  3. Home Assistant
  4. unable to open USB port
23 Posts 4 Posters 8.0k Views 4 Watching
  • D
    drock1985
    The error says it. You have persistence turned on, but the file location is invalid or you do not have read/write access to it.
    What user are you using to turn on hass and what does the MySensors entry of configuration.yaml look like?
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
    • chillimanC
      chillimanC
      chilliman
      drock1985
      do you have to have the persistence turned on , i turn on hass with pi (user)
      mysensors:
      gateways:
      - device: '/dev/ttyUSB0'
      persistence_file: 'path/mysensors2.json'
      baud_rate: 115200
      if i turn the persistence off i get a different error
      16-07-17 21:42:41 mysensors.mysensors: File does not exist or is not readable: /home/pi/.homeassistant/mysensors1.pickle
      16-07-17 21:42:41 mysensors.mysensors: Trying backup file: /home/pi/.homeassistant/mysensors1.pickle.bak
      16-07-17 21:42:41 mysensors.mysensors: File does not exist or is not readable: /home/pi/.homeassistant/mysensors1.pickle.bak
      16-07-17 21:42:41 mysensors.mysensors: Failed to load sensors from file: /home/pi/.homeassistant/mysensors1.pickle
      any ideas?
      chilliman
      • D
        drock1985
        Your path to the persistence file is wrong. You need to choose a directory that your user (in this case pi) has access to. I would recommend using /home/pi/.homeassistant so that your configuration.yaml flie would look like this:
        mysensors:
          gateways:
              persistence_file: 'home/pi/.homeassistant'
              baud_rate: 115200
          debug: false
          persistence: true
        The entry in your configuration.yaml file is a direct copy/paste of the example; you have to change it to meet your setup. The one I posted above should work fine for your install, and you can enable debug and launch hass manually from a terminal if you need to debug any MySensors related issues.
        My Projects
        2 Door Chime Sensor
        • chillimanC
          chillimanC
          chilliman
          drock1985.
          i cut and paste the example you posted but a get a error
          16-07-17 23:07:10 mysensors.mysensors: File does not exist or is not readable: home/pi/.homeassistant
          16-07-17 23:07:10 mysensors.mysensors: Trying backup file: home/pi/.homeassistant.bak
          16-07-17 23:07:10 mysensors.mysensors: File does not exist or is not readable: home/pi/.homeassistant.bak
          16-07-17 23:07:10 mysensors.mysensors: Failed to load sensors from file: home/pi/.homeassistant
          not sure what is going on hopefully you can help me
          chilliman
          D 1 Reply Last reply
          • chillimanC chilliman
            drock1985.
            chilliman
            drock1985
            wrote on last edited by drock1985
            @chilliman said:
            mysensors:
            gateways:
            baud_rate: 115200
            debug: false
            persistence: true
            My bad, forgot to add the file at the end of the directory.
            mysensors:
              gateways:
                  persistence_file: 'home/pi/.homeassistant/mysensors.json'
                  baud_rate: 115200
              debug: false
              persistence: true
            My Projects
            2 Door Chime Sensor
            • chillimanC
              chillimanC
              chilliman
              drock1985
              i just changed the conf file to with the latest and i get this error massage
              16-07-17 23:16:27 mysensors.mysensors: File does not exist or is not readable: home/pi/.homeassistant/mysensors.json
              16-07-17 23:16:27 mysensors.mysensors: Trying backup file: home/pi/.homeassistant/mysensors.json.bak
              16-07-17 23:16:27 mysensors.mysensors: File does not exist or is not readable: home/pi/.homeassistant/mysensors.json.bak
              16-07-17 23:16:27 mysensors.mysensors: Failed to load sensors from file: home/pi/.homeassistant/mysensors.json
              chilliman
              • chillimanC
                chillimanC
                chilliman
                Drock1985
                please find attached HA start up file
                0_1468799007226_HA-startup.txt
                thanks
                chilliman
                  Drock1985
                  thanks
                  chilliman
                  martinhjelmareM
                  martinhjelmareM
                  martinhjelmare
                  @chilliman
                  The first time you start home assistant, the persistence file will not have been created, so you will get the warning message even if you have set the correct path. Only after a sensor has reported a value will the persistence file be written. You should always include a sending of initial value in your setup/presentation function for a node, so once you have started the node, it will be added as a device to home assistant and the persistence file will be populated.
                  • chillimanC
                    chillimanC
                    chilliman
                    martin.
                    i am sorry i having a newbie moment i just need to understand what is happening so the way it is setup is good.
                    if so i have few more question , i have the gateway and all have a node with a motion sensor attached so how do i get the motion sensor to show up on HA .
                    sorry for not understanding its a very steep learning curve.
                    chilliman
                      martin.
                      chilliman
                      drock1985
                      @chilliman
                      Not sure what else to tell you. Like Martin said, for a node to appear at all in HA; it must do two things. 1) send the full presentation on the node start. Easiest way to do that is to start HA, and after HA is fully started put power to your motion sensor. 2) It must send a valid sensor status. In the case of a motion sensor, I believe it is either 1 or 0 (1 being motion detected, 0 being none).
                      The only thing I can see is maybe the / needs to be in front of home. Can't see it causing this many issues though.
                      mysensors:
                        gateways:
                            persistence_file: '/home/pi/.homeassistant/mysensors.json'
                            baud_rate: 115200
                        debug: false
                        persistence: true
                      Other than that i'm not sure what else to suggest. If everything is configured right, it should see it. You may also want to check out the debug part of MySensors config and HA to better determine your issue. @martinhjelmare help me with that issue some time ago.
                      My Projects
                      2 Door Chime Sensor
                      SebexS 1 Reply Last reply
                      • chillimanC
                        chillimanC
                        chilliman
                        Drock1985 & Martin.
                        thanks guys i have it working just needed to do the full presentation and where it was.
                        just a newbie mistake.
                        thanks again
                        chilliman.
                          Drock1985 & Martin.
                          thanks again
                          chilliman.
                          drock1985
                          @chilliman
                          No problem; just glad to hear you got it working. Everyone is new sometime.
                          FYI I made quite a few mistakes in the configuration.yaml file - took me a while to realize spaces were important ;)
                          Let us know if you have any other problems.
                          My Projects
                          2 Door Chime Sensor
                          • D drock1985
                            @chilliman
                            mysensors:
                              gateways:
                                  baud_rate: 115200
                              debug: false
                              persistence: true
                            SebexS
                            SebexS
                            Sebex
                            12.5k
