  3. Home Assistant
  4. unable to open USB port
23 Posts 4 Posters 8.0k Views 4 Watching
  • chillimanC
    chillimanC
    chilliman
    wrote on last edited by chilliman
    Martin.
    i have purchased a raspberry pi 3 running Debian Jessie loaded Home Assistant which working great i have add MySensors Gateway with a motion sensor node there is no error as regards to not opening the usb port (it says found and has open it) what i am getting error :-
    16-07-17 16:46:03 mysensors.mysensors: File does not exist or is not readable: path/mysensors.json
    16-07-17 16:46:03 mysensors.mysensors: Trying backup file: path/mysensors.json.bak
    16-07-17 16:46:03 mysensors.mysensors: File does not exist or is not readable: path/mysensors.json.bak
    16-07-17 16:46:03 mysensors.mysensors: Failed to load sensors from file: path/mysensors.json
    what do i have to do to get this working correctly any ideas
    chilliman
    • D
      drock1985
      The error says it. You have persistence turned on, but the file location is invalid or you do not have read/write access to it.
      What user are you using to turn on hass and what does the MySensors entry of configuration.yaml look like?
      My Projects
      2 Door Chime Sensor
      Washing Machine Monitor
      • chillimanC
        chillimanC
        chilliman
        drock1985
        do you have to have the persistence turned on , i turn on hass with pi (user)
        mysensors:
        gateways:
        - device: '/dev/ttyUSB0'
        persistence_file: 'path/mysensors2.json'
        baud_rate: 115200
        if i turn the persistence off i get a different error
        16-07-17 21:42:41 mysensors.mysensors: File does not exist or is not readable: /home/pi/.homeassistant/mysensors1.pickle
        16-07-17 21:42:41 mysensors.mysensors: Trying backup file: /home/pi/.homeassistant/mysensors1.pickle.bak
        16-07-17 21:42:41 mysensors.mysensors: File does not exist or is not readable: /home/pi/.homeassistant/mysensors1.pickle.bak
        16-07-17 21:42:41 mysensors.mysensors: Failed to load sensors from file: /home/pi/.homeassistant/mysensors1.pickle
        any ideas?
        chilliman
        • D
          drock1985
          Your path to the persistence file is wrong. You need to choose a directory that your user (in this case pi) has access to. I would recommend using /home/pi/.homeassistant so that your configuration.yaml flie would look like this:
          mysensors:
            gateways:
                persistence_file: 'home/pi/.homeassistant'
                baud_rate: 115200
            debug: false
            persistence: true
          The entry in your configuration.yaml file is a direct copy/paste of the example; you have to change it to meet your setup. The one I posted above should work fine for your install, and you can enable debug and launch hass manually from a terminal if you need to debug any MySensors related issues.
          My Projects
          2 Door Chime Sensor
          • chillimanC
            chillimanC
            chilliman
            drock1985.
            i cut and paste the example you posted but a get a error
            16-07-17 23:07:10 mysensors.mysensors: File does not exist or is not readable: home/pi/.homeassistant
            16-07-17 23:07:10 mysensors.mysensors: Trying backup file: home/pi/.homeassistant.bak
            16-07-17 23:07:10 mysensors.mysensors: File does not exist or is not readable: home/pi/.homeassistant.bak
            16-07-17 23:07:10 mysensors.mysensors: Failed to load sensors from file: home/pi/.homeassistant
            not sure what is going on hopefully you can help me
            chilliman
            D 1 Reply Last reply
            • chillimanC chilliman
              drock1985.
              chilliman
              drock1985
              wrote on last edited by drock1985
              @chilliman said:
              mysensors:
              gateways:
              baud_rate: 115200
              debug: false
              persistence: true
              My bad, forgot to add the file at the end of the directory.
              mysensors:
                gateways:
                    persistence_file: 'home/pi/.homeassistant/mysensors.json'
                    baud_rate: 115200
                debug: false
                persistence: true
              My Projects
              2 Door Chime Sensor
              • chillimanC
                chillimanC
                chilliman
                drock1985
                i just changed the conf file to with the latest and i get this error massage
                16-07-17 23:16:27 mysensors.mysensors: File does not exist or is not readable: home/pi/.homeassistant/mysensors.json
                16-07-17 23:16:27 mysensors.mysensors: Trying backup file: home/pi/.homeassistant/mysensors.json.bak
                16-07-17 23:16:27 mysensors.mysensors: File does not exist or is not readable: home/pi/.homeassistant/mysensors.json.bak
                16-07-17 23:16:27 mysensors.mysensors: Failed to load sensors from file: home/pi/.homeassistant/mysensors.json
                chilliman
                • chillimanC
                  chillimanC
                  chilliman
                  Drock1985
                  please find attached HA start up file
                  0_1468799007226_HA-startup.txt
                  thanks
                  chilliman
                    Drock1985
                    thanks
                    chilliman
                    martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    @chilliman
                    The first time you start home assistant, the persistence file will not have been created, so you will get the warning message even if you have set the correct path. Only after a sensor has reported a value will the persistence file be written. You should always include a sending of initial value in your setup/presentation function for a node, so once you have started the node, it will be added as a device to home assistant and the persistence file will be populated.
                    • chillimanC
                      chillimanC
                      chilliman
                      martin.
                      i am sorry i having a newbie moment i just need to understand what is happening so the way it is setup is good.
                      if so i have few more question , i have the gateway and all have a node with a motion sensor attached so how do i get the motion sensor to show up on HA .
                      sorry for not understanding its a very steep learning curve.
                      chilliman
                        martin.
                        chilliman
                        drock1985
                        @chilliman
                        Not sure what else to tell you. Like Martin said, for a node to appear at all in HA; it must do two things. 1) send the full presentation on the node start. Easiest way to do that is to start HA, and after HA is fully started put power to your motion sensor. 2) It must send a valid sensor status. In the case of a motion sensor, I believe it is either 1 or 0 (1 being motion detected, 0 being none).
                        The only thing I can see is maybe the / needs to be in front of home. Can't see it causing this many issues though.
                        mysensors:
                          gateways:
                              persistence_file: '/home/pi/.homeassistant/mysensors.json'
                              baud_rate: 115200
                          debug: false
                          persistence: true
                        Other than that i'm not sure what else to suggest. If everything is configured right, it should see it. You may also want to check out the debug part of MySensors config and HA to better determine your issue. @martinhjelmare help me with that issue some time ago.
                        My Projects
                        2 Door Chime Sensor
                        SebexS 1 Reply Last reply
                        • chillimanC
                          chillimanC
                          chilliman
                          Drock1985 & Martin.
                          thanks guys i have it working just needed to do the full presentation and where it was.
                          just a newbie mistake.
                          thanks again
                          chilliman.
                            Drock1985 & Martin.
                            thanks again
                            chilliman.
                            drock1985
                            @chilliman
                            No problem; just glad to hear you got it working. Everyone is new sometime.
                            FYI I made quite a few mistakes in the configuration.yaml file - took me a while to realize spaces were important ;)
                            Let us know if you have any other problems.
                            My Projects
                            2 Door Chime Sensor
                            • D drock1985
                              @chilliman
                              mysensors:
                                gateways:
                                    baud_rate: 115200
                                debug: false
                                persistence: true
                              SebexS
                              SebexS
                              Sebex
                              12.5k
