  3. [SOLVED] ESP8266 WDT reset
34 Posts 6 Posters 47.9k Views 6 Watching
    The esp (and AVR) has something called a watchdog timer. It's actually there to help if something goes wrong, resetting the MCU. The watchdog timer can be disabled and reconfigured to allow longer interval. On ESP it's enabled by default and on AVR you have to enable it yourself (requires a special bootloader).
    Its works by using a timer which gets "reset" by calling yield() or delay(). Normally you don't have to worry about it as yield() is called automatically in the main loop().
    If yield() isn't called each second (which is the default timeout on ESP) the MCU will reset.
    If you have some long blocking tasks you can disable the wdt temporariily like this:
     wdt_disable();
     <some blocking task>
     wdt_enable();
    https://github.com/esp8266/Arduino/blob/master/cores/esp8266/Esp.h#L29-L46
    @hek are you sure disabling the WDT does actually work for ESP? The fact that the function exists, doesn't automatically mean it works :smirk:
    In the past there were numerous issues of users who tried to disable it but kept getting WDT resets. But again, maybe that's been fixed in 2.x
    • YveauxY Yveaux
      @172pilot please try with 2.0.0 development. 1.5 does not contain all fixes for ESP that 2.0.0 has.
      172pilot1
      172pilot1
      172pilot
      @Yveaux
      Thanks for the response.. I actually did get the 1.5 to at least come up, by putting some WDT resets around in various places that may take a while in a loop, for example, BUT, based on yours, and several other recommendations, I decided to try the 2.0 dev branch.. I deleted everything in my librarys\MySensors directory, and downloaded the DEV branch, and re-extracted the code, and now I can't compile.. I'm getting this:
      Arduino: 1.6.9 (Windows 10), Board: "SparkFun ESP8266 Thing Dev, 80 MHz, 115200"
      In file included from C:\Users\sjones\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/ESP8266WiFi.h:39:0,
                       from C:\Users\sjones\Documents\Arduino\MyDevelopment-2-0-GatewayESP8266\MyDevelopment-2-0-GatewayESP8266.ino:70:
      C:\Users\sjones\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/WiFiClient.h: In instantiation of 'size_t WiFiClient::write(T&, size_t) [with T = char*; size_t = unsigned int]':
      C:\Users\sjones\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:163:66:   required from here
      C:\Users\sjones\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/WiFiClient.h:123:36: error: request for member 'available' in 'source', which is of non-class type 'char*'
           size_t left = source.available();
      C:\Users\sjones\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi\src/WiFiClient.h:127:5: error: request for member 'read' in 'source', which is of non-class type 'char*'
           source.read(buffer.get(), will_send);
      exit status 1
      Error compiling for board SparkFun ESP8266 Thing Dev.
      I found some recommendations to put the "#include <ESP8266WiFi.h>" close to the top, and it fixed it for other users, but I'm having no success with that..
      Any idea what this may be?
      Thanks in advance..
      -Steve
      • 172pilot1 172pilot
        @Yveaux
        exit status 1
        Thanks in advance..
        -Steve
        @172pilot I'm not behind a PC right now, so it's hard to replay the situation.
        I'd say you either didn't clean everything out completely (use e.g. a completely separate Arduino folder for sketches and libraries), or it's the ESP Arduino port you're using (which version did you install through board manager?)
        172pilot1 1 Reply Last reply
        • YveauxY Yveaux
          172pilot1
          172pilot1
          172pilot
          @Yveaux Thanks.. Good to know what I'm doing SHOULD work.. :-)
          I have been storing everything in what I think is the default directory, which under my \users\sjones\Documents\Arduino\libraries. This is what the Arduino IDE is pointing to.
          Under that directory, I removed the MySensors directory and extracted the new 2.0 one.. BUT, I do see that there are more modules than just those under MySensors, so even though I think those are supposed to NOT conflict with the default ones, I missed one?
          Also, I dont understand why, but I see SOME arduino extension stuff under \program Files (x86)\arduino although I didn't see any MySensors information..
          And, the only other thing I saw which I didn't know how it got there was the one referred to in the error: "C:\Users\sjones\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi" Since that specifically was referred to in the error, I thought maybe I had an old version there, so I renamed the ESP8266Wifi directory to "old", figuring that whatever put it there in the first place would replace it with the current version if needed, but it didn't happen - it just failed to compile, complaining that it was missing, so I put it back..
          I'm not near my home computer now, but maybe when I get home I'll try with a completely new windows profile (create a new user) and reinstall Arduino from scratch
          Thanks for your help and patience!
          -Steve
          AffordableTechA 1 Reply Last reply
            -Steve
            AffordableTechA
            AffordableTechA
            AffordableTech
            Hi @172pilot
            I'm fairly certain from what you have described that you have NOT done this, but just in case I will mention it. Remember, simply renaming a folder within libraries (eg. 'MySensors' to 'MySensorsOLD') can cause grief as the old and new will both be compiled / seen by the linker.
            I think your 'new user' idea will work.
            FWIW: Some time ago I had a similar issue with a different library, I can't remember the details, but I found/fixed it by doing a global search of "C:" for various keywords (e.g. "ESP8" and "MySen" in your case). I ended up finding files I didn't realise were there.
            Good luck!
            Paul
            • AffordableTechA AffordableTech
              Hi @172pilot
              Good luck!
              Paul
              172pilot1
              172pilot1
              172pilot
              @AffordableTech @Yveaux
              I uninstalled Arduino completely, deleted everything I could find, and reinstalled from scratch, and after a bit of patience and rebooting the vera, I now have a functioning Wifi gateway using a Sparkfun 8266 Thing Dev board, and an NRF radio.. Then I was able to build a quick "Arduino switch" with an Uno and an NRF just to test, and it works great!!
              Now it's time to get creative and build some stuff!
              Thanks again!!
              -Steve
              • KosikaK Kosika
                Have had the GW running for a day now, as long as the client (Vera Edge) don't sent
                0;255;3;0;9;Client 0: 2;1;1;0;24;
                Or I start up an new sensor it's stable and works well.
                Problem now to figure out is how to connect a new sensor, as it restarts as soon as it's powered on.
                Any ideas?
                Note. Noticed that it only restarts upon new sensor startup if the client is connected.
                connected with Skoda, channel 6
                dhcp client start...
                .ip:192.168.1.5,mask:255.255.255.0,gw:192.168.1.1
                .IP: 192.168.1.5
                0;255;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:39.8
                0;255;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
                NO restart as the client is not connected
                0;255;3;0;9;Client 0 connected
                0;255;3;0;9;Client 0: 0;0;3;0;2;Get Version
                0;255;3;0;9;Client 0: 0;0;3;0;5;1
                0;255;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.2
                0;255;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:39.7
                0;255;3;0;9;Client 0: 255;255;3;0;4;3
                Soft WDT reset
                Here is restarted, inclusion mode or not does not matter
                afenoA
                afenoA
                afeno
                Any ideas?
                I have the same problem. I'm using the Esp8266Gateway sketch in the Lib v1.5 and have a NRF24 radio as described in the instructions.
                Every time that I connect a new sensor, the MCU is restarting as you described. This is only happening when the Gateway is connected to a controller (Homeassistant or MYSController). If the gateway is not connected to any controller then it receive the data without any problem.
                @Kosika, How did you solved the problem?
                KosikaK YveauxY 2 Replies Last reply
                • afenoA afeno
                  Any ideas?
                  KosikaK
                  KosikaK
                  Kosika
                  @afeno
                  I have not solved this problem. But I have put this project on ice the last 2 months, but I will soon continue by doing a complete reinstall of all libraries etc.
                  • afenoA afeno
                    Any ideas?
                    @afeno @Kosika please switch to the new 2.0.0 library, for your gateway, repeaters and sensors.
                    Esp support has been improved in there, and developer support will be faster.
                    afenoA 2 Replies Last reply
                    • YveauxY Yveaux
                      afenoA
                      afenoA
                      afeno
                      Ok. I will switch to 2.0.0 and let you know.
                      Thank you.
                      • YveauxY Yveaux
                        afenoA
                        afenoA
                        afeno
                        I switched to the new 2.0.0 and I still have the same problem:
                        connected with AFENO_DD, channel 6
                        0;255;3;0;9;TSM:READY
                        f r-40, scandone
                        .....ip:192.168.1.82,mask:255.255.255.0,gw:192.168.1.1
                        .IP: 192.168.1.82
                        0;255;3;0;9;TSP:MSG:READ 6-6-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                        0;255;3;0;9;TSP:MSG:BC
                        0;255;3;0;9;TSP:MSG:FPAR REQ (sender=6)
                        0;255;3;0;9;TSP:MSG:GWL OK
                        pm open,type:2 0
                        Soft WDT reset
                        ctx: cont
                        sp: 3ffef6b0 end: 3ffefa30 offset: 01b0
                        >>>stack>>>
                        3ffef860:  00000000 3ffefd08 3ffefd08 402048bb
                        3ffef870:  40107050 00000000 3ffefd08 402048bb
                        3ffef880:  00000000 3ffefd08 00000000 4020230f
                        3ffef890:  001e8480 3ffe0001 3ffefa8f 40202376
                        3ffef8a0:  00000000 0000000e 00000000 00000006
                        3ffef8b0:  00000000 00000000 00000006 00000006
                        What could be the reason for the reset?
                        Is it OK to power the NodeMCU from the microUSB?
                        Thank you!
                        • afenoA afeno
                          f r-40, scandone
                          .IP: 192.168.1.82
                          pm open,type:2 0
                          Soft WDT reset
                          ctx: cont
                          >>>stack>>>
                          Thank you!
                          @afeno what esp arduino core are you using? Try updating to the latest version.
                          I have an esp gateway running (2.0.0, fixed ip, mqtt client, powered through micro USB) without any issues. Power could be insufficiently stable though, so you could also try switching the power supply.
                          afenoA 1 Reply Last reply
                          • afenoA
                            afenoA
                            afeno
                            @Yveaux said:
                            last arduino core version and different power supply.
                            Hi, I'm using the version 2.3.0. I tried with different power supplies and all the same.
                            I will try the mqtt client just to see if it is working.
                            • YveauxY Yveaux
                              afenoA
                              afenoA
                              afeno
                              @Yveaux ,
                              I tried with the esp mqtt client and I have similar issues. The node is reseting when receiving the radio signal.
                              This is the log:
                              ž¡9C~0;255;3;0;9;Starting gateway (RNNGE-, 2.0.0)
                              0;255;3;0;9;TSM:INIT
                              0;255;3;0;9;TSM:RADIO:OK
                              0;255;3;0;9;TSM:GW MODE
                              scandone
                              state: 0 -> 2 (b0)
                              state: 2 -> 3 (0)
                              state: 3 -> 5 (10)
                              add 0
                              aid 4
                              cnt
                              chg_B1:-40
                              f r-40, scandone
                              .IP: 192.168.1.82
                              IP: 192.168.1.82
                              0;255;3;0;9;MQTT connected
                              Soft WDT reset
                              ctx: cont
                              sp: 3ffef6d0 end: 3ffefa50 offset: 01b0
                              >>>stack>>>
                              3ffef880:  00000000 3ffefc24 3ffefc24 40204d27
                              3ffef890:  40107050 00000000 3ffefc24 40204d27
                              3ffef8a0:  00000000 3ffefc24 00000000 40202336
                              3ffef8b0:  001e8480 3ffe0001 3ffefaaf 40202336
                              3ffef8c0:  00000000 0000000e 00000001 00000006
                              3ffef8d0:  00000000 00000000 00000006 00000006
                              3ffef8e0:  00000030 0000000e 00001928 402023d1
                              3ffef8f0:  00000001 3ffefaa8 00000006 402024ce
                              3ffef900:  00000008 00000006 3fff129c 00000027
                              3ffef910:  00000001 00000006 3ffefaa8 402035bc
                              3ffef920:  40107050 3ffef981 3ffefc24 00000061
                              3ffef930:  3ffef980 3ffefc24 3ffef980 40202336
                              3ffef940:  401054b2 000e937d 3ffefc24 3ffefc68
                              3ffef950:  4010556e 3ffee428 000e937d 00000000
                              3ffef960:  40105740 000e937d 3ffefc68 00000006
                              3ffef970:  000000ff 3ffefaa8 00000006 402026dd
                              3ffef980:  3ffefa06 00000006 40203bc8 00000006
                              3ffef990:  000000ff 3ffefaa8 00000006 402036fd
                              • afenoA
                                afenoA
                                afeno
                                I didn't give up (yet...) I tried today to power the NRF from an external power supply. Same result. The esp8266 is rebooting after receiving some data as shown above. My conclusion is that the problem is on the esp8266 itself or in the power supply that I am using.
                                My last try will be to power the esp8266 from something different than the microUSB.
                                Just in case, this is the setup. Maybe I'm missing something very basic:
                                Regaards,
                                Alfredo.
                                • afenoA afeno
                                  Regaards,
                                  Alfredo.
                                  @afeno hard to tell from the picture, but it looks like CE is connected to D1, instead of D2.
                                  Please refer to the connection diagram here: https://www.mysensors.org/build/esp8266_gateway
                                  • YveauxY Yveaux
                                    afenoA
                                    afenoA
                                    afeno
                                    @Yveaux , did you know that you are awesome?
                                    There is an error on Pin labels!!! The print on the pcb is wrong. You are right!
                                    I have two D2 and of course that I used the wrong one
                                    Thank you so much!!!!
                                    • afenoA afeno
                                      Yup :smirk:
