  3. Home Assistant
  4. unable to open USB port
23 Posts 4 Posters 8.0k Views 4 Watching
  • D
    drock1985
    Your path to the persistence file is wrong. You need to choose a directory that your user (in this case pi) has access to. I would recommend using /home/pi/.homeassistant so that your configuration.yaml flie would look like this:
    mysensors:
      gateways:
        - device: '/dev/ttyUSB0'
          persistence_file: 'home/pi/.homeassistant'
          baud_rate: 115200
      debug: false
      persistence: true
    The entry in your configuration.yaml file is a direct copy/paste of the example; you have to change it to meet your setup. The one I posted above should work fine for your install, and you can enable debug and launch hass manually from a terminal if you need to debug any MySensors related issues.
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
    • chillimanC
      chillimanC
      chilliman
      drock1985.
      i cut and paste the example you posted but a get a error
      16-07-17 23:07:10 mysensors.mysensors: File does not exist or is not readable: home/pi/.homeassistant
      16-07-17 23:07:10 mysensors.mysensors: Trying backup file: home/pi/.homeassistant.bak
      16-07-17 23:07:10 mysensors.mysensors: File does not exist or is not readable: home/pi/.homeassistant.bak
      16-07-17 23:07:10 mysensors.mysensors: Failed to load sensors from file: home/pi/.homeassistant
      not sure what is going on hopefully you can help me
      chilliman
      D 1 Reply Last reply
      • chillimanC chilliman
        drock1985.
        chilliman
        drock1985
        wrote on last edited by drock1985
        @chilliman said:
        mysensors:
        gateways:
        baud_rate: 115200
        debug: false
        persistence: true
        My bad, forgot to add the file at the end of the directory.
        mysensors:
          gateways:
              persistence_file: 'home/pi/.homeassistant/mysensors.json'
              baud_rate: 115200
          debug: false
          persistence: true
        My Projects
        2 Door Chime Sensor
        • chillimanC
          chillimanC
          chilliman
          drock1985
          i just changed the conf file to with the latest and i get this error massage
          16-07-17 23:16:27 mysensors.mysensors: File does not exist or is not readable: home/pi/.homeassistant/mysensors.json
          16-07-17 23:16:27 mysensors.mysensors: Trying backup file: home/pi/.homeassistant/mysensors.json.bak
          16-07-17 23:16:27 mysensors.mysensors: File does not exist or is not readable: home/pi/.homeassistant/mysensors.json.bak
          16-07-17 23:16:27 mysensors.mysensors: Failed to load sensors from file: home/pi/.homeassistant/mysensors.json
          chilliman
          • chillimanC
            chillimanC
            chilliman
            Drock1985
            please find attached HA start up file
            0_1468799007226_HA-startup.txt
            thanks
            chilliman
              Drock1985
              thanks
              chilliman
              martinhjelmareM
              martinhjelmareM
              martinhjelmare
              @chilliman
              The first time you start home assistant, the persistence file will not have been created, so you will get the warning message even if you have set the correct path. Only after a sensor has reported a value will the persistence file be written. You should always include a sending of initial value in your setup/presentation function for a node, so once you have started the node, it will be added as a device to home assistant and the persistence file will be populated.
              • chillimanC
                chillimanC
                chilliman
                martin.
                i am sorry i having a newbie moment i just need to understand what is happening so the way it is setup is good.
                if so i have few more question , i have the gateway and all have a node with a motion sensor attached so how do i get the motion sensor to show up on HA .
                sorry for not understanding its a very steep learning curve.
                chilliman
                  martin.
                  chilliman
                  drock1985
                  @chilliman
                  Not sure what else to tell you. Like Martin said, for a node to appear at all in HA; it must do two things. 1) send the full presentation on the node start. Easiest way to do that is to start HA, and after HA is fully started put power to your motion sensor. 2) It must send a valid sensor status. In the case of a motion sensor, I believe it is either 1 or 0 (1 being motion detected, 0 being none).
                  The only thing I can see is maybe the / needs to be in front of home. Can't see it causing this many issues though.
                  mysensors:
                    gateways:
                        persistence_file: '/home/pi/.homeassistant/mysensors.json'
                        baud_rate: 115200
                    debug: false
                    persistence: true
                  Other than that i'm not sure what else to suggest. If everything is configured right, it should see it. You may also want to check out the debug part of MySensors config and HA to better determine your issue. @martinhjelmare help me with that issue some time ago.
                  My Projects
                  2 Door Chime Sensor
                  SebexS 1 Reply Last reply
                  • chillimanC
                    chillimanC
                    chilliman
                    Drock1985 & Martin.
                    thanks guys i have it working just needed to do the full presentation and where it was.
                    just a newbie mistake.
                    thanks again
                    chilliman.
                      Drock1985 & Martin.
                      thanks again
                      chilliman.
                      drock1985
                      @chilliman
                      No problem; just glad to hear you got it working. Everyone is new sometime.
                      FYI I made quite a few mistakes in the configuration.yaml file - took me a while to realize spaces were important ;)
                      Let us know if you have any other problems.
                      My Projects
                      2 Door Chime Sensor
                      • D drock1985
                        @chilliman
                        mysensors:
                          gateways:
                              baud_rate: 115200
                          debug: false
                          persistence: true
                        SebexS
                        SebexS
                        Sebex
                        12.5k
