam (I mean compared to classic gw). And the node is a multisensors. Radio is RFM69.
        • blebbensB
          blebbensB
          blebbens
          Flashed ClearEpromConfig...
          Added to the sketches...
          Think, this overrides MyConfig.h ?
          What a pity... just the same output... recognized as "unknown" S_ARDUINO_REPEATER_NODE.
          I bought this NRF:
          http://www.aliexpress.com/item/1sets-Special-promotions-1100-meter-long-distance-NRF24L01-PA-LNA-wireless-modules-with-antenna/32341792715.html?spm=2114.13010608.0.161.TbEXts
          But, the delivered NRFs have no marked GND.
          Oh, any ideas left ? Delivery of standard NRFs take 30-40 days.
          Extract of MyConfig.h:
           * @def MY_RF24_SPI_MAX_SPEED
           * @def MY_RF24_CE_PIN
          #ifndef MY_RF24_CE_PIN
          		#define MY_RF24_CE_PIN 4
          		#define MY_RF24_CE_PIN 27
          		#define MY_RF24_CE_PIN 9
           * @def MY_RF24_CS_PIN
          #ifndef MY_RF24_CS_PIN
          		#define MY_RF24_CS_PIN 15
          		#define MY_RF24_CS_PIN 3
          		#define MY_RF24_CS_PIN 10
           * @def MY_RF24_PA_LEVEL
          #ifndef MY_RF24_PA_LEVEL
           * @def MY_RF24_CHANNEL
          #ifndef MY_RF24_CHANNEL
          #define MY_RF24_CHANNEL	76
           * @def MY_RF24_DATARATE
          #ifndef MY_RF24_DATARATE
          • Tore André RosanderT
            Tore André Rosander
            Have you tried to use another sketch?
            Just a random mysensors sketch to see if it that one also get presented as repeater node.
            Maybe just take one with a button and make your own (if you dont have any) and see if the buttonpress gets transmitted.
            blebbensB 1 Reply Last reply
            • Tore André RosanderT Tore André Rosander
              blebbensB
              blebbensB
              blebbens
              @Tore-André-Rosander
              Have tried out different sample-sketches from library, e.g. motion and air quality.
              It is... so... frustrating. There has to be a stupid mistake causing the sensors to report their availability as repeater node.
                tekkaT
                tekkaT
                tekka
                #33
                @blebbens I totally understand your frustration but I'm afraid, your issue seems HW/radio-related. The logs look normal, also the repeater node message (which is actually emitted from the GW, see your domoticz screenshot and GW log). If you can get a different pair of nRF24L01+ (the P-version), I'd retry with those.
                  Tore André Rosander
                  wrote on last edited by Tore André Rosander
                  #34
                  Is it just me or does it look like the repeater node is not the actual sensor node?
                  If you look at the logs " Gateway INTERNAL C_PRESENTATION NO S_ARDUINO_REPEATER_NODE 2.0.0" "New child discovered, node id=0, child id=internal" and "Update child id=255, type=S_ARDUINO_REPEATER_NODE"
                  How about try to define the node id manually?
                  And just to be sure the clear eeprom config sketch in the mySensors examples.
                  You can also try the RF24 library ping-pong examples to test your radios.
                  • SGiS
                    SGiS
                    SGi
                    Ok so connections appear to be my major problem.... my dupont cables seem to be a bit dodgy... now wired with solid jumpers i can get the 'gettingstarted' sketch of the RF24 library working.
                    Now i have the following log from the sensor which is encouraging but still weird:
                    0_1468831166660_upload-4129d0ca-3934-4199-b4a4-5eb6553a1103
                    Anything obvious now? The sketch on the sensor is the basic motionsensor one from the examples of 2.0.0 and the gateway is the serialgateway sketch... both no changes
                    nielsokkerN 1 Reply Last reply
                    • SGiS SGi
                      nielsokkerN
                      nielsokkerN
                      nielsokker
                      @SGi
                      I am not an expert but i had the same problem. I think a controller determines the id. But since you have none, it can't be done this way. Set a static ID with
                      #define MY_NODE_ID 11
                      or something
                      SGiS 1 Reply Last reply
                      • nielsokkerN nielsokker
                        @SGi
                        or something
                        SGiS
                        SGiS
                        SGi
                        @nielsokker Yea you are probably right, no problem now though since as soon as i hooked it up to my controller everything works fine :) dodgy wires on the gateway was the issue all along.... using the very basic node sketch i can now see it in Domoticz and watch it turn on/off every 10 secs :)
                        • SGiS SGi
                          tekkaT
                          tekkaT
                          tekka
                          @SGi Excellent, have fun 👍
                          • blebbensB
                            blebbensB
                            blebbens
                            Think, I do not understand yet.
                            The motion sketch uses #define CHILD_ID 1.
                            Where do I have to insert #define MY_NODE_ID 1 ? Just into the skecht of the motion sensor ?
                            Tore André RosanderT 1 Reply Last reply
                              Tore André Rosander
                              @blebbens i think you can just put it over "define child id"
                                nielsokkerN
                                nielsokkerN
                                nielsokker
                                @Tore-André-Rosander said:
                                define child id"
                                I think so too.
                                These are probably just minor mistakes, changing from MySensors versions.
                                • blebbensB
                                  blebbensB
                                  blebbens
                                  So, I have to delete CHILD_ID und change it to MY_NODE_ID?
                                  Okay, reaching home today, perhaps. Hope, this works.
                                  nielsokkerN Tore André RosanderT 2 Replies Last reply
                                    Tore André Rosander
                                    No, just add the define node id.
                                      nielsokkerN
                                      nielsokkerN
                                      nielsokker
                                      @blebbens
                                      The old define, might become useless, but it wont be in the way either. It is your choice.
                                        @blebbens use MY_NODE_ID to define the id of your node. the child id is for your sensors id, not the node id.
                                          Tore André Rosander
                                          @blebbens I just replaced my RPi Gateway (the direct connection to GPIO) with the Serial Gateway, and the Repeater node you are seeing must be your gateway. Before i connected any nodes i got the same repeater node listed as hardware as you did, so it is probably your node that is the problem.
